KyleHorse
mule drive
KyleHorse
is the mule drive on a 520h and 461h  the same part number##    one is  60" deck and the other is a 44"????
Tankman
Couldn't say for sure but, all my mule drives the same size.
Let's wait on the forum Horse mule drive pro's. :think:
rokon
From what I understand, the 60 inch deck requires a specific spring tensioned or spring loaded mule drive.
Tankman
Thanks daveoman1966. Been a long time since I've seen a 60" deck. :think:
daveoman1966
I have a 60" deck to sell...good shape too.  I will (probably) put it on here is the CLASSIFIEDS and / or on CL.
  • Like 3
KyleHorse
On April 7, 2016 at 5:13 PM, daveoman1966 said:
They are different and not readily interchangeable....see these pics.
Big difference.  Thanks for the pics.
Hurley1
Does anyone know where I can get a spring loaded mule drive for my wheelhorse 520h with a 60” deck?
c-series don
Okay so what is the deal with the spring? I have been running a 60" deck on my 416-H for years with a standard mule drive. I only recently had to replace the belt.
Hurley1
Really...I just found this out myself. I do have a 60” deck on my 520h with the standard mule drive. The trouble I am having is I’m replacing PTO to deck belt every year. I can’t seem to get the mule drive adjusted just right. If I can show these pics you will see the issue I’m having. I start with a new belt. Mule bolt all the way in. I took the deck off to replace the bearings and reinstalled the deck. Now...with not much wear on the belt. I have to adjust the mule drive bolt all the way out to get the 1/2” play in the belt. I thought it may be the wrong mule drive for a 60” deck. What am I doing wrong?
daveoman1966
Qs...Do you have the right PTO to deck drive belt.
This belt MUST be on the INNER V of the PTO pulley...NOT the outer V.
Hurley1
It is the right belt part number 114895. And it is in the inner V of the PTO.
My issue is the mule drive adjustment bolt. It is almost adjusted out of the pinion nut. Is there a correct  procedure for install and adjustment?
lynnmor
I think that you said the mule drive is the one for all other decks than the 60", is that correct?  If you do not have the spring loaded mule drive, you will need to come up with a belt that will fit.  Even then, I would expect clearance problems and short belt life.
daveoman1966
Belt 114895 is the engine to trans drive belt...
The deck drive belt should be # 113072... Length is 103"  .. schematic here
Image?arik=dT3IVkQGAhCRF9guJWtb&arib=TO&arim=CLAJCe7Ijn44T7YyjUFHSA2&aria=clShfOjq_Uj1JCqrs4FN8A2&ariz=2&ariv=http%3A%2F%2Fwww.psep1.biz%2Farinet.asp%3Faribrand%3DTO
Edited by daveoman1966
peter lena
i think part of the issue is the forward angle setting on the drive, looking at the # 10 pictures, you are at the end of your adjustment threading. also note the 45% lower forward angle of the mule drive, both of these issues effect the stability of the drive belt. years ago I went to a shorter belt, 1" to 2" will put you right on the sweet spot for adjustment and level/ square drive mounting. I went to a local  (  bearing distributor  )  that has belts and bearings and sized up a shorter belt, against the used belt. Problem went away, and my drive sits square on the frame hitch point. the speed and angle vibration / lack of stability  is probably the cause, when you are in the center of your dial thread adjustment , you are at the strong point of the mule. I tag all my belts with info , so I always have a spare . take your belt to a local supplier and size up a shorter belt, try it on, (  without running it  ) and verify your change, they can zero in on your exact length. Pete
BESTDOGEVER
I agree with that what I have seen is the pulleys have worn enough to need a slightly shorter belt to keep everything tight
daveoman1966
Belt 114895 is NOT the correct belt as it is only 83" long and is for the TRANSMISSION drive belt.
The DECK DRIVE BELT is number 113072 and it is 103" in length.
Get the right belt # 113072 and I bet your problems will be solved.
dcrage
I know from my 310-8 37"SD mowing combination that when you adjust the tension all the way out as you have that you are quite probably rubbing the back of the belt on the metal cover for the mule drive pulleys -- And that doesn't last too long -- That is a different angle than the whole thing was designed to operate at -- I think you will have to get the custom shorter belt prescribed by Peter or get the correct 60" mule drive with the correct 60" belt
Hurley1
Thanks guys. I guess I’ll try a shorter belt. Anyone know where I could possiable get a spring loaded mule drive?
Frank The Tank
I've been searching for the answer to this question as well. I have been scouring eBay, Craigslist, and forums alike. It seems these mule drives are rarer than gold.
Edited by Frank The Tank
Hurley1
Ok guys. I’ve tried a slightly shorter belt for the 60” deck on my 520. I did get my adjustment right. But after a couple times of mowing the belt stretches and wears and  ultimately breaks. Any suggestions?I’m still looking for the  correct  Spring loaded mule drive. So if you guys may have one you’d sale or may know who might...PLEASE LET ME KNOW.😬
Pullstart
What brand belt are you using?
ebinmaine
Try Lincoln at A to Z
Or
Seeing you're in WV... Maybe @WVHillbilly520H Jeff has a local parts source?
WVHillbilly520H
Like above try A-Z tractors here in our vendors section, also eBay, Good luck.
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
