Cole J.
hydro temp gauge
Cole J.
I seen a post on an other tractor forum I'm apart of, and it was about a temperature gauge for your hydro trans. I was wondering if anyone on here has tried this on their own tractor.
Phatboy
I havent myself ,, but im sure its a good idea .. And would be interested in learning how they do it..
pfrederi
D series came with hydro temp gauges.  i know where to mount one on a sundstrand hydro not sure about the Etons
Cole J.
I personally have a sundstrand hydro, on the other forum they were talking about putting the thermostat plug in the drain hole then every time you changed the oil you could check the thermostat as well. how did you set up your hydro Pfrederi ?
19richie66
I would be interested to know this also. I want to run a temp gauge in a sunstrand C-175. Should be close to the same set up?
82Caddy
Here is where the temp sensor is mounted on my d series pump.
