cleat 6,796 #1 Posted March 19, 2016 I picked up this old wagon frame from work. Front end was really low to the ground so I cut and offset the front spindles. I had already put an offset in the tongue so now I need to take some out of it. Rear end needs spacer plates welded in to level it. I have started building the side and tailgate latches and hinges. I will drill and paint them once the wood rack is built and I know how everything comes together. 23 Share this post Link to post Share on other sites
KC9KAS 4,741 #2 Posted March 19, 2016 Looks like a heavy duty wagon you are putting together. 2 Share this post Link to post Share on other sites
AMC RULES 37,144 #3 Posted March 19, 2016 Looks like a fun project Cleat... would be pretty cool adding four wheel steering too. 1 Share this post Link to post Share on other sites
pfrederi 18,108 #4 Posted March 19, 2016 I see you have a hitch on the front of your horse...good thing i would need it. 4 wheel trailers are a PIA to back up a skill i have not mastered. Can't back up the hay wagon with the Case VAC so WH with front hitch to the rescue. 11 Share this post Link to post Share on other sites
squonk 41,827 #5 Posted March 19, 2016 Neat project. I hope to build a mini haywagon out of old horse parts someday. I stink with lumber though so I've had to line up a carpenter already! Share this post Link to post Share on other sites
cleat 6,796 #6 Posted March 19, 2016 I am somewhat good at backing up 4 wheeled wagons. I grew up on a farm backing up hay wagons since I was 13 or so and actually never backed up a 2 wheeled trailer until I was in my 20's. 2 wheeled trailers are easier to back up for sure, this little wagon is worse than a larger hay wagon. I will try out the front hitch next to see how that works. 2 Share this post Link to post Share on other sites
pfrederi 18,108 #7 Posted March 19, 2016 44 minutes ago, squonk said: Neat project. I hope to build a mini haywagon out of old horse parts someday. I stink with lumber though so I've had to line up a carpenter already! The hay wagon in my pics is a home built and I am no carpenter. Running gear came from an auction and is from a Model A Ford. I helped cut most the wood at a local non-OSHA approved sawmill. 1 Share this post Link to post Share on other sites
Phil854 130 #8 Posted March 19, 2016 Neat little wagon project great find!!!! 1 Share this post Link to post Share on other sites
Tankman 3,520 #9 Posted March 19, 2016 I've always had an easier time backing up the longer wagons / trailers. Can't wait to see your finished project. 2 Share this post Link to post Share on other sites
DennisThornton 4,770 #10 Posted March 19, 2016 I've got a couple larger hay wagons and a small tow behind a WH wagon and if you want a chuckle I'll record a video of me backing them up. Sometimes I do OK and sometimes I just give up and go another way. But I'll still be watching this build 'cause I want to build a mid-sized one. (Maybe I'll find someone else to back them up or fix a front hitch!) 2 Share this post Link to post Share on other sites
cleat 6,796 #11 Posted March 20, 2016 They do sometimes get a little unruly. Just pull ahead and straighten things out then try again. I think for the most part I will be going forward. 2 Share this post Link to post Share on other sites
ericj 1,578 #12 Posted March 20, 2016 i learned to back up 4 wheeled wagons with a john deer 630 with a hand only clutch, and anybody that ever drove one of those old hand clutches they were a real bear, let a lone backing a 4 wheel wagon. but my wheel horse wagon is harder to back becuase you can't split the brakes and turn as sharp as a bigger farm tractor with a horse. i'll be watching this build also eric j 4 Share this post Link to post Share on other sites
Kegler 68 #13 Posted March 20, 2016 Nice little wagon, should be very useful. Got pretty good at backing a 4 wheel wagon but when is comes to getting into tight spaces we would turn that tractor around and use the front hitch. Makes it a lot easier to cut into tight spits. 2 Share this post Link to post Share on other sites
Ed Kennell 39,641 #14 Posted March 20, 2016 (edited) OK all you Wheel Horse drivers, try backing this rig into the hay barn. Edited March 20, 2016 by ekennell 10 Share this post Link to post Share on other sites
pfrederi 18,108 #15 Posted March 20, 2016 or this 8 Share this post Link to post Share on other sites
Wishin4a416 2,191 #16 Posted March 20, 2016 Nice project. Keep the pictures coming. 1 Share this post Link to post Share on other sites
cleat 6,796 #17 Posted March 20, 2016 Removed front wheels and pulled off tires. Got all old ugly blue paint off of the tires. Wheels are ready to go to work to be bead blasted and painted. 5 Share this post Link to post Share on other sites
Ed Kennell 39,641 #18 Posted March 20, 2016 How many remember these ? If you made too many attempts at backing a wagon, the axle nuts turned loose and the wheels fell off. I didn't have time to take pictures..I was in a panic to get the wheels back on before Pappy caught me. 4 Share this post Link to post Share on other sites
roadapples 6,983 #19 Posted March 20, 2016 2 hours ago, ekennell said: OK all you Wheel Horse drivers, try backing this rig into the hay barn. I don`t believe I could even find reverse on that rig... 7 Share this post Link to post Share on other sites
cleat 6,796 #20 Posted March 20, 2016 1 hour ago, ekennell said: How many remember these ? If you made too many attempts at backing a wagon, the axle nuts turned loose and the wheels fell off. I didn't have time to take pictures..I was in a panic to get the wheels back on before Pappy caught me. Those pre-date even the old wagons we had on the farm. 16 minutes ago, roadapples said: I don`t believe I could even find reverse on that rig... Me either. 4 Share this post Link to post Share on other sites
stevasaurus 22,962 #21 Posted March 20, 2016 I was 15 when I drove the old ford tractor, with 2 loaded four-wheel hay wagons to close to the conveyor for the hay-mow and almost trashed that. Hank, my cousin's husband, through me off the tractor and backed them both up at once. I can't even picture how he did that. I can back up one, but having two hooked up...I was impressed. I did not break the conveyor...would have played hell getting those bales in the barn with out it. 7 Share this post Link to post Share on other sites
squonk 41,827 #22 Posted March 20, 2016 The color of the tractor was all wrong Steve. If it was red you would have made it easy! 4 Share this post Link to post Share on other sites
cleat 6,796 #23 Posted March 23, 2016 Front wheels are now sandblasted and painted. New tubes are also ready to replace the ugly rusty ones. I will mount tires when the paint has cured for a while longer. Now to work on the back wheels and tires. 5 Share this post Link to post Share on other sites
cleat 6,796 #24 Posted March 24, 2016 Well, I got impatient and mounted the tires with the new tubes. Front wheels are now complete. 1 Share this post Link to post Share on other sites
cleat 6,796 #25 Posted March 24, 2016 Wagon frame has been stripped of all bolt-on components ready to have rear axle spacers welded in. Frame will then be sanded and painted then reassembled. Frame has been drilled for bolts to attach wood rack. 4 Share this post Link to post Share on other sites
