Chas520H 17 #1 Posted March 27, 2016 Just picked up my WH520H and it has a 42 inch rear discharge mower deck. I mowed my lawn and it seemed to leave large clippings. I was running at full throttle but didn't seem to help. Do you think using a set of Gattor Blades would help or does anyone have any ideas what I could try. 2 Share this post Link to post Share on other sites
953 nut 55,049 #2 Posted March 27, 2016 The rear discharge will tend to not chop the grass as finely as a side discharge because the grass only makes a single pass. A new set of blades couldn't hurt, or at least make sure yours are sharpened well. 2 Share this post Link to post Share on other sites
SylvanLakeWH 25,489 #3 Posted March 27, 2016 Ditto what 953 said...Sharp blades do help but you get bigger clips with rear discharge vs. side. Plus, you never run over the rear discharged clips again like you often will with side discharged clips, depending on your mow pattern, which cuts them again. Side discharge tends to leave a cleaner overall look. But that's just my And 2 Share this post Link to post Share on other sites
Aldon 4,826 #4 Posted March 27, 2016 If it a calm non breezy day, the cut blades rest on top and it appears less attractive. Usually the next morning it looks a lot better. 1 Share this post Link to post Share on other sites
doc724 925 #5 Posted March 27, 2016 On the positive side, RD decks seem to be less prone to having the clippings sucked into the engine. 2 Share this post Link to post Share on other sites
skrusins 128 #6 Posted March 27, 2016 (edited) By all lawn mower company suggestions " you should cut 1/3 of the height of lawn" that is if your grass is 3in. you cut 1in. I do use Gator blades on all my machines. Edited March 27, 2016 by skrusins wanted to add Share this post Link to post Share on other sites
cleat 5,808 #7 Posted March 28, 2016 13 hours ago, doc724 said: On the positive side, RD decks seem to be less prone to having the clippings sucked into the engine. As long as they are not simply getting sucked up by the hydro. 1 Share this post Link to post Share on other sites
Tankman 3,518 #8 Posted March 28, 2016 One reason to have a riding mower, cut the grass frequently. As noted, cut only one-third off the grass when mowing. Cutting off more than a third of the grass damages the lawn. If necessary, raise the blades. Then lower the blades, mow again. Now, get with the program, mount your Horse and mow frequently Cowboy. A rear discharge mower towing a sweeper does an excellent job. 1 Share this post Link to post Share on other sites
Phatboy 565 #9 Posted March 28, 2016 (edited) I have gator blades on my 520H ,, and to be perfectly honest,, best cutting blades i have ever used ! No exaggeration !! It is the most perfectly cut grass i have ever had,, worth every penny they cost ,,,and i have a 48" inch side discharge deck,,. Forgot to list that ,, Edited March 28, 2016 by Phatboy 1 Share this post Link to post Share on other sites
GlenPettit 1,716 #10 Posted March 28, 2016 (edited) When you order your new Gator Blades, they will not be exactly the same length as your original regular 42" RD blades, being a 1/4" shorter will not miss any glass blades if you leave your original regular blades on too, at 90º . . . so you now have six blades under your deck and 12 cutting edges (there should be enough threads, and you can get 'low profile' 3/4" nuts at most any Hardware store). The extra blades, lift & cutting edges should give you finer clippings & discharge. I'ld recommend leaving the original blades lower on the spindles, so they take the most wear . . . for my lawn, the upper Gator blades only need to be sharpened every third time, and they tend to stay at 90º in regular lawn mower use (thick & wet grass = tougher abuse, but dry regular grass will not move the double blade arrangement). (Note: the 42" SD Gator Blades are exact length as originals, it's the 42" RD that are short - ?). Edited March 28, 2016 by GlenPettit 3 Share this post Link to post Share on other sites
312Hydro 474 #11 Posted March 30, 2016 I followed Glenn's advice on my 48 SD about a year ago and I really like the results. Thanks for the tip,Glenn! Share this post Link to post Share on other sites
wrightorchid 261 #12 Posted March 31, 2016 (edited) I might have to try this. I can certainly use better mulching. What model blade do you use on the 42 SD? Edited March 31, 2016 by wrightorchid Share this post Link to post Share on other sites
