Furious
Loader Plans?
Furious
Anyone have loader plans?  I have a 1967 1277 that I'd like to fabricate a loader for?  I've seen some pictures, but it's hard to find a good set of plans or at least some pictures from different angles that would give me a good idea of how to build one.  I'm pretty good at building something from pictures, just can't find enough different views to let me get a plan together.  Thanks.
Furious
roadapples
Check out PF Engineering, and   :WRS:
JAinVA
PF engineering has loader plans for around $55.00.I just got a set of his drawings.Well thought out and the web site has lots of pictures of loaders built by individuals for many different brands of  tractors.Worth a look if you want to build your own.Luck,JAinVA
JimAnderson
Gloucester,Va
WNYPCRepair
PF Engineering plans are $65 now. I bought them and looked them over. I also followed a couple of threads here closely, then started my own.
JAinVA
Rexemouse found a used loader built from PF engineerings plans.If you do a user search for Rexemouse he posted a lot of photos of his mounting of the loader on his 312.
JimAnderson
Gloucester,Va
wallfish
Money well spent if you order the PF plans. It will save you a lot of guess work! I built the hoe but assume the loader plans are just as good. You can find all the pictures you want at the PF site
But if you want, here are some BASIC free FEL plans from the manual section to download. Also put up some basic back hoe plans too but can't seem to find it.
