WNYPCRepair 1,923 #126 Posted March 27, 2016 (edited) A good nights sleep makes a lot of difference. I realized the arm isn't twisted, it's the holes in the mount on top of the pedestal. My cheap HF drill press has so much play in the spindle one hole was 3/16" higher than the other side, which made the arm twist. cut one side of the mount loose, popped it up 3/16", cut the bucket flanges loose and re-tacked everything and it is almost perfect now. I'm not going to stress over 1/16", I think it will be fine. Glad I decided to tack weld everything until I am sure it all fits. Edited March 27, 2016 by WNYPCRepair 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #127 Posted March 27, 2016 (edited) Ran out of steel, I need a couple more squares for the cylinder mounts and the cross beam above the bucket. I tacked on 2 squares and tried the cylinders, it is coming together quickly now. Finished all the pins. got the pump mounted, though I think I am going to have to rework the mount, I can't get the belt tight enough. Finished the angle braces. Beads are getting better. Test mounting cylinders Anyone have a clue what this O ring is for? It is on both the cylinders I fitted today. The specs said they had a wiper, but this isn't going to move once the cylinder extends. Edited March 27, 2016 by WNYPCRepair 3 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #128 Posted March 30, 2016 So, the steel lines that the hoses hook to... Has anyone made them (or had them made) from scratch, or is there somewhere to buy them ready made, etc? All I am finding is rubber lines. I don't suppose it is the end of the world to use rubber lines from valve to cylinders, but the steel lines look a lot cleaner. 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #129 Posted March 30, 2016 What do you know, I finally found something. Supposedly these double ferrule compression fittings are good to 3300 psi with .035 3/8" tubing. Anyone ever try these type fittings?http://www.stainlesssteelfittings.com/flareless_compression_fittings_s/2018.htm Share this post Link to post Share on other sites
cleat 6,945 #130 Posted March 30, 2016 (edited) I have similar fittings on the loader hoses on my big diesel tractor. These run at 2600 PSI no issue. these are swagelok SS fittings swaged onto the factory steel lines. Been this way for a few years now. Edited March 30, 2016 by cleat 3 Share this post Link to post Share on other sites
Phatboy 565 #131 Posted March 30, 2016 Boy wnypc hats off to ya buddy ,, that is far above my limits of capability,, nice looking !!! 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #132 Posted March 30, 2016 43 minutes ago, Phatboy said: Boy wnypc hats off to ya buddy ,, that is far above my limits of capability,, nice looking !!! Thanks, appreciate the words of encouragement. I'm kind of at a stop, I got the flu or something, have been sick since Sunday. Today was my first day out of the house, worked all day and I am exhausted, but I think it is behind me. Have another full day of work tomorrow, then hopefully I can get back to work on it. did force myself to run by the steel store yesterday, but then I was too exhausted to do anything 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #133 Posted March 30, 2016 9 hours ago, cleat said: I have similar fittings on the loader hoses on my big diesel tractor. These run at 2600 PSI no issue. these are swagelok SS fittings swaged onto the factory steel lines. Been this way for a few years now. Is that tubing 1/4", or 3/8"? Share this post Link to post Share on other sites
cleat 6,945 #134 Posted March 31, 2016 I believe they are 12mm (tractor is all metric). Share this post Link to post Share on other sites
WNYPCRepair 1,923 #135 Posted March 31, 2016 12 minutes ago, cleat said: I believe they are 12mm (tractor is all metric). Oh wow, that is almost half inch Share this post Link to post Share on other sites
roadapples 6,983 #136 Posted March 31, 2016 5 hours ago, WNYPCRepair said: Is that tubing 1/4", or 3/8"? My Ark has 3/8"..... 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #137 Posted April 5, 2016 Well, I think I am going to skip the hard lines, and just run hoses. I stopped by a Kubota and a Mahindra dealer today, and both brands have tractors done both ways. Some used hard lines, some just used hoses from valve to cylinder. I then stopped by a place that does hydraulic lines, and just the tubing is $65, and looking online, the fittings would be at least $100 just for the 4 tees at the cross brace. I will mount the valve and cylinders and measure for hoses and get those ordered. Looking at Andy's loader, it appears he used 1/4" hoses from valve to cylinders, and 3/8" from tank to pump. Now I just need to figure out how sizes work on the fittings at universalhoseandfittings.com. They just show part numbers like 5604-04-04-04, no idea what size hoses fit it, so I will have to call. Share this post Link to post Share on other sites
Snowmobileaddict 403 #138 Posted April 5, 2016 (edited) 38 minutes ago, WNYPCRepair said: Well, I think I am going to skip the hard lines, and just run hoses. I stopped by a Kubota and a Mahindra dealer today, and both brands have tractors done both ways. Some used hard lines, some just used hoses from valve to cylinder. I then stopped by a place that does hydraulic lines, and just the tubing is $65, and looking online, the fittings would be at least $100 just for the 4 tees at the cross brace. I will mount the valve and cylinders and measure for hoses and get those ordered. Looking at Andy's loader, it appears he used 1/4" hoses from valve to cylinders, and 3/8" from tank to pump. Now I just need to figure out how sizes work on the fittings at universalhoseandfittings.com. They just show part numbers like 5604-04-04-04, no idea what size hoses fit it, so I will have to call. That 5604 fitting is just like the photo indicates on the universalhoseandfitting website. Its a TEE with 2 female ends and center male connection. The 04 , 04, 04 designation refers to the size of the fitting openings in 1/16ths of one inch. Therefore 04, 04 , 04 means its 1/4" pipe fitting on each of the openings. You'll probably want to go with the 2603 fitting for your tees. Those 2603 fittings are MJ, MJ, MJ or Male JIC all the way around. The JIC connections are a flared connection and do not require pipe dope. They are easy to open and close repeatedly and not have leaks. The 5604 fitting you called out is all NPT and would require pipe dope. All the Kwikways used 1/4" hard lines and 1/4"hoses for valve to cylinder. Also, on the Kwikways, the pressure line from the pump is 3/8" ID hose and the suction hose from the res to the pump is 3/4" ID. Lastly, the number convention is better decoded for hydraulic fittings on this online store: http://www.discounthydraulichose.com/SS_5604_Male_Pipe_Branch_Tee_NPTF_p/ss-5604.htm Although, the prices are cheaper at universalhoseandfitting.com at least for what I bought. they were much cheaper. Edited April 5, 2016 by Snowmobileaddict 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #139 Posted April 5, 2016 53 minutes ago, Snowmobileaddict said: That 5604 fitting is just like the photo indicates on the universalhoseandfitting website. Its a TEE with 2 female ends and center male connection. The 04 , 04, 04 designation refers to the size of the fitting openings in 1/16ths of one inch. Therefore 04, 04 , 04 means its 1/4" pipe fitting on each of the openings. You'll probably want to go with the 2603 fitting for your tees. Those 2603 fittings are MJ, MJ, MJ or Male JIC all the way around. The JIC connections are a flared connection and do not require pipe dope. They are easy to open and close repeatedly and not have leaks. The 5604 fitting you called out is all NPT and would require pipe dope. All the Kwikways used 1/4" hard lines and 1/4"hoses for valve to cylinder. Also, on the Kwikways, the pressure line from the pump is 3/8" ID hose and the suction hose from the res to the pump is 3/4" ID. Lastly, the number convention is better decoded for hydraulic fittings on this online store: http://www.discounthydraulichose.com/SS_5604_Male_Pipe_Branch_Tee_NPTF_p/ss-5604.htm Although, the prices are cheaper at universalhoseandfitting.com at least for what I bought. they were much cheaper. Thanks, Andy, that is a big help. I thought the 04 meant 1/4", but I wasn't sure. I will go with JIC fittings at the tees, and SAE at cylinders, valve and pump, unless it is cheaper to have JIC hoses made and use an adapter, which I wouldn't think would be the case. Shocking how much the compression fittings for the tubing cost. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #140 Posted April 6, 2016 OK, hoses and fittings ordered, control valve mount built and fitted. Ready to take it all apart, finish all welds, grind, sand, clean and prime. Hoping for better weather so I can do it with the garage open. Even with a mask I inhale huge amounts of dust when grinding. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #141 Posted April 8, 2016 On March 5, 2016 at 8:10 AM, Snowmobileaddict said: Yeah. No key way. You'd have to drill a small shallow divot or similar into the pump shaft for the setscrew to land on and better secure the pulley. I tried drilling a spot on the keyway. No go. Started with a center drill, and it barely scratched the surface. Switched to an end mill, thought I would just mill a flat spot on the shaft where the set screw hits the keyway. Same result, pretty sure the cutting edges of the end mill were wearing away. That is some hard steel. Ended up cranking the set screw into the keyway as hard as I could get it, but I'm not sure it will hold. I'll start looking for a pulley with a keyway, but I'm not sure one exists. Share this post Link to post Share on other sites
Snowmobileaddict 403 #142 Posted April 8, 2016 2 hours ago, WNYPCRepair said: I tried drilling a spot on the keyway. No go. Started with a center drill, and it barely scratched the surface. Switched to an end mill, thought I would just mill a flat spot on the shaft where the set screw hits the keyway. Same result, pretty sure the cutting edges of the end mill were wearing away. That is some hard steel. Ended up cranking the set screw into the keyway as hard as I could get it, but I'm not sure it will hold. I'll start looking for a pulley with a keyway, but I'm not sure one exists. I'm almost positive you won't find a "finished bore" pulley with a keyway in 1/2" diameter. You'll end up getting a pulley that takes a split taper bushing adapter. They are available at McMaster Carr. You'll be at about $10 for the split taper bushing (with keyway) that will go on the pump shaft and about $28 for the pulley diameter of choice to spin the pump. Bushing Adapter for Pump Shaft: http://www.mcmaster.com/#9859t1/=11w85yl 6.35" Pulley to Mount on the Bushing Adapter: http://www.mcmaster.com/#6209k215/=11w86up 3 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #143 Posted April 14, 2016 Finally got hoses and fittings, hopefully I can put the hydraulics together this weekend and test. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #144 Posted April 16, 2016 For want of a fitting, the job was stopped. I put the new pulley and collar on the pump, installed the fittings, only to find the outlet from the pump ended up at an angle that prevents me from being able to attach the hose, so I need an elbow. I'll have to buy it locally from ferry hydraulics, can't wait to see how bad they rape me for it. It's a $3 fitting, I'll bet I pay $15 or so for it. But I did get some stuff done. 5 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #145 Posted April 18, 2016 So, went to Ferry Hydraulics, picked up the fittings to finish, got home, and they gave me the wrong fittings, they weren't even close. Went back, got the right ones, put it all together, and filled it with fluid, and tested. Found out that despite Andy's advice and the directions on the website, I STILL got the inlet and outlet on the pump reversed. I used up a whole bundle of rags soaking it up. Gotta get more kitty litter. Sorry for the crappy video, I had to rest my phone on my truck mirror. 7 Share this post Link to post Share on other sites
Forest Road 594 #146 Posted April 19, 2016 Well done! All the members with pretty Xi's, like yours, keep making me consider painting mine. In the winter I've been known to tape my phone to a 2x4 and stick it in a snow bank. Won't repeat what my wife said when I asked her to record my antics. 4 Share this post Link to post Share on other sites
Snowmobileaddict 403 #147 Posted April 19, 2016 Looks good! The cycle times are faster than a kwikway. I wish mine was just a touch quicker. 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #148 Posted April 19, 2016 49 minutes ago, Snowmobileaddict said: Looks good! The cycle times are faster than a kwikway. I wish mine was just a touch quicker. yeah, almost too quick. Share this post Link to post Share on other sites
CasualObserver 3,410 #149 Posted April 19, 2016 That is turning out awesome, nice job! 2 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #150 Posted April 19, 2016 19 minutes ago, CasualObserver said: That is turning out awesome, nice job! Thanks. I definitely learned some important lessons, and there are things I would do differently if I had to do it again. I also wish I had started earlier, so I could have spent more time, I definitely had to work fast to get it finished for spring, so it isn't the prettiest job, but as long as it works, I can overlook ugly. My wife overlooks ugly every day, so I guess I can too. 5 Share this post Link to post Share on other sites
