Marv 919 #1 Posted April 26, 2016 The clutch spring broke on my 486. While researching I discovered the spring for B80, C120. C160 etc Pn 1014 has been discontinued and Toro does not offer a substitute number. The 486 Pn108035 is available. It is heavier than the 1014 Spring. I see no reason we can't use the 108035 to replace it when needed. Marvin 1 Share this post Link to post Share on other sites
Racinbob 11,030 #2 Posted April 26, 2016 You bet, works fine. I didn't know it was heavier. That's probably to compensate for the damper they put on some models. The damper that was on mine fell off 1 Share this post Link to post Share on other sites
doc724 925 #3 Posted April 26, 2016 Marv, I ran into the same problem when I was restoring my C141. Came up with the same P/N you did 108035. Bought 2, installed one and keep one in my WH spare parts box. 3 Share this post Link to post Share on other sites
Dakota8338 115 #4 Posted April 3, 2018 This is a couple of years old now, but looking for the same spring (number 1014), I encountered an updated number 83-2730, which is still in stock at some locations. If we are allowed to site sources, I will in the future. If not, PM me and I will provide my source. 1 Share this post Link to post Share on other sites
Lane Ranger 10,943 #5 Posted April 13, 2018 Something worth Noting about Wheel Horse/Toro Clutch Springs Interesting thing about these Wheel Horse clutch springs. The original 1014 spring is shorter than the replacement 108035. My clutch spring on my 603 (red one missing one end rusted off in photo) was a little wider than the 83-2730 (a later replacement) and the current clutch spring version 108035 is really too long to properly clutch that transmission. Yes, you can adjust the brake band but not enough on the 603 version. I do have a couple of the 83-2730 versions that are New Old Stock but I also note then are a little narrower on the spring as seen in my photo this from this morning. 3 Share this post Link to post Share on other sites
Racinbob 11,030 #6 Posted April 13, 2018 That's interesting Lane. I've never come across a 2 piece case transmission where a 108035 wouldn't work. I have a 5025 and it works fine Maybe the spring is connected differently? Pictures? Share this post Link to post Share on other sites
Willie 14 #7 Posted August 29, 2022 I’m replacing a worn out clutch spring on my 77 C120. My replacement part is about 1/3 the size of the worn out part. Anybody got any ideas on how I can install this thing? I don’t know if I’m strong enough to stretches thing out. Share this post Link to post Share on other sites
Racinbob 11,030 #8 Posted August 29, 2022 (edited) 48 minutes ago, Willie said: I’m replacing a worn out clutch spring on my 77 C120. My replacement part is about 1/3 the size of the worn out part. Anybody got any ideas on how I can install this thing? I don’t know if I’m strong enough to stretches thing out. You've got the wrong spring. You want a 108035. I wouldn't try to make the one you have work. I always have a couple of them in my stash. Four of my five use them. Readily available on Ebay. Edited August 29, 2022 by Racinbob Share this post Link to post Share on other sites
Willie 14 #9 Posted August 29, 2022 Ten4 good buddy. Share this post Link to post Share on other sites
peter lena 8,577 #10 Posted August 29, 2022 @Marv while you are on that spring detail , get some penetrating oil into the connection ends of all related linkage , or grease fittings . like aerosol red grease with spray tube after the rust runs out , pinpoint lasting lubricant , takes the effort out of linkage . pete Share this post Link to post Share on other sites
Racinbob 11,030 #11 Posted August 30, 2022 I suspect you know this but Here's the correct hook up points. This is a 76 C-series, identical to yours. 2 Share this post Link to post Share on other sites
Handy Don 12,116 #12 Posted September 3, 2022 On 8/29/2022 at 8:58 PM, Racinbob said: I suspect you know this but Here's the correct hook up points. This is a 76 C-series, identical to yours. Nice photo! Share this post Link to post Share on other sites
Willie 14 #13 Posted September 3, 2022 Got my spring from jacks and installed it today. I left my clutch linkage adjustment where it was. How many threads are showing on your clutch linkage adjustable nut? I have 5. This new spring is much better than the factory one I took off. Thanks. Share this post Link to post Share on other sites
Willie 14 #14 Posted September 3, 2022 On 7/27/2022 at 3:41 PM, mabsoon said: Yes they are. I have pics but they are too big to post…. the agricultural tires are also on rims. Share this post Link to post Share on other sites
mabsoon 60 #15 Posted September 6, 2022 Ag tires sold. Share this post Link to post Share on other sites
