Countdown To Christmas!
marky
wheel horse 8 speed transmission problems
marky
i got a wheel horse 857 and am putting a 8 speed transmission into it. i was going to put a lot of wieght on it and a 20hp engine and plow with it in the winter. i was worndering what breaks on the 8 speeds when you use them really hard?
russellmc301
i think the transmission is belt driven and therefore the belt will slip before  anything breaks.
i may be off the wall wroung thought
Edited by russellmc301
marky
i was going to put a double pulley system and there was going to be droping the clutch a lot.
slammer302
If all the bearings and gears are in good condition and hubs. You shouldn't have any problems. Especially if you have the 8 pinion trans with the 1" 1/8 axles. The 857 is a great horse for pushing snow. Is there a reason you are changing out the 8hp kohler and original 3 speed trans both should work well for what you are planning on using it for.
sorekiwi
You can blow up anything if you try hard enough.  Treat it like it was designed to be used and you will be just fine.
  • Like 3
marky
i broke a 3 speed differential before plus it has 5 more gears for mudding and i am putting a 20hp diesel engine for more power and the 8 horse kohler is worn out.
slammer302
:wwp:
roadapples
I thought the same thing. I have a C160 with a loader and 340# of ballast. The wheels will start to dig but you can`t make the belt slip..:twocents-02cents:  And :WRS:marky..
Edited by roadapples
can whlvr
first thing I can tell you is the belt will not slip allways before something breaks,i thought this years ago when I left my 308 outside in the winter for a few days,it got warm then cold and the rear chains froze into the ground,i thought the belt will slip before anything else,NOT WHAT HAPPENED,i let the clutch out and she tore out 4 pinions and one axle gear,this was before the internet so the dealer was the only source for parts,it cost me over 600 dollars to get the parts,the only good thing was that I learned how to open up an 8 speed and repair her,and I had no book to tell me how,so I wrote down how and what I did,its haard to say what will break when used hard,it can be anything inside,bearings,pinions,bull gear(not too common)but one of the weakest parts are the shift forks
