buffaloman
1962 702 fuel pump diagram ??
buffaloman
Is there a diagram of the fuel pump for the 702 I guess 161k . when I got this tractor the pump was off of it ,im trying to figure out if it was put back together correctly, ive searched down in the manual section but I cant seem to find it ? thanks for help
rmaynard
I don't know if there is a diagram, but I have one that I can take apart and get you some pictures if it will help.
rmaynard
Raining here today, so I have plenty of downtime. Took some pictures for you.
Here is the vacuum operated (pulse) pump assembled
Notice the IN and OUT markings on the top
With the screws removed, the pump splits open revealing the diaphragm.
With the diaphragm removed, the one-way valve assembly is seen.
One screw is removed and the valve cover is removed. Notice the INLET side (left) has a fine coil spring, and the OUTLET side (right) has a flat disc. There is
also a gasket to seal the cover.
On the left we see the INLET disc, and on the right we see the OUTLET spring.
That is how it supposed to be assembled. I hope this helps.
Edited by rmaynard
  • Like 9
Racinbob
Nice Bob :handgestures-thumbsup:
