BenTheWheelHorseMan
Stuck Head stud problems
BenTheWheelHorseMan
I have a Kohler k241 that I recently acquired. When I bought it I was told that it was rebuilt and bored .030 over. It came without head bolt and a head gasket, but there were 2 head studs in it. One came out relatively easily, but the other is pretty well stuck. I have tried penetrating oil and I do not want to heat it because it is right next to the exhaust valve. Would it be a big deal to just put a spacer on top of the place where the bolt head would go and just put a nut on it? Thanks
Edited by BenTheWheelHorseMan
BenTheWheelHorseMan
These are some pictures of the head and the stuck stud.
JAinVA
You should have no problems doing what you propose.Just make sure that there are a couple threads below your spacer top so that the nut bears on the spacer and not bottom out .Try to use a heavy walled spacer.Do the normal torque sequence and retorque after a few hours run time.JMHO ,JAinVA
JimAnderson
Gloucester,Va
BenTheWheelHorseMan
JimAnderson
Gloucester,Va
You should have no problems dowhat you propose.Just make sure that there are a couple threads below your spacer top so that the nut bears on the spacer and not bottom out .Try to use a heavy walled spacer.Do the normal torque sequence and retorque after a few hours run time.JMHO ,JAinVA
JimAnderson
Gloucester,Va
Thanks Jim. I was hoping you would say that. That stud is really stuck and I am glad that the spacer should work out.
KC9KAS
Is it possible that the stud once had a bracket also attached.
I was thinking some Kohler's had a bracket for the throttle cable attached under one of the head bolt/stud. Just thinking out loud.
BenTheWheelHorseMan
That could be. I recall having seen some like that before. I was really wondering if someone at some point switched the head out on it from the one that came with studs.
rmaynard
What is the K241 off of? I've never seen one with an oil dipstick tube. Does it have a starter that mounts on the side and engaged with the flywheel, or did it have a starter/generator? Could it be a stud for the mounting bracket of the S/G bracket?
pfrederi
The S/G uses 2 studs but they are on the back end of the head (away from the valves)
JAinVA
Kohler engines were widely used in applications other than garden tractors.They provided reliable power for many application such as concrete/mortar mixers,concrete saw and the list is endless.A year ago I was able to get a clean low hour K341.This engine has no throttle control.It is set up to run high idle.The block has 2 studs where a bracket is attached that has the ignition switch and starter switch.The starter switch looks like the old auto dimmer swtich.It doesn't engage a solenoid but directly closes the circuit between the battery and starter.This is a very handy set-up as the positive lead and fuel supply are the only things needed to mount this engine. Works great to evaluate a newly aqquired tractor with a blown or missing engine.To my original point.That Kohler could have come off just about anything. Luck,JAinVA
Edited by JAinVA
BenTheWheelHorseMan
I believe it is off of a cub cadet because it has the starter generator mount on side. The guy I bought it from may have told me that it was off a cub cadet, I just can't remember.
Actually, I see that on the pto end of the engine there is the cub cadet front clutch mounting plate and starter belt pulley so it must have been off of a cub
doc724
If it makes you feel any better...last year I refreshed a tractor and it had a K241.  I took the head off and snapped that very bolt by the exhaust port.  After drilling the broken bolt out and cleaning up the threads, I bought a new stud, coated it liberally with hi temp JB weld and threaded it in and gently torqued it into the block but not enough to strip the fragile threads.  I let the JB weld set for a few days, reassembled the head and torqued per factory specs.  Still runs like a champ.  Leave the stud alone and make sure the head is thick enough so you can torque down on the nut
  • Similar Content
    • aaronthomas57
      By aaronthomas57
      Hello Everyone,
      The information here has been invaluable as far as getting this old wheel horse I purchased back in service. Some parts home made, the motor generator is ripped off a 2013 Yamaha, some salvaged parts.
      I bought this little bastard some months ago, it had to be dug out of the previous owners yard and lifted with a backhoe. It had not ran in about 40 years.
      Thanks for taking a look.
    • tomabrown77
      By tomabrown77
      my 1067 stopped moving; limited slip had worn out long ago;  now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance.  Enough to tell me shift lever is actually changing gears.
      I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt  transaxle if someone has one they would part with.  And any advice on opening up the transaxle and looking inside .  Or where i can find parts to rebuild it myself...
      ps i was on forum about 5 years ago,  forgot my username so i joined again
    • JeremyNzl
      By JeremyNzl
      Hi Guys,
      Looking for some advice,
      We rebuilt this k241 with a +.010 piston, Its had a rebore to +.010 but they did it off the manual specs and not the piston.
      Not ideal with an aftermarket piston but I wont get caught on this next time.
      Its developed this oscillating ting noise, its not the metal cover its there with it on and off,
      its 100% from the cam side, does it under low load / slow idle,
      Have setoscoped the motor with a screwdriver to the ear, and I cannot locate it.
      but its in the top.
      Have rechecked valvel clearances x2 already , 1st before initial run, and again day after, very minimal adjustment made after 1st run.
      Ting noise clearly heard in the video , appreciate any advice.
      Jeremy Nz
      https://www.dropbox.com/s/txf8fciaqi5rozg/2021-06-10%2009.08.11.mp4?dl=0
    • WheelHorseC101
      By WheelHorseC101
      When I start my engine it will die once i change the throttle from idle to full throttle and when I switch the cold start throttle to what ever down is. It will just die every time
    • BAM1
      By BAM1
      Starting a slow restore to a C-160, Today she got a new fuel tank, and different tires. Started it up and went for a ride under her own power, first time since '08.
      Next comes finding the fuel leak, looks like a bad hose. and maybe some cleaning of the oily parts.
