DownHome
855 WH Extension Spring
DownHome
I'm working on my 855 WH and have noticed that the spring on the right side (seated) is broken. It looks like it attaches to the frame and then to the pedal on the right side. I'm not sure what the function of the spring is? From what I found in the manual is that it's part #5714 So far I have been unable to locate a replacement. Can anyone help? Also what does this spring actually do? Thanks.
slammer302
Its the return spring for the idler pulley for engaging the belt for the deck
DownHome
Since I have removed the deck, do I need to be concerned with this Spring?
slammer302
No unless you plan on using a attachment that needs to driven from the engine
buckrancher
mcmaster carr #9433k111 for spring
Brian
  • Similar Content
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • KC9KAS
      By KC9KAS
      My 875 is missing the small spring that is attached to the cam/neutral plate.
      The part number is 1230 and NLA.
      Anyone have one or know the dimensions of the spring?
      Thank you!
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
    • DownHome
      By DownHome
      Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
    • Pat_In_Denver
      By Pat_In_Denver
      Looking to buy a replacement spring for belt idler on my tiller.  Tried using one from a mower deck, but it was too strong and bends the idler out just enough that the belt walks off the flat idler.  I've done an internet search for the original part number (6135) and came up blank.
      Any suggestions?  Is there a Napa or Stens equivalent?
      Thanks!
