Similar Content
By WH1618speed
1965 Wheel Horse 855 with 42" blade and chains
Runs good
Sheet metal is very straight, great candidate for restoration.
Missing Belt guard
Will sell tractor by itself for $500 without blade and chains
Blade is straight and lots of cutting edge left... just a little rusty.
Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
I can also deliver to the big show in Arendtsville, PA... IF you prepay.
Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
By admin-(Admin)
1 page 196.25KB
1 page 82.24KB
Dated February 17, 1965
232613 Kohler belt nla Use 231605
232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
1964 model 854
1965 model 855
1965 model 875
Starter/generator belt
Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
1964 model 1045
1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
1965 model 1055
1965 model 1075
By Goldnboy
I am attempting to convert a K321 from a Ford/Deere style throttle-governor to wheelhorse style. The hole shown is where the bolt attaches the bellcrank that the governor spring and throttle rod connect. The Hole on this block is there but was not tapped out to screw in a 1/4" bolt, also about half way in is some hard as #$$@ metal insert that has ate 4 drill bits. How do I get this tapped?
By DownHome
Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
By Dan693
Thinking about trying a foot pedal throttle on my WH,
Has anyone ever tried it and how did it work out?
Thanks!
