horsehouse
Serial number help
horsehouse
Hi
Hoping someone has background story on my serial number plate on a C160 8 speed I have had for some time. C160 was a worker until 417 arrived and stole the show...
Never did figure out year, etc it actually is....anyone know what 1?66 USED relates in model year?
Pictures attached -
My wife said to many tractors....this one does need to go....trying to estimate $$ range
Thanks
Horsehouse
Wishin4a416
I would think 74-75-76.  The 77's had a Model# like 71-16K80?
KC9KAS
1-0381 is a 1975 C-161....according to my "cheat-sheet".
KC9KAS
From the manual here....1975 C-160 8-speed model 1-0381.
My info came from "Wheel Horse by Years" spreadsheet. Go figure!
elcamino/wheelhorse
You can never have too :wh:, tell your wife you will get rid of the horse when she gets rid of 1/2 her clothes. Make sure you have somewhere to stay after the comment about clothes. Also RUN
  • Haha 1
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
