mikeeyre74
1056+B-60 Transaxle = ???
mikeeyre74
I know a guy who has a nice enough 1056 without a motor or transaxle. I have an 8 speed transaxle from a B-60 that I parted out a while ago.. is it feasible to mate the 1056 chassis to the 8 speed trans and then go find a motor to bolt in there and run it? Comets think of it.. i think I still even have the 7hp engine from the B-60 kicking around here somewhere.. would that work in this setup as well?
N3PUY
Sounds like something I'ld do!  :techie-eureka:
Dad&Kev
I did that exact same thing last year . You will need to change the drive pulley to fit belt guard , make new brake rod because its different and make shift tower cover. everything else bolts up
