IthacaJeff
Gravel on the grassy bank
AMC RULES
I'm thinking...
NOT!
Edited by AMC RULES
Phatboy
My neighbor has a huge back yard and it is slap full of moles ( i have none) his craftsman tractor was broke ( cough cough) so he askd if i would pull his brinly 400lbs roller around for him ,, so i loved the fact i got to go oit and play on my tractor today, but i told him them little rascals better not come in my yard !!! Lol
Ed Kennell
And we all thought you were just overweight.
Tankman
Look up milky spore disease. ;)
IthacaJeff
Okay, so my gravel bank issue gets hijacked by Tiny Tim and moles. Wow. But, just in case a few might still have some solutions, here are the pics:
This is the mowed part of my yard. I do mow this bank, and you can see that I was able to dozer the gravel off the top of the bank. But dozing does not work on the slope; regardless if going across the fall line or up and down. I emailed the town highway dept. to see if they would take care of it, as this is far beyond the normal. Way to much to rake out. I've yet to hear back.
This is the part of the bank flail-mowed by the town. Too steep to mow across or up and down, too steep for the dozer blade. The gravel is thick.
Retired Sparky
10 hours ago, Tankman said:
Gas those ugly pests? Needs some thought.
Try Milky Spore disease, kills grubs. Moles populate where grubs live, milky spore, one application lasts 20-30 years. Eliminates the moles' food supply.
The moles will move to your neighbors. :handgestures-thumbupright:
That is very true. Kill the grubs, the moles have nothing to eat. :text-goodpost:
Ed Kennell
:text-imsorry:  for the  hijacking  Jeff.   The pictures make it clear ...you have a serious stone problem.   I feel your pain and I only raked for  1 1/2 days.
I'm thinking one of the smaller power brooms where you have room to work from the bottom up may work in the shorter grass.  In the longer grass with no room at the bottom  ????
One thing I try to do is when the snow starts to melt, I push the snow back on the edges of the road while the stones are still suspended in the snow.
WNYPCRepair
On February 29, 2016 at 0:23 PM, tunahead72 said:
Pics will definitely help.  You might want to ask your town's road crew to stop by and take a look, see if they have any ideas.
Whoever owns the road (county, city, state) is responsible for maintenance. Start complaining about the blocked ditch and keep complaining. The squeaky wheel gets the grease.
On March 1, 2016 at 8:06 PM, AMC RULES said:
After installing my rock collection a couple years ago...
That is a nice looking wall, Craig. I wish I had some stones on my property, I've always loved those low rock walls. I like the plants in the middle too.
14 hours ago, ekennell said:
The latest "invasive species".             Break out the mole controllers.
56d58f2e1b8d9_IMG_2679(640x480).jpg.17b8
I think this might be the best implement for a WH yet!
I think what was digging up my garden was a vole or shrew. The only holes I ever saw were coming up inside the garden, never did spot the ones outside the fence. Any ideas for those?
I should have finished reading the thread before replying, I guess. :)
If that part of the grass is their property or right of way, they may not have to do anything, unfortunately. Hopefully they clean it up. If not, maybe you can rent a power broom for a day?
Looks like your driveway is gravel, tell the highway dept they don't have to haul it away if it is easier, just sweep it up wwith their power broom and you'll doze it away. :)
You could go to Home depot, buy a cheap riding mower, set the blade as low as you can and mow all the gravel back into the road, then return it. :)
Phatboy
Im sorry Jeff i saw the wh with the tube and killing of the moles ,, i thout that what convo was about ,, im really sorry did not mean to hijack your post:text-offtopic::text-imsorry:
Tankman
Sorry Jeff. Seeing your pic's, stone problem is awful. A back breaking rake job, appears you'll be raking till dooms day.
You might rake, rake, rake. :unsure:
Lane Ranger
I worked with a guy that developed a product back in the 1980's called Mole-Med.     It had to have approval from the U.S. Environmental Protection Agency  under FIFRA -the Federal Insecticide and Rodenticide Act.
He used two ingredients -ivory liquid soap and castor oil.    Poured down a mole hole (or later with pellets)  the moles would smell, eat and then blow up on their rear end!
Edited by Lane Ranger
Lane Ranger
Driveway groomer device  may be worth looking at to deal with your gravel on the bank issue.    You can see it has teeth on the "groomer' .      I do not have one  but there is a video or two on Youtube of this in operation.     I use a  light dethacher on my lawn each year and it will pick up  gravel and walnuts after the times get full of grass.    This groomer  would cut into the grass too but that actually  might act like a dethatcher does.
http://www.drivewaygroomer.com/shop/driveway-groomers/groomer-jr-riser-plate-black-hardened-blades/
Tankman
My dethatcher does bounce stones up 'n out but still need lots of spring tooth raking. My drives are stone and asphalt millings. The stone goes back where it belongs, on he driveways.
One big problem when wet, stone hugs mud, sticks in the lawn. Driving, the Horses' weight push the stone in further.
Annual grass germinates in seven (7) days. A good cover for stone left behind. Plant grass seed before leaves grow on trees. There's no such thing as "shady lawn grasses".
You can overseed (in) the annual grass using perennial grasses. Perennial grass will be held in place while germinating, 14-21 days.
At any rate, we both have lots of spring cleaning ahead of us. I vote for the dethatcher. Mine is 4 ft wide, does a decent job but is time consuming.
I've seen the driveway groomer Lane Ranger posted, thinking of making one. A few homemade graders are on youtube, interesting.
Don1977
Rubber edge on a snow plow might be the best way to push that stone back in the road.
Tankman
Careful with that roller. #1 problem in PA = erosion. The 2# difficulty = compaction.
Sorry, years ago an agronomy student at Penn State.
For erosion use grasses or ground cover. Compaction? Spread gypsum or sand.
Minimize roller use, compaction. A roller will compact the soil. Good strong earth for mole tunnels!
Stone in your grass? Sorry, rake away. One very good reason to have many grandsons. Pop-Pop will supervise! :handgestures-thumbupright:
can whlvr
our town uses a mid sized mini excavator with a large stiff broom end on it,it does an ok job,but would be expensive for you too rent,maybe the town has something like this,its not a rotary broom,the hoe pulls the large broom and the gravel and road sand come with it,then they skid steer it,theres large vaccums too but again would be expensive
Retired Sparky
Looks like all that stone was is part of the original road bed. Of course I'm not there and like everyone else we can only add our :twocents-02cents:.  Looks like a nice well graded bank. I sat get some top soil and cover the D--- rocks, throw some hay of it, when the grass grows mow it and be happy.  :happy-jumpeveryone:
Peace Brother.B)
TDF5G
I'll offer my :twocents-02cents: on the gravel in the ditch situation.
You may already have tried this, but I use my dozer blade going backwards to pull the gravel from the grass back into my driveway each spring.  You have to turn the height control all the way down and the blade will ride with the contour of the ground.    It actually does a great job of grading going backwards and it won't dig into the soil.  You can experiment with different blade angles too.
It's hard to tell exactly how steep your bank is so I don't know if this will work, as I would think you would have to drive down and up out of the ditch, going the same direction as your driveway.
If it was me I'd just try to get the worst of it and let it go.  The gravel will eventually work its way into the ground.
Edited by TDF5G
IthacaJeff
The town got tired of trying to patch up the roadway that was undergoing colossal failure along along a 200 yard stretch. Much of the asphalt/chip/tar had broken up and the road bed below was mud. Temporary cold patch or trying to fill with crushed concrete did not last, so last fall they covered the whole 200 yard length  with crushed limestone. Good stuff, wish it was on my driveway. Worked well until the first snowplows hit it, and pushed the gravel to my bank and my neighbor across the street.
It was unwise to put down the gravel, though it did stop cars from sinking into mud pits on the road. My road is due for a complete new chip 'n tar job, but there are only two houses on the road. Low priority.
I've thought of the driveway groomer type of idea. I could set it down the bank and drive on the top. I don't want to push the gravel into the ditch as it does not drain water too well as it is. I cannot drive the tractor on the ditch bank -- not across or up/down. Much too steep.
Edited by IthacaJeff
Tankman
Thinking, lawn sweeper? I used to use a Parker (or Jackson) sweeper behind a Horse.
Might work on gravel, or not?
Edited by Tankman
Ed Kennell
I have never tried my sweeper and I probably should.  I just never thought it would be able to pluck the stones out of the grass.     If we get that 3" snow that's forecast for tonight maybe I'll plow a few stones back into the grass just so I can test the sweeper.
Ed Kennell
http://www.popularmechanics.com/home/tools/reviews/g125/6-top-shop-vacuums-tested/?slide=1
May be the answer Jeff.  I used a Craftsman dual motor shop vac on a 55 gal steel drum to pull balled up wads of curly drill chips out of the crannies of a 5 axis mill.
I am sure it would suck 2B stone out of the grass and they are deposited in a drum that can be hauled and dumped where they belong.
I am already starting to dream about the ultimate stone collector with the vacuum head mounted on top of an enclosed dump cart pulled by a WH with a front mount gen set,  a boom mounted collection nozzle sweeping left to right by an actuator  as the WH slowly moves forward with a foot controlled hydro...............
Oh my, I'm headed for the barn.
Edited by ekennell
Tankman
I have two Little Wonder lawn vacs. Threw the bags away, blow everything into the surrounding woods.
I am thinking sweeper would be best or, might the blower push stone?
Ed Kennell
Yeah, you definitely don't want to try to suck up stones with a lawn vac system. That could get real exciting when the stones go thru the blower.
But a high suction vac system that drops the heavy objects in a container and nothing goes thru the blower...That should work.
A blower would probably push the stones, but some of mine are thrown 20' into the yard.  That's a long distance to push a stone.
  • Similar Content
    • Jayzauto
      By Jayzauto
      GMorning Gang,
             Last year I had purchased an old C175 with blown engine and all the attachments the owner had with it, including the FEL.  He gave me everything he had, or thought he had.  It was quite a pile, requiring 2 trips.  Of course, in the heat of the moment, it appeared everything was there, except belts for the most part.  He even had most of the original documentation.  Now I know what your thinking, and you'd be correct...... everything was Not there. And as we all know, it's the little things that hold up the project AND seem to cost the most money.... mot to mention the heartache.  But, I did find an engine, got the tiller installed and working, the plow mounted, the deck running.  Now for the Big hit..... The FEL.  I do seem to have most of it.... The bucket and arms assembly, lower frame, weight box. weights, chains and even the pump , with brackets that was still mounted to the blown engine.  The show stopper here is what is called the "Front Mount Assembly".  It mounts to the front of the frame, and the stabilizer arms to the posts attach to it.  It also has a couple of hose brackets that hold the hydraulic hoses from flopping around.  I did look around, and none appear to be available...Big Giant Surprise.  I can't imagine anyone parting it out, even IF they knew what it was.   But I pretend to be a welder and have Fab skills,
      (Sorry, that should have read Fab Equipment), So I'm sure I could Hack one together if I had measurements.  The grainy B&W photo in the manuals make it look very simple (Hahahahahaahahahah).....Anyways, is there anyone that would be willing to take a couple color shots And Measurements of their "Front Mount Assembly"?
      Or rough estimates, then I can Make up something clos, and tweak it after its installed.
      It appears to be the Ark style Loader, with the catalog number of 97-40FL-01.   The actual part number of the bracket is: WheelHorse 260932 (part #36 in the pix)
      Again, it looks like it attaches to the front of both Frame rails and loops around the front.  It attaches with 4) 3/8" bolts and would have the hoses attached to it.  It looks like it loops close to the front of the frame, meaning the mule drive would have to be removed, maybe even the Attach-A-Matic front bracket too.  And its job is to give the Brace Arms a place to attach to.
      Wish I had more info to give,
      Can anybody help me out?
      Thanx in advance,  Have a Great weekend
      Jay
      I'll accept any form of communication, Calls, Texts, Emails
      781.630.0338
    • WVHillbilly520H
      By WVHillbilly520H
      I know I have sorta hi-jacked @PeacemakerJack's "let's go plowing/rolling dirt" thread with my gardening madness so I'll start it over here with some pics of the progress I have made so far and as planting and growing season continues... I also encourage any other RS member who is preparing a garden this year to contribute to this thread as well like @Greentored, @Andy N., @ZXT, ect so here it goes...from sinking a plow in the ground to tilling and discing to bringing over all of dad's sleeve hitch gardening implements to making rows and planting potatoes and onions today at the in-laws plot. Will update as things proceed like planting other veggies and maintaining plants and soil/weed control ect.
    • Blackhood Bill
      By Blackhood Bill
      Ok folks first of for those who have helped me "THANK YOU", But here we go again. I inherited my father's C-145A and I have apiece of equipment I need to Identify. It does have a Wheel Horse sticker on the rear left side while facing the rear. Looking for what it is, model, what it's used for, how it's used and any manual someone might have for it. Don't think I would ever use it, might restore it back to the Wheel Horse red( provided it was red originally) which is a good question, what was it originally. Please see the photos. Does this piece look complete? I think it is a disc but I'm not sure. Thanks again!!!!!!!!
    • tristan watson
      By tristan watson
      I'm looking for some help I'm wanting to fab a mid mount grader for my '73 10 automatic but I'm looking for someone who has one to measure it i have been looking online for the last few days and can't seem to find anything so if anyone know what the measurements might be or a webste where i might find anything i would really appreciate any help i can get on this thanks.
    • IthacaJeff
      By IthacaJeff
      I'm not really sure why I feel compelled to post this, and my daughter might kill me, but she finally got on the horse.
      It is a rule in the family that you cannot get your learner's permit for driving until you get significant seat time mowing.
      My 3 older boys had no hesitation, my younger 14 year old twin daughters have been getting some time, but 16 year
      old daughter has been reluctant to say the least. This has not been one of the forced chores, but a lesson in "If I
      want to do X, I'll need to suffer with Y".  Well, the other day I asked if she wanted to mow, same question as all
      summer, and I expected the same answer, "No thanks, dad, I'm good." But, finally, she agreed.
      Took instruction with great care, listened intently, and did a great job. The 416-8 is not the easiest thing to master,
      but she had no problems with the clutch, or keeping the tractor on a good mowing path. Got confident going
      around trees. It was awesome.
