ztnoo
K341 With No Fire In The Hole
ztnoo
Went to start up my GT 14 equipped with a 16 hp K341 yesterday afternoon.
The starter spins like there's no tomorrow, but I've got no spark to the spark plug, so the engine's not firing.
Tractor lights are working fine.
I have been doing random work on the tractor and may have bumped or dislodged an electrical connection.
The engine started fine last fall and has always started without problems.
I'm the likely culprit here, but I'm not quite sure where to begin tracing the problem.
Any suggestions as to the most likely place to first look to locate the reason I have no spark???
pfrederi
To confirm does your 16hp have a battery ignition system??    If so first see if you have 12 volts at the small + terminal of the coil when the switch is on (and also in the start position.) Then we can determine if we need to look upstream (wiring/switch) or down stream, coil points plug.
  • Like 4
rmaynard
I would check the points. Clean the contacts and try again.
Tuneup
ztnoo,
Do you have a test light or DMM? If so, and I don't know specifically about this machine but do know the basic coil/points wiring on a Kohler. I have a K301. With the key cranking the engine and in run, is there light or 12V on the + terminal of the coil? If so, ignition switch and wiring good. Pull the plug and ground it to the engine. With key on, short the - on the coil to ground with a test lead to charge the coil and then remove it from ground. Do it a few times and you should see a spark when you remove ground now and again. If no spark, disconnect the capacitor - may be shorted - and try again. No spark - coil (assuming the plug and wire to it are good). If spark, points or capacitor. You can measure the cap with your DMM. It should not be short and should charge. Sounds about right?
ztnoo
OK.......I did have good luck yesterday resolving the ignition issue.
In a nutshell, I'll state two words....................USER ERROR.
While working on my hub removal/woodruff key/axle seal replacement project, I have on occasion, gotten distracted and wandered off, meandered, worked on, or maybe a better term would be, messed and finagled with other things I have assigned random importance to, for whatever reason, during times I have encountered hangups or glitches with my original focus.
One of those things was the replacement rectifier I noted in another thread.
Having finally resolved the questions concerning that component and purchasing a replacement, I noted some wiring terminals in need of attention. Ah, another diversion................
I set about buying a variety of fully shielded terminals to retrofit specific connections/wire sizes I deemed faulty, inadequate, and in need of replacement.
Some of those terminal connections were associated with the switch which controls starting the tractor.
I removed the switch from the cast "dashboard" housing and replaced those female connections I observed which were not in good condition.
I replaced the switch back in its location and went about my business.
I also worked replacing battery terminal connections.
I've always had significant problems with battery sulfation on this tractor.......and I've owned it 35 or so years, its always set inside an attached garage .......and its always the same problem. That horrific "algae bloom" from battery posts is something I've always chased my tail with. So, I resolved to attempt to remedy or reduce the problem. I removed the positive cable and then the clamp on the cable........ I cleaned and scrubbed the stranded copper cable ends with a baking soda solution until all signs of green corrosion were gone, rinsed completely, let dry, then replaced the post clamp after treating the stranded copper with dielectric grease. The ground clamp was a woven cable (I'm unsure if it was original to the tractor) and the old one was pretty funky, so I replaced that with a new woven ground clamp. I like them because of the flexibility of the cable which makes it easy to route around other parts.
So yesterday, after finally getting the new rectifier installed and rewired with fresh terminals, I replaced the battery tray (removed earlier for access to installed the rectifier on the inside of the left panel in its OEM location), set the battery in place and hooked up the new cables. I decided to see if everything worked OK. The starter would freely and ungrudgingly turn the engine over like crazy, but would not fire. Tested the front and rear lights, and they worked fine. Everything seemed to have power to it. I finally pulled the spark plug to observe if I had ignition. Clearly there was no spark being delivered to the plug. I figured my only option was backtracking to reexamine the switch spades and the wiring leading to those male spades.
To aid in doing that, I opted to pull the steering wheel, the grease zerk on the column, and the plastic dash panel to greatly improve access to the back of the switch.
As soon as the dash panel was removed, I could clearly see a wire was detached from the switch. I physically traced its path......and interestingly it went to the + side of the coil!
Eureka, now I know why there was "no fire in the hole"! That's a pretty big arc to jump across when the switch end isn't hooked up to the switch. I decided I better recheck everything that plugged into the male spades on the switch to confirm correct wire locations and to be sure of secure connection of each terminal. I removed the switch body from the cast dash surround to further view and see what went where.
Sometimes I tend to forget I have a somewhat bastardized GT 14, in that it doesn't have its original K321 14 hp engine, but rather a K341 16 hp engine. That was changed out, I'm guessing 30 years ago after a broken rod came apart and lunched the block. I was busy working then, sometimes 7 days a week. So my dad had some guy he knew that was a mower repair mechanic do the changeover. I had no hand it that conversion and don't know the specifics of what went on and what transpired, or who it was that did the work. All I knew was dad had the guy pick the tractor up, and switched things out installing a brand new K341, and delivered it back to me in running condition. I have no particular reason to think the ignition switch may have been changed at that time, but after researching this a bit I'm beginning to think it might have been.
However in looking at the back of the switch, my switch is different than what is shown in the 1969 Model 1-7441 literature. That spec shows a switch with 5 spade positions with the following lettering from left to right, facing the switch from the seat: B,S, L, M, R . This diagram shows the terminal spades just mentioned, and in addition, no coil is shown in this schematic. The parts list calls for switch # 8362 as standard equipment on the 1969  GT 14 Model 1-7441. I assuming the "M" spade position refers to "Magneto".
56dc416e5a32a_1969GT141-7441diagram.thum
My K341 has a coil attached to the side of the fan housing. The positive side clearly goes to the switch (position "I" below), while negative post has a wire from the condenser (also on the mounted on the fan housing) and another wire which runs from the negative coil post and disappears behind the fan housing and I assume under the flywheel. The switch installed on my tractor also has 5 male spade positions with the following lettering from left to right, facing the switch from the seat: B,S, A, I, R . I can't identify any part number associated with this switch although there is a patent number on the switch. The poorly scanned image below from GT 14 literature I have in hard copy is a GT 14 owners manual with no model number assigned on the cover. Inside this manual there is a page with the image below stating specification changes to Model 1-0502 ('72 & '73) and Model 1-0503 ('73). The schematic shown below which I scanned and cannot find anywhere else, accurately describes what I have on my tractor. I suspect the switch I have is not an original because the terminals are designated differently than the '69 switch is in the image above. A change must have been called for given the coil in my system at the time of the engine switchover. I don't know because I'm not an electrical guru. I feel fortunate to have just resolved my no spark issue.
Here's what the assigned terminal positions on my GT 14 operate:
B  =  Ammeter
S =  Clutch switch
A =  Light switch (w/fuse inline)
I  =  Coil +
R  =  Rectifier
 56dc565e5a173_03-05-2016051651PM(2).thum   56dc55377b2fb_03-05-2016051742PM.thumb.J
I believe this may be the switch I have, but I have no absolute proof of that supposition. No terminal letter identifications on image at the left. Different letter destinations from my switch's designations on the right.
Curious stuff. All I know is that is working again.
As I said before, USER ERROR. Getting in a hurry and not being attentive enough to what I was doing, was the prime cause of my non working ignition and "no fire in the hole".
Duh!!!
56dc59f09262f_101876_Switch_Battery_igni   56dc5bb882827_92-6785_Switch_Battery_ign
Edited by ztnoo
ztnoo
After researching a bit more this afternoon, I found the same switch I have in my GT 14, available as a new part, from a source other than Toro and the usual players who almost always provide no pictures of the item.
It replicates my switch exactly, and the vendor offers stunning, accurate pictorial evidence to potential buyers.
From iSaveTractors
http://isavetractors.com/ignition-key-switch-for-garden-tractors-with-battery-ignition/
56dccd90e244b_GT14switch(2).JPG.921806b4
"Ignition Key switch for Battery Ignition Kohler K Engines
This is a 5 Terminal, 3 Position Ignition Switch. Works for all Vintage Garden Tractors and Kohler K Engines that use a battery ignition system.
  • The terminals are for Battery, Rectifier, Ignition, Starter, Accessories
  • 9/16" Mounting
  • Circuit Design: Off: No Connections Run: Battery + Rectifier + Ignition + Accessory Start: Battery + Start
Same High Quality Key Switch we use to rebuild dozens of tractors per year! When you first buy your old vintage Garden Tractor, replace the Key Switch! It likely has years worth of corrosion!
Fits all Battery Ignition Kohler K Engines! For all models of tractors.
  • Cub Cadet
  • John Deere
  • Wheel Horse
  • Ford
  • Jacobson
  • Case
  • Ingersoll
  • Gilson
  • And Many Others!"
Tuneup
So glad you found the problem! I've been frustrated chasing gremlins, too. You can always disconnect the switch and map it with a DMM if you're so inclined but, why bother? You have a working tractor and that's a good thing. If you do plan to buy that new switch, map it to match before you simply swap the wires, otherwise, Murphy may just kick in.
  • Similar Content
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
    • Rollo416H
      By Rollo416H
      I'm new here, but I have years and miles of dealing with electrical issues with my 1997 416H, engine Onan P216G (I am the only owner) . Problem description: the start circuit turns the starter over fine, but no spark at the plugs or the coil sockets by spark tester.  The ignition trigger tests good by connecting a test light to the coil positive and and the ignition trigger negative lead, plenty of light flash from the test light in unison with the engine turning over. So, I conclude the ignition trigger, replaced 3/18/2021 along with the coil is good.  I have followed the "Demystification" wiring diagram in detail and there is 12V at the coil positive terminal, wiriing is solid (for now), all those damn safety switches, key switch,  and relays work too. I conclude that the coil is bad since the primary side tests 3.1 OHM and the secondary tests infinite OHMS (1. displayed on multimeter).  Two coils (Onan part# 166-0820) have NEW dates of 3/2021 and 8/2021, and yes both have the same test results mentioned. Infinite OHMs to me means the coil windings are broken. The most recent coil came from Onanparts.com and tested as mentioned above when it arrived.  Onanparts won't take anything back!  There are a lot of coils on ebay and various suppliers from China.  Maybe good, maybe bad, who can tell? And most suppliers won't accept returned electrical parts. Please help: What are good test readings for a GOOD coil (primary and secondary). Who do you recommend as a reliable supplier for a new coil?
      Thanks for any help!
      Rollo416H
    • Don66
      By Don66
      I have a 1978 Wheel Horse 8 speed tractor,Kohler 321 engine. I've been working on restoration, finally got the mower deck finished and installed. Before this, the engine was easy to start and ran well. Yesterday it would not start with ignition key, would not even turn over, so I jumped it with a screwdriver between cylinoid and battery. The engine started and ran about 10 seconds and died. Now I get no spark and the engine won't fire off. I checked the wiring and everything seems to be connected and without damage. I don't have test equipment available so I'm stumped at what went wrong. Any suggestions?
