Chas520H
42 inch rear discharge mower deck
Chas520H
Just picked up my WH520H and it has a 42 inch rear discharge mower deck. I mowed my lawn and it seemed to leave large clippings. I was running at full throttle but didn't seem to help. Do you think using a set of Gattor Blades would help or does anyone have any ideas what I could try.
953 nut
:WRS:  The rear discharge will tend to not chop the grass as finely as a side discharge because the grass only makes a single pass.  A new set of blades couldn't hurt, or at least make sure yours are sharpened well.
SylvanLakeWH
Ditto what 953 said...Sharp blades do help but you get bigger clips with rear discharge vs. side. Plus, you never run over the rear discharged clips again like you often will with side discharged clips, depending on your mow pattern, which cuts them again. Side discharge tends to leave a cleaner overall look. But that's just my :twocents-02cents:
And :text-welcomeconfetti:
Aldon
If it a calm non breezy day, the cut blades rest on top and it appears less attractive. Usually the next morning it looks a lot better.
doc724
On the positive side, RD decks seem to be less prone to having the clippings sucked into the engine.
skrusins
By all lawn mower company suggestions " you should cut 1/3 of the height of lawn" that is if your grass
is 3in. you cut 1in. I do use Gator blades on all my machines.
Edited by skrusins
wanted to add
cleat
As long as they are not simply getting sucked up by the hydro.
Tankman
One reason to have a riding mower, cut the grass frequently. As noted, cut only one-third off the grass when mowing.
Cutting off more than a third of the grass damages the lawn. If necessary, raise the blades. Then lower the blades, mow again.
Now, get with the program, mount your Horse and mow frequently Cowboy.
A rear discharge mower towing a sweeper does an excellent job. :handgestures-thumbupright:
Phatboy
I have gator blades on my 520H ,, and to be perfectly honest,, best cutting blades i have ever used ! No exaggeration !! It is the most perfectly cut grass i have ever had,,  worth every penny they cost ,,,and i have a 48" inch side discharge deck,,. Forgot to list that ,,
Edited by Phatboy
GlenPettit
When you order your new Gator Blades, they will not be exactly the same length as your original regular 42" RD blades, being a 1/4" shorter will not miss any glass blades if you leave your original regular blades on too, at 90º . . . so you now have six blades under your deck and 12 cutting edges (there should be  enough threads, and you can get 'low profile' 3/4" nuts at most any Hardware store). The extra blades, lift & cutting edges should give you finer clippings & discharge.
I'ld recommend leaving the original blades lower on the spindles, so they take the most wear . . . for my lawn, the upper Gator blades only need to be sharpened every third time, and they tend to stay at 90º in regular lawn mower use (thick & wet grass = tougher abuse, but dry regular grass will not move the double blade arrangement).    (Note: the 42" SD Gator Blades are exact length as originals, it's the 42" RD that are short - ?).
Edited by GlenPettit
312Hydro
I followed Glenn's advice on my 48 SD about a year ago and I really like the results. Thanks for the tip,Glenn! :handgestures-thumbupright::handgestures-thumbupright:
wrightorchid
I might have to try this.  I can certainly use better mulching.  What model blade do you use on the 42 SD?
Edited by wrightorchid
