ztnoo
Kohler K Engine Weights?
ztnoo
Does any one know of a reference link to finding the weight of complete Kohler engines, in particular the K321 & K341?
If you know of no electronic data about this topic, but have one of these on the bench and complete, could you somehow weigh it for the benefit of group knowledge.
(Sneak the bath scales out to the garage if you can).  :ROTF:
I'd actually like to see a listing of weights for the entire Kohler K series, if anyone can contribute any piece of this puzzle.
Regards,
Steve
Aldon
I know that the K321 and K341 are freakin HEAVY
  • Haha 1
ztnoo
Well, I know you're right, even though I've not had mine out of the frame.
If we can learn the weight of a K321 and K341, it would be a big help to Dell to know how much weight to add up front after his Predator repower.
Somebody out there has to know........
oldredrider
I believe it's in the neighborhood of 125#.
  • Like 3
bds1984
Well I thought that you could just download the K-series manual from Kohler's website but the weight isn't indicated there, but, if you download the manual for an M16, I am sure that'll get you in the ballpark. Kohler says that an M16 tips the scales at 129lbs.  Having had my K341 out of the frame from my C165, I can attest to the weight of it and probably then some.  To put it lightly, ANY large Kohler, whether it be K or M series, is HEAVY!  Especially if it is lifted sans helping hands or engine hoist!
  • Like 4
19richie66
Kohler shows in their engine manual "approx.118 pounds for the K-241, K-301,K-321. The K-341 is 122 pounds".
  • Like 5
ztnoo
19richie66,
Which specific Kohler manual are you referring to???
I couldn't find it in anything I've looked through.......all kinds of engine specs and fastener torque ratings, but no weights.
That's going to be real help info for Dell in his GT 14 repower project and reweighting his front end after swapping the Kohler for a Predator and pulling the 6 gallons gas tank out.
:greetings-clappingyellow:
If anyone has info on the other Kohler K engines not listed, please jump in here.
Regards,
Steve
Wishin4a416
I switched out a Kohler M10 for a Predator 212 and added 75 lbs in weight up front. Looks like I am close.
dells68
Yup, definitely goi g to need some weight up there.  This explains why I almost got a hernia lifting the k321 in the other tractor by myself!!!   I could tell just carrying the predator around that I'd lost a bunch of weight!
bobert94
I tryed to lift out the k482 out of the 18 automatic. kept looking for the bolt i must have missed, no all bolts were out. getting old is not for sissy's !!
ztnoo
That's EXACTLY what my urologist tells me.
I guess I'm a convert to that theory, as I have no logical argument to refute his premise.
C'est la vie..........
Edited by ztnoo
19richie66
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
service manual
http://www.kohlerengines.com/onlinecatalog/pdf/tp_1346_c_all.pdf
owners manual
for other engines, pick your engine type, horsepower and shaft from the drop downs and you are good to go.
http://www.kohlerengines.com/manuals/landing.htm
ztnoo
19richie66,
Thanks again, that's very informative and helpful.
I haven't located any weight info on the K141 or K160 yet.
So here's what the specs say:
K91 (4hp) = 43 lbs
K141 (6.25hp) =
K160 (6.6hp) =
K161 (7hp) = 65 lbs
K181 (8hp) = 65 lbs.
K241 (10hp) = 118 lbs.
K301 (12hp) = 118 lbs.
K321 (14hp) = 118 lbs.
K341 (16hp) = 122 lbs.
Edited by ztnoo
pacer
Are those specs with starter, muffler/exhaust, carb, etc or?
ztnoo
I would assume complete, ready to run engines since the info is take directly from official Kohler documents, but I have no way to verify my assumption
Edited by ztnoo
19richie66
I would imagine the K-141 probably would also be close to 65 lbs, because arent the blocks the same?
ztnoo
That's probably a reasonable assumption given the K141 is grouped together with the K160/K161 here:
http://www.gardentractorpullingtips.com/engspecs.htm#torques
But if anyone has any definitive information from Kohler literature about the official weight, please provide a link for the rest of us.
squonk
I had to pull the K341 out of my Power King to change the hyd belt. I borrowed an engine crane. Poeple looked at me like I was nuts! :rolleyes: :)
953 nut
Mike, aren't you accustomed to that by now?         :ychain:
Maxwell-8
A k582 weigs in @ 187lbs
Maxwell-8
So I will edit the list:
K91 (4hp) = 43 lbs
K141 (6.25hp) = 63lbs.
K160 (6.6hp) = 63lbs.
K161 (7hp) = 65 lbs.
K582 (23hp) = 187 lbs.
KT17 (17hp) = 118 lbs.
KT19 (19hp) = 121lbs.
KT21 (21hp) = 124 lbs.
  • Similar Content
    • Maxwell-8
      By Maxwell-8
      So yesterday I picked-up a C175. She was rusting away as she was stored outside. She had a new to her Kohler K341. @squonk The previous owner indeed better had"LET AN ELECTRICIAN      CHECK his  SHORTS!"  as bad wiring shorted the battery out, and exploded/melted. She has a Sundstrand hydro pump with a Filter, is that normal? By the pump I believe it's a 1980. But you never now for sure as it's made in Oevel. Due to the bad wiring, the engine was in no running condition. But don't think the K341 has many hours on it. The hydro I don't know if it works. She was hard to push. So i lift up one wheel, so we could roll here one one wheel and the diff prevented the trans from locking up.
      So first things to do:
      1) get the engine running
      2) replace the steering wheel, but don't think removing it will be very hard as it's already split in two.
      3) replace the axleseals, the oil leak caused a lot of sandbuild up as she was mainly used on for leveling out a horse track.
      4) clean all the acid and remove all the old wiring to do a full rewiring
      5) replace the plastic seat pan with a metal.
      6)...
      I'm looking forward on my first C.
      It's also my first hydro, I don't know a lot about them and prefer actual gears. Simpler and need less maintenance (parts-shortage).
      But since I couldn't find another project WH and me hearing a lot of good things about hydro's  on the forum..  I finally took the shot.
    • Bill D
      By Bill D
      I bought this K341 and was wondering what it came on originally.  It's a 13 fin block and has been bored .020 over already.  It has a Kohler carb which may not be original.  Bill
    • RJ Hamner
      By RJ Hamner
      Rebuilding a C160. everything worked prior to rebuild
      Engine was fairly high time so machined .020 over and rebuilt
      Finished rewiring and made sure all the circuits were in order
      Starter would spin the engine. Made new coil wire and installed new spark plug
      Starter won't turn the engine. Tried several times with and without spark plug Same results
      Starter was what I took off the tractor prior to rebuild but can't say it is orininal
      So.......Am I missing something or is a new starter going to be the answer?????
      Thoughts?  Ideas?
      All help/input appreciated
      BTW:  Don't know if it means anything but the gear does not retract when key is moved back to ON
      Bob
    • RJ Hamner
      By RJ Hamner
      I was breaking down the engine getting it ready to go to the machine shop. Everything was pretty normal until it tried to remove the PTO race and the engine pulley.  As I was setting up the "puller" I noticed the end of the crankshaft looked different but never gave it much thought.  After a half a can of PB Blaster,destroying the engine pulley and turning the air in the shop blue I was able to get the crankshaft free.  There was a LOT of baked on crud and grease and I thought that was the problem.  Cleaned everything up and found the race would not slide on the crankshaft???  Got out the measuring tools and found the answer.  The end of the crankshaft was expanded will past the 1.125".
      I had another crankshaft so I looked at the PTO end.  It almost looks like someone bored the end and inserted some kind of tapered shaft and/or beat the heck out of the end and swelled the last 1/2"-3/4" of the crankshaft.
      Can anyone think of a reason???
    • Machineguy
      By Machineguy
      Hello everyone!
      I finally picked up a Workhorse 700 and I’m doing a restoration with the exception of a Kohler K321 in place of the scavenged Tecumseh. Anyone done a similar swap and had trans issues or breakage problems? This isn’t going to be a puller, just gonna keep a 42” snow blade on it  for small snows and use it for light duty towing and putting around. I have the engine sitting around from another repower project and I have access to a large variety of machine tools and fabricating equipment. Any thoughts?
