andrewLL
Rotavator / Tiller spring
andrewLL
Hi, hoping that someone may be able to tell me what size spring I need for tensioning the drive belt on a tiller (length and diameter).  I have recently purchased a tiller on fleabay which appears to have hardly been used as so much paint is still on the tines.  The only part missing is the small spring that attaches to the idler pully and tensions the belt.  The instructions are dated 1994 and the model is 79370 and I hope it will fit on to my 72 Raider.
The other potential problem that I have is I am unable to remove the bar holding the tow hitch on.  I have hit it as hard as I dare but don't want to risk cracking the transmission casing, all I can do is spray it with WD40 every so often and hope it eventually releases.  Do you think it would seriously weaken the tiller if I cut out the diagonal bracing bar so I could fit it with the tow hitch in position.
Any advice would be appreciated.
Andrew
cleat
I am trying to understand your problem.
Are you taking about the rod with the large washers welded on the end that is in the front of the tiller framework ?
If so, that is welded in.
As for the spring, I would have to go out and measure mine.
gwest_ca
The part number 6135 spring
3-5/16" between hooks
coil 5/8" diameter 2-3/8" long
 34 coils of .070" wire
Garry
andrewLL
Cleat
thanks for the reply and sorry for not explaining the problem very well.  The bracing bar I am referring to runs diagonally from below the small pulley wheel forward towards the rod that you referred to on the opposite side.  I assume that it is to help stop the frame flexing and twisting.  But with this in place it would foul on the tow hitch which runs down the centre line of the tiller.  So could not raise and lower the tiller.
Has that made the problem any clearer?
all th best
Andrew
Ed Kennell
There are many posts on removal of these hitch pins.
JAinVA
andrewLL,
    Ed gave you a source of much info on removing the hitch pin.If you are concerned about maybe breaking the rear of the transmissionyou could remove the diagonal brace on the tiller.The mounting setup on the tiller should be able to stand up to any stress caused by the tiller without this brace..I would cut it off and keep it.It could be reattached when you get the hitch off.You will love this tiller.I know I love mine.JAinVa
Edited by JAinVA
cleat
I had one seriously stuck in a machine as well.
I ended up cutting it flush to the transmission casing, removing a rear wheel, and pounding the pin out with a large hammer and a length of rod just smaller diameter than the hitch pin itself.
You can make up a new pin or just buy a hitch pin at TSC.
Jacksback
I know this is an old thread but I have a chance to get a WH tiller will
it attach to my WH 227-5 . I think it only has the brackets attached to the tiller not the one to the left , the plate and the one above the belts in the pic. So would it be worth getting and has anyone got any pics of it attached to a WD
andrewLL
Hopefully someone can confirm it will fit a 227-5 tractor, mine is a Raider.  You asked about buying it with out all the parts needed to fit it, over here in the UK I would not gamble on being able to find all the other parts.  But they may be more easily found where you are. I’m sure others will have suggestions. All the best, Andrew.
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • oliver2-44
      By oliver2-44
      Anyone have any Troy Bilt  Pony Tiller Gear Box Experience?
      So about a year ago an older neighbor gave me this Troy Bilt Pony Rear Tine tiller.  Said he forgot he drained the engine oil and started it.  Bore diameter was actually good, but has a bunch of large vertical scars on cylinder walls.
      Fast forward, my wife has volunteered us to help a Youth Summer Camp that runs an  "Outdoor School" during the 9mth  school year.  They had a fairly large garden for several years, but it has been neglected & overgrown for a couple of years.  So she drives past this neglected garden daily!
      There's some scheme emerging where we have half the garden to ourselves and help with the other half where students will plant and weed and pick their produce.  I enjoy a garden, but not real keen on some of the aspects on this one...( a bunch of 6" high raised beds with paths to narrow for my big feet to turn sideways. But I've already been committed, O I mean volunteered.
      So engine is shot (aluminum block)  but I have a Predator or a K181 I could put on it.
      The wheel shaft seals looked shot and had a bunch of play so brass wheel bushings were shot. (the other 2 shafts have tapered roller bearings).
      No model number, but from the "Pxxxxx" serial number and Briggs engine I've dated it to a 1981.
      MTD now owns Troy Bilt and their "on-line manuals" go back to 2000.  Called their Tech Supports and got "Deer in the Headlite" comments regarding a 1981 Service Manual.
      Searched online and founds lots more info on the larger "Horse" model, and a 1991  Pony service manual.
      While they basically look the same, there's been several generations of re-engineering the internals to simplify manufacturing and eliminate castings it appears.
      I found this parts diagram to be the close's match to what I have.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/wheel-tiller-shaft-assemblies-7/
      I disassembled it and I think I marked everything as to what faced the front, back or R,L side.  Internals looked OK, but the wheel shaft seal area is not the greatest.
      Most parts are NLA but found bearing. seals & bushings on ebay. $130
      Reassembled everything and used the 1991 Service Manual as a "Guide" to shimming the 3 shafts end play.
      Everything turn freely in both directions when in neutral. But when I engage the Wheel Shaft "Clutch" it binds up. The clutch lets the wheels roll freely or engages them to power.  It uses belt idlers to reverse direction from a second shaft on the briggs (like a walk behind snow blower drive)
      photo from phone here
      This internal clutch actually works by using a pawl disc which is keyed to the shaft to engage the wheel
      shaft gear which is free wheeling on the shaft.
      I've loosened the bolt on the bearing end caps slightly and no change.
      This uses worm gears and I know "some" worm gears are designed where they must be "power driven"  in each direction (My boat lift is like this)
      So the rear tine gear shaft turn freely in each direction.
      The wheel shaft locks up when the clutch is engaged amd trying to turn it in what would be the forward direction.  But it will turn freely with the clutch engaged if going in the backwards direction.
      The wheel shaft gear cannot be turned backwards because of the clutch mechanism on the one side.
      The rear tine shaft bevel gear turn freely in both direction in neutral but is bound up when the clutch on the wheel shaft is engaged.??
      There is a Main Drive Shaft that has the Worm Gears on it to drive the Wheel Gear and a second worm to drive the Tines Gear.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/main-drive-shaft-gear-assemblies-4/
      This shaft is made up of a smooth shaft with the worms keyed to it and spacers in between them.  I disassembled it (and carefully laid out each piece in order) to wire brush everything clean on the grinder as there was some rust from water in the very bottom of the gearbox.
      I find it hard to believe that I could have one of the worms backwards because it seems it would not turn freely when the wheel clutch is not engaged??
      To remove it I have to disassemble everything and might ruin my seals as I have to drive them out. (dumb me, I tested everything to turn freely before I installed the seals, BUT I didn't engage the clutch)
      Just a note,, I didn't try to turn everything with the "clutch engaged" "Before" I disassembled it so I don't know how hard it should turn, but it had to turn via a belt drive verse's now totally locking up.
      Regrettable a nonworking tiller doesn't get me out being volunteered.
      Did I say I actually enjoy a garden!
      Thanks for any suggestions and listening to my rant.
      This is the input shaft from belt pulley
      Special woodruff key
      Tiller Tine Shaft
      Some one was in here before me. These are threaded holes with removable set screws to drive the bearing cone out. No set screws just filled with caulk or body putty.
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
    • wh315-8
      By wh315-8
      My 50” D-series tiller input shaft has like 3/16” +\-, play pulling in or out. Anyone else have this same thing. Is it supposed to have that much play? Have it all apart and was thinking of adding a shim or 2nd thrust bearing to lessen the play to at least 1/16”.
