HorseFixer
Started Working In The Horse Stable!
Butch
Thanks Duke! :thumbs: Duff I haven't heard anything about this new PT lumber yet. I don't even know how long it has been tested in the field for rot. And I sure hopes it's "pressure" treated and not dipped. I haven't heard anything about screws or nails rusting yet. My neighbor is a framer and my sons friend owns a bulkhead company and I haven't heard any complaints channeling through yet. I never liked galvanized nails. I prefer hot dip when I can find them. They can be hard to find. Best nails I ever came across is from a company called Maze. Great nails if you can find them. I nailed the cedar siding to my house 21 years ago with Maze nails. The heads haven't rusted or stained the siding and the suckers still have a ton of gripping power. My deck also has Maze deck nails. They're much stronger than deck screws. The down side is you can't yank them out without a lot of effort. You wind up tearing up the deck.
Duff
Duff I had a simular situation a couple years ago myself and checked into what you said and found that they are now making coated deck screws for treated lumber that are like gauranteed for 50 years. If you look on top of that beam you will see coated screws there are only a handfull of nails used anywhere on the horse barn everything is screwed and predrilled before screwed thats why you see somany drills around in the jobsite.
I have been told the reason there is a chemical reaction is because of constant moisture of the decks treated lumber being outside in the weather. I have also heard that the chemical in the treated lumber doesn't like the zinc in the galvanized coating :lol: I donot belive in the dry there will be a problem. :whistle:
I shoulda known you'd be on top of this situation! You are DA MAN! :whistle:
Also glad to see I'm not the only one who builds everything with screws and glue. (I keep a collection of sizes of the 50 yr. ceramic screws around) My shop is only 12x24 freestanding, but I'll bet there isn't a quarter pound of nails in the entire structure. Deck screws and S/S lag bolts on the other hand....oh yeah! :banana:
I intentionally framed and built my shop so if I ever move, it can be jacked up and go with me. It's already a foot off the ground on 8x8 PT posts. But my interior doesn't hold a candle to yours - nice work, guy! :thumbs:
Duff :dunno:
linen beige
Butch, as I was reading your post I instantly thought "I bet he's never tried Maze nails." then in the next line you mention them. You're right about the holding power. You just about have to cut the heads with a grinder and drive them through with a punch to take things apart.
I used Maze nails on a few parts of my deck in '01, (older CCA treated wood.) with the rest fastened with what looks like the same coated screws Duke is using. Last year I redid the landing and stairs and found most of the screws corroded, but the nails were still good as new.
Duke, Is the new type pressure treated allowed in indoor apps.? They stopped allowing pressure treated down here. Not even for a sill plate in a basement wall! We have to use plain old wood with a galvanized metal shield under it. I don't know if the new PT is allowed.
The shelves are taking shape! :thumbs:
One concern though: With PT's propensity for bowing, twisting, and warping I think I would have used doubled 2X4s for uprights to get some grain opposition to resist bending. Or some metal "basement jack" pipes.
What are you planning to use for decking?
big mike
With the Federal Governments "protecting us from danger" and banning copper chromated arsenate they left us with alkaline copper quaternary which likes to eat stuff......mainly steel and aluminum.
Fasteners should be triple zinc plated,hot dipped galvanized or stainless steel.....inside or outside use.
The reason we have so much trouble with pressure treated is because the tree is cut down,machined into lumber and the kiln dried then it is loaded into a pressure vessel which is filled with treatment.The vessel is then pressurized and fills the wood fibers full of liquid again,then it is bundled and shipped to lumberyards.....or Lowes :thumbs:
If you want good results with pressure treated try and find kiln-dried-after-treatment and you wont have near the problems.
That being said,I doubt you'll loose your shelf from corrosion from the PT lumber.
HorseFixer
Thanks Butch Ill ck into the Maize Nails hafta look them up online! :thumbs:
Thanks Duff! :whistle:
Jim ~ we are okay here with the PT lumber, a matter of fact they require it above a foundation as a sill plate. The decking will be 3/4" OSB on the platform & 1/2" on the shelf! All this was figured by a master carpenter builder frien of mine Big Mike knows him also, ( TIM EN****) Big Mike used to work for the Oldest lumber Yard in Niles no doubt he knows his chit on lumber. :whistle:
More later.... In what seems to be a never ending saga.... <_< Be glad when the damn thing is done I'm getting burned out! :dunno:
linen beige
They still allow it for sills here too Duke. Those are not considered interior walls. But a framed wall inside the perimeter concrete wall of a basement IS.
Maze nails should be available at Lowes.
HorseFixer
Jim ~ I asked my Bud The Contractor about 2X4's -VS- a single treated 4X4 and he said a singular piece of lumber of same dimension is way stronger. Twisting is also not a factor due to its small length. I dont understand what you mean by grain oposition the grain in a 2X4 run one way I dont care if you flip it end for end the grain still runs lengthways. As far Jackposts In this application way way to exspensive for this application The 4X4's are way overkill as it is for about 20% of the price besides that they look much nicer and matches the structure. :thumbs:
linen beige
The solid 4x4 is probably stronger than 2 2x4s laminated together in terms of compressive strength, but NOT in terms of resistance to warpage, bending, twisting IF the end grain "arch" of the 2x4s is oriented so that those "arches" oppose one another. The solid 4x4 is most prone to bending if one side is exposed to more moisture and/or slower drying than the other. That's why the outer edges of deck boards always seem to warp, or cup upward and cause them to hold water, regardless of whether they are installed arch up or arch down. When it rains they get wet and the wood swells. Then after the rain gravity and sunshine dry the top side more quickly than the bottom. The bottom stays swelled but the top shrinks and causes the wood to cup. If allowed to fully dry they will return to flat. Cycles of exposure to cold, damp air and hot, dry air as in a garage that is heated only for a few hours and then allowed to cool off for a few hours when you're not using it can also cause this if the dryer heated air can get to one side of the post more easily.
The doubled 2x4s would be more than strong enough for your application and would add the resistance to bending.
big mike
I always figgered it was Randy that knew his S&*# and Tim was FULL of it :thumbs:
Either way if those guys helped you pour the foundation and floor you can play pool on it!
Butch
I was at Lowes the other day and they only had 8p but I did pick up a box to have on hand. Our Lowes has never had much in the way of Maze nails. When I built my house I ordered 50lb boxes of siding nails along with the cedar siding. I had bought around 10lbs of 16p when a lumber yard use to carry them but I've gone through them. You can order through Maze themselves but I think you have to order 50lb boxes. They are probably easier to find in the midwest which is closer to the manufacturer. I do buy them when I run across them.
perry
great job on the horse stable duke :thumbs: . you do some nice work. how about red switch-plug cover plates :whistle: .
HorseFixer
great job on the horse stable duke :whistle: . you do some nice work. how about red switch-plug cover plates :dunno: .
Thanks Guys, Perry that is definitely an Idea may have to get the Red brush back out! :whistle: Have been busy the past few nights grinding the floor with a diamond grinder, this being done to give the floor the proper profile to except Epoxy Coat base coat and flakes that were previously shown. Will have more pics this weekend. :thumbs:
HorseFixer
When you are going to apply an Epoxy on a concrete floor you have to have a profile on the floor. It doesn't matter if it is new concrete or not in order for the Epoxy to adhere to the floor most floor coating manufactures suggest using a shot blaster or a diamond grinder to prep the floor and get it ready for the Epoxy floor paint. The Epoxy floor paint that I am using is so tuff that you can clean it with Xylene or lacquer thinner. Its allot of work to diamond grind the floor but it will make it adhere better and the floor will be long lasting. Actually when I was finished grinding it looked pretty neat with the grind-ed aggregate that was showing. I probably could have just clear coated the floor at this point with a urethane but the fleck patter that I have chosen looks allot better I think.
I set up a furnace blower to help with the residual airborne dust and used a sheet of Styrofoam board to block off the doorway and exhausted the air thru a 12" spiral foil duct to the building exterior. To not draw the garage down in a negative pressure I cracked the garage door open an inch. The grinder I used was a Milwaukee with a 24 facet diamond blade, the grinder had a modified head that hooked to a shop vac and I used Drywall bags to collect the dust. When I was finished I be I had close to 80lbs of dust I had collected in 5 large Shop Vac Drywall bags. Here are some pics.
Picture Of Blocked Off Door With Blower Exhaust 12" Duct
1400 CFM Direct Drive Exhaust Fan Came Out Of A Furnace.
Look At The Difference Between The Picture Below And The Picture After Look at How Much Smoother The Floor Is! This is the same area! :whistle:
Above Pic Before Grinding! :thumbs:
Below Pic After Grinding! :whistle:
HorseFixer
Sheeted The Platform Tonight, Will Be Applying the Epoxy finish to this first. I plan on sheeting the shelving tomorrow and then will move onto doing a major clean up getting ready for the epoxy coating on the platform and then the floor. Gonna haft crank up the heat in order to get the floor temp above 40 deg would like to be at 50 deg pretty Tiff in this cold weather! :thumbs:
Suburban 550
Duke, by the looks of the way you constructed that platform you should be able to park your Jeep on it and not worry about it coming down. :whistle: I know who to call if I ever have to borrow any tools. :thumbs: The epoxy finish should look great on the platform and floor.
HorseFixer
Thanks Ray :thumbs: worked on the platform yesterday and the shelving unit plan on laying down the Epoxy on the platform later this evening will have some pictures later! :whistle:
KyBlue
Lookin good Duke!!
HorseFixer
Well got all the shelving sheeted and installed, also installed the trim boards on the platform. After that was completed I taped off the trim boards which will be painted red and filled T-11 siding groves with caulk because of the epoxy that would be thick on the shelf. I then taped the edges with painters tape. I then installed the Epoxy-Coat and gave her a good the flec mixture.
Nick
Duke, Looks like the stable project is coming towards the end. Always liked the look of that epoxy on garage floors but never seen it used on a shelf. Looks good.
Couple months ago think I sold what ya needed for the floor. Gas powered and air powered floor scarifiers.
wh500special
The Epoxy floor paint that I am using is so tuff that you can clean it with Xylene or lacquer thinner...
Duke,
You CAN use strong non-polar solvents like that to clean it but I wouldn't. Worst thing you're probably going to have to deal with are oil drips from your antiques. In that case use soap and water.
Many epoxies are resistant to solvents (your floor will probably be an amine cured bis-F formulation) but solvents - especially acetone and even xylene - WILL soften it over time. If you elect to use solvents for cleanup use a wipe-on, wipe-off method and don't let them soak.
If you want to get ultra sophisticated on the floor surface and tap into your retirement account a little deeper, you can thicken the epoxy with sand and trowel it on to whatever thickness you desire. It makes a surface that is a little less hard than concrete but is a whole lot tougher.
Of course, it takes more epoxy so makes it more expensive too. We had a floor covered at work by Stonhard and it was troweled on about 1/4" thick with a simple cosmetic topcoat - like the one you're using - on top of that. very durable and held up well to solvent splashes, forklift traffic, and our own spilled epoxies and polyesters. The whole benefit for us was not increasing the life of the floor but was to make things easier to clean up.
Steve
EDIT: I went back and now see that your floor chemistry is actually a cycloaliphatic epoxy :thumbs: ...but I'm still singing the same song about solvent resistance.
HorseFixer
Duke,
Steve
EDIT: I went back and now see that your floor chemistry is actually a cycloaliphatic epoxy :whistle: ...but I'm still singing the same song about solvent resistance.
Thanks Nick yep we have used Shot Blasters & Scaffiers at the Jail when repainting the dorms, Scaffiers leave the floor I think a little to rough maybe for this product however some floor epoxies & finishes that are troweled on require a lot of TEETH to allow the coating to BITE into.
Steve yeah I have no intentions even tho the product I am using is Cycloaliphatic Epoxy to allow Xylene or Lacquer Thinner to sit on there. No doubt it would evaporate fast and not harm it but I would not chance it!! I would do like you said and use it as a wipe clean method then prolly mop it with some soapy water. :thumbs: To the rest of you this is a PROFESSIONAL PRODUCT not that Water Bourne Crap you buy at Lowe's, Home Depot, or Menard's. This stuff holds up for 20 years in traffic areas and just laughs at Salt Snow & GRIME Hot Tires or whatever. Thats Because Water Bourne Epoxy Shrinks After The Moisture Evaporates, This STuff Is 100% Epoxy And Does Not Shrink And Povides Over 5 Times The Thickness When Cured. The DUKES Horse Stable will not give it the abuse it can take so I am thinking it will last the rest of my days. Sometime I plan on doing My Shop Floor But I will do a test and see if it will stand up to WELDING CHERRIES & SPATTER :whistle: If it does work I will.
CasualObserver
Looks great Duke, but pardon my ignorance.... How ya going to get the painters tape off? Isn't that stuff cut and scratch resistant too? :thumbs:
Duff
I'm going to make a SWAG (scientific willd azz guess) here, but I'll bet he pulled the tape just after the stuff went to "tack"............ :whistle:
Duff :whistle:
HorseFixer
Jason that is a good question :whistle: and I have not removed the tape yet and you will see why. The tape is thin and can be cut with a sharp exacto or stanley knife. You have to remember this stuff is tuff when it has the concrete or some other substrate for a backing, along the wood it is thin mainly at a wood seam I dont think there will be a problem. :whistle:
HorseFixer
Last night after finishing up something just wasn't sitting right with me, :thumbs: the gray looking color just didn't seem to be right! <_< on further investigation I was right. I found out the color the company sent me was GRANITE not GRAPHITE like I asked for. To make sure I took the samples out of my truck and went in the Horse Stable for a comparison, sure enough the color was wrong.
A call to Epoxy Coat the company That I used and all was handled to my satisfaction with proper comps given, and my shipment will be at my local UPS company in the morning. :dunno: I really appreciate a company like Epoxy Coat that steps up to the plate and takes care of its customers! This has made me a believer in this company and I highly reccomend them not only for their superior products, but also their outstanding service after the sale! :D If you ever need any of their Products ask for Christine she is fantastic to deal with! :whistle:
I will do the floor tomorrow and in 3 days most likely Friday night I will redo the platform, this will not take much product to redo because it has a good coat on already. There was a couple fish eyes in the surface and this second coat will cover those nicely. :omg:
I spent today masking the floor edges and giving the floor a couple more good sweepins. I also insulated around the foundation with R-30 Insulation I put inside Contractor sized Garbage bags that I stapled shut. This and th extra heat I am pumping in there off my furnace has raised the temp from 36 deg to above 46 deg this is important because the temp has to be above 40 deg during application so the product cures properly.
Graphite the color that should have been sent, instead of Granite which is waht is what was applied. <_<
Had a couple fish eyes the whole surface will be lightly sanded with 120 sandpaper and a new coat and flecks installed this is the beauty of this product its easy to fix a mistake and it blends in nicely.
Insulated the perimeter with R-30 in garbage bags. :omg:
Added some direct heat in the stable.
Taped off the perimeter and swept the floor like for the 10th time!! :whistle: .
The Floor Temp is above 40 deg Which is the minimum application temp if you look closely you can see the lazer dot 1/2" away from the wall in the corner X marks the spot Where the temp is taken. :lol: .
  • Similar Content
    • Travas
      By Travas
      Hello everone reading this. Im currently in the process of building a race mower out of a front engine 8-32 toro. It was sitting outside for the longest time because of a broken axle. It believe it has a vertiical 8 hp b&s that had running. Here is some some photos of it.  I put a bifferent transaxle in because it was spare one laying around. I put it on and it fits pretty well. Altho i had to remove all the clutch and shifter parts to get it in, but hey it works. I got a wheel on and tried getting the other off the axle it was on. So i put it in the press and tried for about a half hour before in popped loose. After that it took me about 15 mins and got it off. It was really  rusted on there! Put it on the transaxle to how it fits and looks. Now im in the process of drilling a hole the axle for the key in the wheels. Any suggestions or ideas? I will update this project when do some more work on it.
    • mmmmmdonuts
      By mmmmmdonuts
      I have approximately an 10x12 lean to shed attached to my house on the side of my side loading garage. I currently have a double door that is 6' wide by 6x10" high. The problem I am having is the door starting to fall apart. It is also framed very heavily with 2x6s. So I am currently looking to either do another double door or a garage door. Part of the reason the door is getting damaged in the first place is because water pools at the bottom of the door in the winter and freezes and I have to basically heat and or chisel the ice away. It is where I store my snowblower.
      My wife ruled out a sliding barn door and a roll up door mainly for appearance purposes.
      I was starting to lean to a 8w x7h regular garage door but see a few cons.
      1) It would block the light when up.
      2) I would lose quite of bit overhead storage and about 2 feet of wall space.
      3) There would be much more work reframing parts of the wall to fit the door.
      Pros.
      1) I could fit my wheel horse plow and snowblower side by side.
      2) Shouldn't freeze to the concrete as easily with a rubber seal.
      3) Don't have to shovel out the doors to get the snowblower out.
      I was wondering what thoughts you guys had on and if I am missing something.
      Thanks.
    • CasualObserver
      By CasualObserver
      I've been dreaming of a new shop space to work on tractors and generally store things at my house. We already had a three car garage on the house and could only fit one vehicle in it due to the large space that kids toys, bikes, zero turn mower, shelving and a workbench already occupied. Well.. that stuff and a few or so little garden tractors... but they don't take up that much space, right?   Anyway...  we'd been talking about building my dream shop for several years. We live on a large in-town parcel, so there's plenty of room, but as with most things, it comes down to when it can fit in the budget. I drew it up several times on the building designer at Menards dreaming of when we could go forward. Well, in the early 2017 we decided to go ahead with it, and I came up with my final layout plan.
      We proceeded under the option of build the shell, and finish what we can later. We went over and over the list of things to do now and later. Things I wanted that had to be done now for sure were the rough in for the in-floor heat and the attic trusses. I had a contractor friend who would GC and frame it for me if I bought all the materials and he could do it on his own schedule. Yep, done. I figure I could have built it myself, but it would have taken most of the summer of every night and weekend, as well as the headaches of arranging the subs for the stuff I couldn't do, but if he could do it, and he has all the contacts/subs already... I'm money and time ahead to work some extra overtime and avoid the headaches.
      The previous owners of our place had a gravel RV parking next to the house. The old poorly done timber walls were deteriorating and leaning with age.It was convenient for parking the trailer, and nice when the kids were little that we could park off the driveway so they could play, but every year inevitably it was always a weedy mess by mid-summer.
      Step one, remove ugly timber wall.  Lucky for me my neighbor had an chainsaw with a garbage blade on it. He came over and we were able to cut the wall into 12 ft sections that we loaded on the trailer for the dump.
      Next, met with our contractor friend to stake and mark it out. Since part of the goal was to reduce the amount of gravel, the equivalence of one car parking space was being removed and returned to grass on the left edge.
      Then just before the excavator was to start work, the kids and I did a little groundbreaking for the big project.
      Some gravel removed and sand base laid down and compacted.
      Concrete guys laid the forms for me on a Friday night so I could lay the insulation and pex for the in-floor heat.
       Like any kids, the call of the sand pile was irresistible.
      Next day I had help to lay the insulation boards and pex. Might seem silly to see two people carrying these boards that weigh all of 2 lbs each... but notice all the pavers? I'd been hoping for good weather to do the insulation and pex..... what I got was great temperature, bright, sunny......and 25 mph sustained winds with 40-50 mph gusts. So.... two guys to carry each flippin' board and weight it down. Ugh.... made the process much longer.
      Got the pex down, which went very smoothly. Three zones, stapled to the foam board.
      Monday morning I get a call.... inspector won't pass it because there's no pressure test on the pex. Ugh. Nothing about that in our building code, but what am I going to do? Project can't go on without his initials. So... I build a pressure manifold, tie all three zones into one long line and charge it up.  Tues morning, concrete guys are onsite... inspector shows up and says ok.
      By the time I get home from work, I have a new slab.
      Lumber pack shows up the day before the family and I are leaving for a week at the cabin. When I pulled out of driveway, construction was underway. We got a few progress pics through the weeks from various friends.
      And I returned a week later to this.  Totally the best way to build a shop!  I was out of his way, he was out of mine... worked out perfectly.
      I installed the overhead doors, had the electrician come and trench the electric over. Got the gas line roughed in for the boiler as well while the trench was open.
      After that, the excavator came back with the final top dress for final grading.
      We bit the bullet and decided to go with sod right away. Even got the kids to help for a little while. Couple of neighbors (one of whom happens to be a professional landscaper) came over the chip in too, and three pallets later....
      Now we're at slow progress time. I bought all the construction materials on a Menards 11% rebate, so once I got the rebate check I started to finish the interior. Got the vapor barrier up, and ceiling rocked with 12 foot 5/8" type x. 105 lbs each. Ugh. Thank God for drywall lifts, right!?
      More rebate checks allowed for the insulation and rock for the walls.
      Then we came to a complete standstill..... got enough stuff moved out of the house garage to get both the car and truck in for the winter, but with no heat and no ceiling insulation the shop was just a big storage box for winter.
      Spring this year rolled around and prioritizing shop work made it to the list. I realized it's going to be much easier to get the interior done before I move in. So... started back at it. I got the floors masked off and got tape and mud done... then the girls helped me paint.
      Did the floor with Rock Solid polycuramine kits from Menards... grey with flakes and a textured topcoat to make it less slippery if wet. This is a long and multi-stage process. First it required renting a diamond grinder and grinding off the curing sealer. Then powerwashing three times to remove all dust and debris.  The base coat went on, cured for a few days, and topcoated three days later. Then I let that cure for a week before moving in. It's supposed to be cured in 24 hours, but why rush it if not necessary?
      Finally ready to move in.
      Got some used kitchen cabinet take outs and installed them for the workshop area.
      Really looking forward to getting stuff organized and cleaned up now.  It's totally a dream come true. Still have to buy and install the boiler and get the ceiling insulated... but those are things that can be worked around. Up until this point it's been much easier to have minimal stuff in the way.
      If you made it all the way to the bottom, thanks for taking the time to read it.  Get more done, have more fun!!
    • Pullstart
      By Pullstart
      Pretty soon, the tractors will have a place for everything and everything in it’s place!
      We put up another section of racking and it will allow for some custom pallets at 66” long and 44” wide to store tractors 3-wide in the racking.  The closest green upright is 9’ tall, it’ll be a shell for the buggy to rest on top of
