pstlouis 20 #1 Posted March 22, 2016 My c160 is having some tranny issues. 1) the belt is not loosening when I push the clutch 2) the brake will not engage when the clutch is pushed. Any suggestions? 1 Share this post Link to post Share on other sites
scotty 252 #2 Posted March 22, 2016 Maybe the clutch pully bearing went bad? Im not sure if that would cause that issue or not. 1 Share this post Link to post Share on other sites
squonk 41,501 #3 Posted March 22, 2016 Cracked plate where the trans mounts? 1 Share this post Link to post Share on other sites
daveoman1966 3,762 #4 Posted March 22, 2016 Are you using the right drive belt. The OEM belt is # 7473. If using an after-market belt, that MAY be the problem. 1 Share this post Link to post Share on other sites
rmaynard 15,668 #5 Posted March 22, 2016 Do you have the belt cover on? Guides on the cover assist the belt in disengaging from the drive pulley. 1 Share this post Link to post Share on other sites
daveoman1966 3,762 #6 Posted March 22, 2016 3 minutes ago, rmaynard said: Do you have the belt cover on? Guides on the cover assist the belt in disengaging from the drive pulley. Pics of belt cover guides.... Share this post Link to post Share on other sites
Ed Kennell 38,906 #7 Posted March 22, 2016 Check the 1/8" shear pin that locks the lever to the cross shaft on the right side rear of the tractor. 1 Share this post Link to post Share on other sites
