nickj21 20 #1 Posted March 5, 2016 I need held with what transmission fluid i should use in my hydrostatic charger 12. Thanks! Share this post Link to post Share on other sites
pfrederi 18,334 #2 Posted March 5, 2016 I would stick with whatever is currently in her. Cherry red looking is ATF (There is a universal ATF for Dexron 3 and prior and older Mercon versions). Tan color is Motor Oil Use 10w-30 or 10w-40. If you try to change you have to repeatedly flush the system which costs money and there is the disposal issue. I have 3 Sundstrands 2 on ATF one on Motor oil. all do just fine. 1 Share this post Link to post Share on other sites
953 nut 57,969 #3 Posted March 5, 2016 If the present fluid is red then it is automatic transmission fluid and you can replace it with Dextron II ATF, if it is amber it will be 10-W-30. Remember to change the filter also. Here is the manual for the trans. 1 Share this post Link to post Share on other sites
nickj21 20 #4 Posted March 6, 2016 On Saturday, March 05, 2016 at 8:37 AM, pfrederi said: I would stick with whatever is currently in her. Cherry red looking is ATF (There is a universal ATF for Dexron 3 and prior and older Mercon versions). Tan color is Motor Oil Use 10w-30 or 10w-40. If you try to change you have to repeatedly flush the system which costs money and there is the disposal issue. I have 3 Sundstrands 2 on ATF one on Motor oil. all do just fine. Would the filter differ if i use dexron or motor oil? Share this post Link to post Share on other sites
pfrederi 18,334 #5 Posted March 6, 2016 Same filter WH 79-5270 Share this post Link to post Share on other sites
953 nut 57,969 #6 Posted March 6, 2016 3 hours ago, nickj21 said: filter differ if i use dexron or motor oil? NAPA 1410 filter is also used for the hydros, may be easier to come by. 1 Share this post Link to post Share on other sites
