ClassicTractorProfessor 5,366 #1 Posted April 29, 2016 Does anyone know where I can get a cooling fan for the hydrostat on my 1277. Mine is beat up pretty bad...I've searched all over on Google with no luck Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,251 #2 Posted April 29, 2016 If you go to a Toro dealer now it says the 6108 fan is a [ duplicate part. See $book ]. I suspect that means price book and the revised part number may be listed there. https://www.partstree.com/parts/search/parts/?searchTerm=6108 If you have a local well established Toro dealer with older experience give them a call and see. You may just get lucky. Garry 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,366 #3 Posted April 29, 2016 Thanks Garry I will have to try and find a Toro dealer somewhere close to me...sometimes living out in the middle of nowhere really sucks Share this post Link to post Share on other sites
roadapples 6,983 #4 Posted April 29, 2016 Seen them on fleebay.. 1 Share this post Link to post Share on other sites
wallfish 17,507 #5 Posted April 29, 2016 Is that the kind which has fins in the cast pulley to blow the air? If so, I might have one for you The Partstree link for that part #6108 is funny--- "DUP PART see $book" Tells you right away they are proud of that part 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,366 #6 Posted April 30, 2016 36 minutes ago, wallfish said: Is that the kind which has fins in the cast pulley to blow the air? If so, I might have one for you The Partstree link for that part #6108 is funny--- "DUP PART see $book" Tells you right away they are proud of that part Not around my tractor to get pics but found this one on Google...my fan looks just like it only in BAD shape 3 Share this post Link to post Share on other sites
Aldon 4,828 #7 Posted April 30, 2016 (edited) That looks very similar to the one on GT14 Hydro's. If you can't locate one, I posted a thread on how to duplicate one using a similar fan from McMaster Carr. Under GT14 hydro fan. Probably could use same fan with slight mod. Edited April 30, 2016 by Aldon 3 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,366 #8 Posted April 30, 2016 12 minutes ago, Aldon said: That looks very similar to the one on GT14 Hydro's. If you can't locate one, I posted a thread on how to duplicate one using a similar fan from McMaster Carr. Under GT14 hydro fan. Probably could use same fan with slight mod. Just searched for your thread and think I might try to do just that...for no more than that little fan costs it's worth a try. Thanks 2 Share this post Link to post Share on other sites
