DownHome
Throttle change, up/down hills?
DownHome
I've noticed that while driving any sort of elevation change, whether it's up a hill or down I start losing throttle. What type of fuel delivery issues could I be having? Occasionally it will even die out almost completely. Sometime if I mess with the throttle I can get it back on track but seems like i shouldn't have to fuss with it that much? Any thoughts? Thanks in advance
rmaynard
Check your governor to make sure it is adjusted properly.
953 nut
Is it operating normally when it is placed under a load, like engaging the mower; if so, the governor could be the problem. Could also be a float level issue.
Phatboy
MY GUESS,,. Would be the float in the carburetor is not functioning properly ,, it seems that the bowl may not be filling up all the way so as you change the pitch or angle of the tractor it is starving for gas... If it were my tractor i would take the carburetor apart clean it well and make sure the float has full range of movment ,, and all the jets are cleaned,, it may have got some settiment in it.. Hope that helps..
Wheelin'theSky
You may have some water or build-up in the float bowl. If it's been a while since it's been cleaned I'd start there.
ol550
What are we working with?
DownHome
It's a brand new carb. I guess I could take the bowl off and inspect it. It's a Kohler K181 8HP
Phatboy
Well maybe its not adjusted right and the bowl is not filling up,, i dont know buddy,, that was my best guesstimate !! Lol
tunahead72
Correct me if I'm wrong DownHome, but I believe it's an 855 (it's one of the tags for this thread).
DownHome
An 855 is correct
  • Similar Content
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
    • Goldnboy
      By Goldnboy
      I am attempting to convert a K321 from a Ford/Deere style throttle-governor to wheelhorse style. The hole shown is where the bolt attaches the bellcrank that the governor spring and throttle rod connect. The Hole on this block is there but was not tapped out to screw in a 1/4" bolt,  also about half way in is some hard as #$$@ metal insert that has ate 4 drill bits. How do I get this tapped?
    • DownHome
      By DownHome
      Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
    • Dan693
      By Dan693
      Thinking about trying a foot pedal throttle on my WH,
      Has anyone ever tried it and how did it work out?
      Thanks!
