redhead
mower deck
redhead
is there a rear discharge mower deck to fit on a c-141wheel horse, I would like to find one if they are out there and not to expensive. I have a 42" side discharge on it know but the way buildings lay blow grass no matter how I mow
953 nut
You may want to repost this in "Classified" as a wanted ad, probably some one has one to sell.
daveoman1966
You can use most any 42" rear discharge deck that incorporates the 'tach-o-matic lift system, except for those designed for the B series trators.  Even those can be used with just a little bit of modification.
Where are you located?    I am in n/w PA at zip 16433 and can provide a useable 42" rear deck to suit your needs...probably.
send a direct email to me at:
daveoman@windstream.net
