ZRB0415
Compatible 30 inch blade 211-5sb
ZRB0415
It took me forever and a year but last spring i found something that fits perfectly. Had to measure the 3 hole separation, but found snapper occasionally uses a blade of the same spec. Readily available online although i have forgotten the site.
gwest_ca
The 111144 original blade has been replaced by 112560 and still available from Toro.
https://www.partstree.com/parts/toro/parts/112560/
Mower deck?
Garry
ZRB0415
Thats usually not in stock, i looked when i bought the blade i now have.
https://www.oregonpartsstore.com/96-630.html
I can mow anything with ease. $25.43 for a gator blade. i'll buy two more and toro can can stuff it for charging that for a blade.
On another topic, does anyone know of a good carb that will fit the 11hp b&s that would make more hp? I would like to get up to 13-15 if possible
Willhaven
That fit your 211-5SB? I have the same one.
  • Similar Content
    • wheeledhorseman
      By wheeledhorseman
      Operator manual #810296R1
      4 pages 848.00KB
      2 pages 171.30KB
      Fits
      1983 B-Series and LT-Series See Product Service bulletin
      1984 B-Series and LT-Series
      1985-1986 200-Series
      For vertical shaft 200 series models 1985 onwards but was also used with 1979-80 B series models (supplied with different lift rod) Fits for example B-165 or 216-5.
      Dozer 1983 42in model 06-42BB02 Complete
      1983 serial numbers that have shown up for the 06-42BB02
      19345
      20452 - Build date 1983 3259 September 16 Friday
      20551 - Build date 1983 3259 September 16 Friday [259] Guess
      Dozer 1984 42in model 06-42BB02 Complete
      1984 serial numbers that have shown up for the 06-42BB02
      23294 - Build date 1984 4193 July 12 Thursday
      Dozer 1985 42in model 06-42BB02 Complete
      Dozer 1986 42in model 06-42BB02 Complete
      Link to service bulletin
      http://www.wheelhorseforum.com/files/file/469-wh61-90-315-snow-equipment-1982pdf/
    • Willhaven
      By Willhaven
      Does anyone know if you can make a 211-5 Single Blade (30”) a mulched or side discharge? I only have the bagging system but would like to mulch (if possible) with my new Oregon Gator Blade.
    • Willhaven
      By Willhaven
      Has anyone tried adding/installing deck wheels to a WH 211-5SB? If so, is there a specific make/model that would work best on this tractor? My lawn doesn't have the most level of surfaces, so adding wheels will save me from multiple scalpings (I think).
    • Willhaven
      By Willhaven
      Trying to find the part numbers for my 1989 211-5SB air filter and gas filter. I was able to find the old part number for the mower blade (111144) which I cross-referenced with the Toro replacement but can't find filter info.
      Thanks!
    • Willhaven
      By Willhaven
      My second post here, and apologies for a potentially amateur question. I've had my WH for a couple of weeks now and am looking for a manual, video, and/or someone's help here on how to remove the deck. I need to confirm the size of the blade (and replace it!)
      Thanks!
