Raider 9 Project
By
M1N1ON, in Restorations, Modifications, & Customizations
Similar Content
By Donavon1
Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
By Redtickuleez
Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
By sjoemie himself
You know those people that have too many projects?? Yeah me neither!
Another tractor added to the heard. Case International 585 with canopy/sunroof.
It's a 60-ish horsepower tractor with very limited electronic gimmicks. Has a nice tight turning radius. It was built in Doncaster from 1985 to 1990 and the hourmeter says it has ran 4700 hours since then, I'll take that with a grain of salt though.
Plan is to use it for all kinds of jobs around the house and barn/stable for my gf's horses.
Ofcourse it is not a new machine so there are things that will need looking after but all the basics are there.
Pictures you say? Sure!
By Aaron Coffman
Hi Red Square Community,
I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
By Joe Reese
Wheelhorse Snow blower Fits c100's 500's etc. with a front mule setup. Works. Comes with lift Flag & Lift spring relief. Also have a set of rear tire chains for additional - $50
Have a set of custom exctra heavy rear wheel weights if interested as well. $75
Snow Blower Only, Tractor Not For Sale.
