HorseFixer
Started Working In The Horse Stable!
Butch
Dang Duke how the heck did you get such a large collection of hardware, nuts, bolts, fittings etc? Did a hardware store go outa business? Got any PEX fittings? You can't channel the heat from your current workshop to the new addition?
HorseFixer
Duke everything is looking good except for that shirt you have on, that should be in the rag pile :omg:
P.J.
Bitten you must be either a SUCKEYE fan or an IRISH fathead charlie weiss fan! :hide: yeah its tuff pullin for a team that's the winningest team in college football! It'll be a couple years but the WOLVERINES will be back in the running! :D
Tickster what ya talkin about? :omg:
Butch yeah I baught out a bunch of Western Auto's bolts back in 1985 when they went out of buisness plus a bunch of other stuff, couldn't beat the deal! :hide:
HorseFixer
Hang up a few sheets of OSB today, would have hung more but I'm outta sheets. Too damn cold to hook up the horse hauler (was -2 this mornin) not much warmer now :hide: will hafta make a trip to Lowes tomarrow after work I guess. Here are a couple pics.
KyBlue
Hey Duke, Might wanna check with HOme Depot. My Local store has some sheets of 1/2" OSB for 6.00 each.. Might be a bit thicker or thinner than 1/2 but its around there... I wish I had the extra to get the 12 sheets needed for the roof of my workspace..
Progress is lookin good!
HorseFixer
Thanks Scott, :hide: I just called LOWES here in Niles and 1/2 OSB is $ 5.94 a sheet. Isn't it just crazy how OSB is cheaper than 1/2 sheetrock? :D It is $5.96 a sheet! I also have some cupons from there, so I will use them too and get that price down even further! I need about 15 sheets to finish the sheeting up. Then I will need some materials For my Tractor Platform, and Will be putting a 30" wide shelf on the low side 25' long the entire length of the stable which will be for the storage of impliments, mowing decks, engines anything that can be stowed on there. Gotta make every inch count when you have limited space.
Butch
My arms and shoulders hurt just thinking about screwing plywood to the ceiling.
KyBlue
Ah well... least your gettin a good price too! (not a fan of lOwes)
HorseFixer
Butch yeah tell me about it!! <_< If ya look closely at the pics ya can see I was useing blocks O wood to help me with that. Up high I used a 2X4 screwed to the wall spaced down about 3/4" then I slid the sheet in there and drove a screw in the bottom of the sheet. I then put a spacer and a small block over the first sheet at the bottom removed the screw at the bottom and tapped it in place once I got er where I wanted I socked the screws to it! :hide: No matter what yer doing its not easy when yer a one man band! :hide: One thing for sure, Im getting to Old for this chit! :D
big mike
Yes,Yellow and White Big Mike(with a smathering of Red) from the clean side of town :hide:
HorseFixer
Yes,Yellow and White Big Mike(with a smathering of Red) from the clean side of town :D
You need to give me all the Red Ones! Cause they need to be with ONLY their own kind! :hide: ya still needin a Tranny?
whfan74
Duke I love the shirt and have plenty of the maize in blue in my house. One room is completely dedicated to the winningnest program in the history of college football!
Stay faithful.....things will be turning around quickly! The old sweater down south is looking over his shoulder. He knows what is coming! I can't wait to sit down and :hide: it will be fun!
HorseFixer
Thanks Scott had the pleasure in having dinner with Loyd Carr in 1998, Have pictures of me and Anthony Thomas the "A" Train before he ever played a down at Michigan. Have a Michigan room myself with TONS of stuff. Met BO years ago and got his autograph, and met and had a good time with John Jansen at a friend of mines Daughters wedding and he brought me by a signed "REAL MCCOY" autographed Michigan helmet the next day :hide: Yep I wont give up! :D
HorseFixer
Had a pretty good day in the stable today, got 9 more sheeth hung, Will finsish the south end wall tomarrow and then will get everything moved out of there give it a good cleanup and will give it a good paint job sunday or monday. Heres some pics.
glenn27
Looking good there--Duke... :hide:
HorseFixer
Thanks Glen!
Well I got after it pretty good the past couple days, got everything sheeted and cleaned up and I am ready for paint! :hide: I will give everything a second vac and have a few stray screws and a piece if f channel to remove and then I will slap some paint on. The paint will be white and the trim will be red. :D
Suburban 550
Lookin' real good Duke. :hide: Won't be long before you're ready to move in.
HorseFixer
Thanks Ray!
Well past couple days started doing some painting in the stable, Cut in all the edges and then applied the first primer coat. Will be putting on the top coat tomarrow.
KyBlue
Its always amazing how much paint brightens a space aint it???
HorseFixer
Yeah it does Scott but I dulled it out a little bit but for good reason! Linen Beige is the paint that was used for all practical purposes! :D I know one guy that will be happy that I used that color! :hide: Well now that the color coat is on its time to hand some fluorescent lights and give it some real light in there! I guess I will also work and get the wall outlets fired up So's I ca quit screwing with extension cords! <_< The next thing after all wiring is done will be to paint the Block and the bottom plate WH RED there will also be 1 X 3 red trim that will be along the edges of the walls & ceiling that should pull it all together. I will then start on the platform & shelving that will run the entire length of the low side that will be 30" wide and a foot down this is where I will store all my decks & small implements that will fit on there. All shelving & the platform will be trimmed in red and will have grass carpet on them.
Duff
Yeah it does Scott but I dulled it out a little bit but for good reason! Linen Beige is the paint that was used for all practical purposes! :hide: I know one guy that will be happy that I used that color! :D Well now that the color coat is on its time to hand some fluorescent lights and give it some real light in there! I guess I will also work and get the wall outlets fired up So's I ca quit screwing with extension cords! <_< The next thing after all wiring is done will be to paint the Block and the bottom plate WH RED there will also be 1 X 3 red trim that will be along the edges of the walls & ceiling that should pull it all together. I will then start on the platform & shelving that will run the entire length of the low side that will be 30" wide and a foot down this is where I will store all my decks & small implements that will fit on there. All shelving & the platform will be trimmed in red and will have grass carpet on them.
Duke, I only got one thing to say to you: you are a Class Act my man! A Class Act! :hide:
Duff :omg:
linen beige
You rang? :horseplay:
HorseFixer
Hung & wired the lights up in the horse stable today WOW what a difference they make! :banana: I use the 6500K daylight bulbs.
Used plastic tube protectors over the bulbs. :D
And The Duke Said Let There Be Light And There Was Light! :hide:
linen beige
Not being critical, just curious. Why not turn those fixtures 90 degrees to spread out the light a little and make fewer shadows?
HorseFixer
Jim the camera doesn't do it justice. :hide: Look at the floor and walls there are no shadows down below. Ya also hafta know my shelving and platform arrangement. :D After that is installed I am sure there will be some shadows. Picture this the platform will be approx 42" tall and will be 6' 6" wide by 15 foot long and will be about from the right hand outet boxes all the way to the doorway and will support 6 round hoods. below the platform will be another 6 round hoods. On the low wall picture this there will be a shelf 12" down from the ceiling will be a 30" wide and will run the entire length longways of the building. Below that shelf will be 3 tractors along that wall. The shelf will be for decks storage and other impliments & engines & so forth. There will be a 30" Isle between the platform and shelf and thats where the lights are running down through there. I tryed to space the lights the best I could to maximize the lighting. I may have to install a couple more in areas as needed but if you seen it in person there really are no shadows as much as you may see in the picture. :hide: The Room looks pretty big now but once it is packed full of ponies it will get packed and small in a hurry! :omg:
HorseFixer
Duff :omg:
Thanks Duffer! :D
Well I told the guy at Sherwin Williams when he mixed the BONDING PRIMER to make it as close to the WH RED as possible! :party: :wtf: YIKES!!! :hide: I don't want to hear any cracks from you guys it's not my fault!! When I cracked that can open this morning and looked inside I just about chit myself! :party: Well damn good thing its gonna get covered up REAL QUICK cause I don't want this stuff around for the wife to See cause she might like it! :D Anyways have more trim to prime tonight most likely will pull a late shift and tomorrow you will see WH RED!
  • Similar Content
    • Travas
      By Travas
      Hello everone reading this. Im currently in the process of building a race mower out of a front engine 8-32 toro. It was sitting outside for the longest time because of a broken axle. It believe it has a vertiical 8 hp b&s that had running. Here is some some photos of it.  I put a bifferent transaxle in because it was spare one laying around. I put it on and it fits pretty well. Altho i had to remove all the clutch and shifter parts to get it in, but hey it works. I got a wheel on and tried getting the other off the axle it was on. So i put it in the press and tried for about a half hour before in popped loose. After that it took me about 15 mins and got it off. It was really  rusted on there! Put it on the transaxle to how it fits and looks. Now im in the process of drilling a hole the axle for the key in the wheels. Any suggestions or ideas? I will update this project when do some more work on it.
    • mmmmmdonuts
      By mmmmmdonuts
      I have approximately an 10x12 lean to shed attached to my house on the side of my side loading garage. I currently have a double door that is 6' wide by 6x10" high. The problem I am having is the door starting to fall apart. It is also framed very heavily with 2x6s. So I am currently looking to either do another double door or a garage door. Part of the reason the door is getting damaged in the first place is because water pools at the bottom of the door in the winter and freezes and I have to basically heat and or chisel the ice away. It is where I store my snowblower.
      My wife ruled out a sliding barn door and a roll up door mainly for appearance purposes.
      I was starting to lean to a 8w x7h regular garage door but see a few cons.
      1) It would block the light when up.
      2) I would lose quite of bit overhead storage and about 2 feet of wall space.
      3) There would be much more work reframing parts of the wall to fit the door.
      Pros.
      1) I could fit my wheel horse plow and snowblower side by side.
      2) Shouldn't freeze to the concrete as easily with a rubber seal.
      3) Don't have to shovel out the doors to get the snowblower out.
      I was wondering what thoughts you guys had on and if I am missing something.
      Thanks.
    • CasualObserver
      By CasualObserver
      I've been dreaming of a new shop space to work on tractors and generally store things at my house. We already had a three car garage on the house and could only fit one vehicle in it due to the large space that kids toys, bikes, zero turn mower, shelving and a workbench already occupied. Well.. that stuff and a few or so little garden tractors... but they don't take up that much space, right?   Anyway...  we'd been talking about building my dream shop for several years. We live on a large in-town parcel, so there's plenty of room, but as with most things, it comes down to when it can fit in the budget. I drew it up several times on the building designer at Menards dreaming of when we could go forward. Well, in the early 2017 we decided to go ahead with it, and I came up with my final layout plan.
      We proceeded under the option of build the shell, and finish what we can later. We went over and over the list of things to do now and later. Things I wanted that had to be done now for sure were the rough in for the in-floor heat and the attic trusses. I had a contractor friend who would GC and frame it for me if I bought all the materials and he could do it on his own schedule. Yep, done. I figure I could have built it myself, but it would have taken most of the summer of every night and weekend, as well as the headaches of arranging the subs for the stuff I couldn't do, but if he could do it, and he has all the contacts/subs already... I'm money and time ahead to work some extra overtime and avoid the headaches.
      The previous owners of our place had a gravel RV parking next to the house. The old poorly done timber walls were deteriorating and leaning with age.It was convenient for parking the trailer, and nice when the kids were little that we could park off the driveway so they could play, but every year inevitably it was always a weedy mess by mid-summer.
      Step one, remove ugly timber wall.  Lucky for me my neighbor had an chainsaw with a garbage blade on it. He came over and we were able to cut the wall into 12 ft sections that we loaded on the trailer for the dump.
      Next, met with our contractor friend to stake and mark it out. Since part of the goal was to reduce the amount of gravel, the equivalence of one car parking space was being removed and returned to grass on the left edge.
      Then just before the excavator was to start work, the kids and I did a little groundbreaking for the big project.
      Some gravel removed and sand base laid down and compacted.
      Concrete guys laid the forms for me on a Friday night so I could lay the insulation and pex for the in-floor heat.
       Like any kids, the call of the sand pile was irresistible.
      Next day I had help to lay the insulation boards and pex. Might seem silly to see two people carrying these boards that weigh all of 2 lbs each... but notice all the pavers? I'd been hoping for good weather to do the insulation and pex..... what I got was great temperature, bright, sunny......and 25 mph sustained winds with 40-50 mph gusts. So.... two guys to carry each flippin' board and weight it down. Ugh.... made the process much longer.
      Got the pex down, which went very smoothly. Three zones, stapled to the foam board.
      Monday morning I get a call.... inspector won't pass it because there's no pressure test on the pex. Ugh. Nothing about that in our building code, but what am I going to do? Project can't go on without his initials. So... I build a pressure manifold, tie all three zones into one long line and charge it up.  Tues morning, concrete guys are onsite... inspector shows up and says ok.
      By the time I get home from work, I have a new slab.
      Lumber pack shows up the day before the family and I are leaving for a week at the cabin. When I pulled out of driveway, construction was underway. We got a few progress pics through the weeks from various friends.
      And I returned a week later to this.  Totally the best way to build a shop!  I was out of his way, he was out of mine... worked out perfectly.
      I installed the overhead doors, had the electrician come and trench the electric over. Got the gas line roughed in for the boiler as well while the trench was open.
      After that, the excavator came back with the final top dress for final grading.
      We bit the bullet and decided to go with sod right away. Even got the kids to help for a little while. Couple of neighbors (one of whom happens to be a professional landscaper) came over the chip in too, and three pallets later....
      Now we're at slow progress time. I bought all the construction materials on a Menards 11% rebate, so once I got the rebate check I started to finish the interior. Got the vapor barrier up, and ceiling rocked with 12 foot 5/8" type x. 105 lbs each. Ugh. Thank God for drywall lifts, right!?
      More rebate checks allowed for the insulation and rock for the walls.
      Then we came to a complete standstill..... got enough stuff moved out of the house garage to get both the car and truck in for the winter, but with no heat and no ceiling insulation the shop was just a big storage box for winter.
      Spring this year rolled around and prioritizing shop work made it to the list. I realized it's going to be much easier to get the interior done before I move in. So... started back at it. I got the floors masked off and got tape and mud done... then the girls helped me paint.
      Did the floor with Rock Solid polycuramine kits from Menards... grey with flakes and a textured topcoat to make it less slippery if wet. This is a long and multi-stage process. First it required renting a diamond grinder and grinding off the curing sealer. Then powerwashing three times to remove all dust and debris.  The base coat went on, cured for a few days, and topcoated three days later. Then I let that cure for a week before moving in. It's supposed to be cured in 24 hours, but why rush it if not necessary?
      Finally ready to move in.
      Got some used kitchen cabinet take outs and installed them for the workshop area.
      Really looking forward to getting stuff organized and cleaned up now.  It's totally a dream come true. Still have to buy and install the boiler and get the ceiling insulated... but those are things that can be worked around. Up until this point it's been much easier to have minimal stuff in the way.
      If you made it all the way to the bottom, thanks for taking the time to read it.  Get more done, have more fun!!
    • Pullstart
      By Pullstart
      Pretty soon, the tractors will have a place for everything and everything in it’s place!
      We put up another section of racking and it will allow for some custom pallets at 66” long and 44” wide to store tractors 3-wide in the racking.  The closest green upright is 9’ tall, it’ll be a shell for the buggy to rest on top of
