Ed Kennell 38,021 #1 Posted April 26, 2016 This was a project I started over a year ago, but I never finished making a mount to the attach-a-matic. Looking thru the "junke" pile, The handle frame that was left from the MAD MAX tiller looked like a chipper mount. I had removed everything from the blown engine except the crankshaft and used it as a bearing block. I bolted a V pulley to the flywheel and removed the aluminum shear key and made a hardened steel key to strengthen the drive train. I seemed to work OK when I blocked it to the 875. This is the old tiller I converted to Mad Max. MAD MAX And now the Mad Chipper. 13 Share this post Link to post Share on other sites
JAinVA 4,619 #2 Posted April 27, 2016 (edited) .Ed, Haven't seen a belt arrangement like that except for long flat leather belts.How long do you think that the drive belt will last? I have thought about having a tractor mounted chipper but the engine turns the wrong way for most.Never thought about what you have discovered.Love the out of the box thinking! Thanks,JAinVA JimAnderson Gloucester.Va Edited April 27, 2016 by JAinVA 2 Share this post Link to post Share on other sites
WHX?? 48,760 #3 Posted April 27, 2016 Your contraptions are definitly different Ed...keep up the the under the apple tree engineneering! 3 Share this post Link to post Share on other sites
JPWH 6,032 #4 Posted April 27, 2016 That's how recycling should be done! I like your thinking. 1 Share this post Link to post Share on other sites
312Hydro 474 #5 Posted April 27, 2016 Great work on both of the attachments,Ed. You not only recycled,but made two very useful tools for your horse. 2 Share this post Link to post Share on other sites
Ed Kennell 38,021 #6 Posted April 27, 2016 1 hour ago, JAinVA said Quote .How long do you think that the drive belt will last? Only time will tell. I don't think the twisting will have much affect on the belt life. My concern was the rubbing and the resulting heat at the crossover. So that is why I added the separator. That is a piece of SST tubing spinning on a greased bolt. There is not much side load on the tubing as the belt puts the same force on both sides and both sides spin the tubing in the same direction. I did consider an idler pulley on the return side of the belt to keep them separated. If this one fails we'll go to plan B. Quote 5 Share this post Link to post Share on other sites
WHX?? 48,760 #7 Posted April 27, 2016 Well said Ed! .... if all al fails go back to the board! 1 Share this post Link to post Share on other sites
Ed Kennell 38,021 #8 Posted April 27, 2016 Yeah Jim, after spending 45+ years doing R & D in a model hydro turbine lab, I came to realize R & D really means T & E. 3 Share this post Link to post Share on other sites
WHX?? 48,760 #9 Posted April 27, 2016 That was trial & error right Ed not......well will telll you when at the show want to keep this a family site!!! 1 Share this post Link to post Share on other sites
Docwheelhorse 2,660 #10 Posted April 27, 2016 Like the idea, love the front tiller.... but I'm wondering what's going to lube the Crank bearings on either end of the block on the chipper. How about putting the piston and rod with the dipper back in and leaving the plug out / blocking the intake, exhaust ports.... fill 'er up with oil and off to the races... Tony Share this post Link to post Share on other sites
Ed Kennell 38,021 #11 Posted April 27, 2016 Thanks Tony. The block is filled with oil high enough for the crank to dip in at the bottom of the stroke. This should throw as much or more oil on the bearings as the piston rod dipper. The valves and piston have been removed, so they don't need any lube. Yep, T & E is trial and error in my vocab Jim........ I can't wait to hear your definition though. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,295 #12 Posted April 27, 2016 I just want to know if MAD MAX and Mad Chipper will be at the show. I would love to see them. 1 Share this post Link to post Share on other sites
Ed Kennell 38,021 #13 Posted April 27, 2016 I don't think I will have enough room Jim. Unless I find a bigger trailer....... Share this post Link to post Share on other sites
Lost Pup 172 #14 Posted April 27, 2016 My chipper/shredder is one of my favorites, really need it with a wooded lot. Great job on yours. 4 Share this post Link to post Share on other sites
squonk 41,018 #15 Posted April 28, 2016 I put a horizontal snowblower on a vertical shaft tractor and twisted the belt. A regular belt lasted an hour, but a green Napa Belt would last 4 seasons. It would wear down and eventually flip over but kept up driving with no slipping. 2 Share this post Link to post Share on other sites
ericj 1,578 #16 Posted May 1, 2016 you may need a trailer like this Ed, this is an Appalachian trailer 10K 82" wide 20' long, should have plenty of room to put 6 tractors on and have room to spare or implements eric j 3 Share this post Link to post Share on other sites
Ed Kennell 38,021 #17 Posted May 4, 2016 I try to stay away from trailers with brakes that require inspections Eric. I sold the 23' boat and trailer last year. The brake maintenance in the salt water was a real PITA. I still have 4 trailers without brakes though. Maybe I should sell em all and get one 20 footer like that . 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,314 #18 Posted May 5, 2016 Really liking that chipper...would sure be handy in my business to have one of those Share this post Link to post Share on other sites
wrightorchid 261 #19 Posted May 5, 2016 I have a smaller regular chipper, I think it is about 6 hp. It is quicker and easier to just haul it to the burn pile. I know that is not an option for everybody. I chipped for a while, but things like green viburnum, vines, and and hard dried wood can really be a problem. Branches with lots of forks are an issue too, since it has to be able to be fed into it. If I had one of the bigger commercial ones, that would certainly be nice. Share this post Link to post Share on other sites
