Jim Slaaen
Wheel Horse Font
Jim Slaaen
Is there anybody knowing the name of the font type used on the hood-decals of C-120, 1974? I wonder about getting the letter and frame of the decal cut out in 2 mm steal with a water jet (water cutter), and powder coat them myself after in white, and use the hood-paint as background. SWRomnt is one that has the style, but is far to thin compare to the one used in the logo.
Jim
Edited by Jim Slaaen
Phatboy
Hats off to all you talented guys !! Im lucky i can write it on a piece of paper lol
Retired Sparky
WHEEL HORSE    Is that what you're looking for. I used Times New Roman and bold type set. It's in the font name folder above.B)
Edited by Retired Sparky
Martin
send a message to @Vinylguy. Terry would know what you are looking for.
Digger 66
Jim
Click the "bold" button.
Edited by Digger 66
Jim Slaaen
LOL. Do you think I didn’t tried that out? I’m not Swedish, I’m Norwegian ;)
  • Like 4
rjg854
What did the Swedes ever do to you? :bitch::ychain:
Jim Slaaen
Done. Thanks Martin :)
Vinylguy
the Lettering is not any font type that I could find so I traced and cleaned it by hand in my illustration software from an OEM decal that I scanned years ago.
I will send you an EPS file of it if you PM me your email address. Sounds like a great project. Post pics when done.
Terry
  • Like 6
Jim Slaaen
Thank you Terry. I'm not sure when I do it, but will post some images of it when it's done. :)
Thank you very much for the EPS-file. Helps me a lot. By that, the water jet get the path for the cuts.
Jim Slaaen
Sweden and Norway have a relationship like siblings. We love eatch other, but make fun of each other too. Like US vs Canadians.
Vinylguy
You are very very welcome Jim.
  • Similar Content
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
