Similar Content
By jmack
What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
Just shredded mine today.
By gfullz
Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
By kurm
You can search for the specs but here are some links:
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en
https://lookup3.toro.com/partdex/modlinfo.cfm?xCaller=Toro&o=2&x=22004&b=9900001&e=9999999&m=73552&y=1999&n=523Dxi Garden Tractor&channel=CN
https://lookup3.toro.com/partdex/modlatch.cfm?xCaller=Toro&x=22004
This is a beast! Comes with the 60" deck and also a 48" deck and a new battery. New belt (installed but unused), newer hoses, regular maintenance.
There are wheel weights too but idk if they fit this unit as I've never tried.
758 hours
I got a zero turn and a Kubota tractor and this has sadly become ignored.
By ryobi.warrior
The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
By seven
Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
