dewdew
Lookin for help
dewdew
Well here's my situation I have this 76 d1-60 that I have about $200 into plus countless hours of work to get it mowing again.  Everything went fairly well last summer. But in the fall I noticed a slow drip coming from the transaxle. And the starter went out also shortly after the leak.
i need a mower that I can count on. I love this one when it works. So should I sell or take it in to fix all the issues. And can anyone tell me a ball park number as to what it's worth compared to what it would cost to fix it.
the bad...
leak in transaxle
leak at hydro motor and drive shaft
(I rebuilt the hydro motor following a tutorial on RS but didn't replace the seal where the shaft exits the motor.)
bad starter
the good..
it has never seen snow it was only mowed with and alway been in climate controlled storage.
it has a newer motor as of 1996(linnamar twin 790)
with less than 1500hrs
have all original manuals
what do you think I should do.
Im not made of money so as much as I would love to a complete restore is not an option.
Phatboy
Buddy in my opinion a good ol' tractor like that is extremly hard to find,, if it were me and i had that tractor , i wouldnt hesitate for a moment to get it fixed,, i would just bite the bullet, put her in get all the issues fixed , and you will habe a tractor that will out last you,, and do absoulutly any thing ya ask it to,, no doubt get her fixed,, thats my 2 cents..
pfrederi
Linnamar  is the same as an Onan???
DennisThornton
A D is noticeably absent from my herd and it dismays me somewhat but I'm also very leery of sick ones due to the hydros and hydraulics.  I'd suggest you keep checking back here to gather more info from "those who know" but keep in mind that the D series was the best Wheel Horse had for a while, or some might say the best they ever had...
pfrederi
The hydro motor drive shaft goes into the transaxle there is no seal where is it leaking??
Being a contrarian 1500 hrs on a replacement engine...how many hours on the tractor itself??  Using a big bulky d series with a 48 " mower deck has never made much sense to me....
Edited by pfrederi
Retired Sparky
I'm no ace mechanic. I'm lucky to have the same dealer twenty mins. away that I bought mine from 30 yrs. ago.   It sound like you have a sweet tractor.  If it's what you like, by all means spend some money and get her fixed.  I swear, I'll never give mine up.  I spent $2400 for mine new and another $2200. in repairs since '86.  Does this tractor look like a beat up pile of metal?  This Wheel Horse has out lasted everything in my neighborhood 5 or 6 to one.
DSC04790.JPG.73156f04a754cfe71197e901120
  • Like 5
Sparky
  The way I see it we are all trying to do our daily chores and depend on equipment made as far back as the 60's. Your D is probably a 70's vintage machine making it close to 40 years old.
  I don't know your budget....but I feel that a second machine (Wheel Horse of course) is a necessity because stuff happens and sometimes even our favorite brand of tractor craps out (like yours has). I have two machines set up for winter duty, my primary plow tractor and a backup.
  Get yourself a 300 or 400 series machine...much newer than your D series and it should be way more dependable. Then you can get the D straightened out while mowing with the spare tractor.
Mike.....
  • Like 6
slammer302
For mowing the grass I would maybe look more towards a good 300 series or if you need bigger a 400 or 500 series they have a better hydro trans and are a bit better suited for lawn care and if you really want to get the Cadillac of wheel horse go with a 522xi or 520xi. I picked one up this year and is a great machine with hydraulic steering and cruise control.
shallowwatersailor
It depends on how much you mow as to the best tractor model. We all know what the best brand is!   :wh: :handgestures-thumbupright:
I have about 17,000 sq. ft. on two acres that is grass. Because of dodging trees I have found a 42" to 52" deck is the best, even though I do own a 60" deck as well. I vary using my 518xi, C-105, and then for a portion of last year my C-145. Keep in mind a twin will burn more fuel than a single. That was one of the reasons why I bought the diesel 523Dxi. That will be the tractor for this year's season with the 52" deck as it is very fuel efficient.
Edited by shallowwatersailor
Retired Sparky
I use a 37'' deck on my 310-8.  It comes in handy because my lawn is no tennis court.  B)
dewdew
Thanks a lot for all your input guys,I really appreciate it. I feel like it's worth saving also. It works well for everything I throw at it you guys think I could get it all strained out for less than $500?
slammer302
I thinks so I've bought some nice machines for under 500$ so I think you could fix about anything you need to in that price range
pfrederi
Hard to say.  Starter motor will be about $100.  The leak if it is from an axle seal is $10-12 for seals.  I still do not understand the hydro motor shaft leak.  I believe the seal is an o ring and if it leaks doesn't it just go into the transaxle ??.where is it coming out???
Tankman
Try 'n pick up another Horse while you play work on your D. Makes sense to us forum members.
Two (or more) is always better best.  :rolleyes:
All said sad but, always sorry to hear 'bout dewdew on anyone's Horsey.
Edited by Tankman
dewdew
The leak is from the hydro motor. Where the splined shaft goes to the coupler that is attached to the flywheel
can whlvr
as sparky stated shes an old machine,the problem is down time with old girls,and that's why its good to have a back up,and then the d would get a lot less use and last a lot longer,the Linamar is a Canadian onan,they made them here for a while when emissions shut them down in the us,its getting pretty old for an air cooled engine,just sayin
pfrederi
OK now I get it.  That is the hydro pump...the hydromotor is back on the transaxle behind the left rear wheel. D's have  a split system the hydropump and hydro motor are connected by  a 4 pipe manifold.
The seal you need is less than $10.(worst case you may need a speedie sleeve if the shaft surface is damaged that would be about $25)..but as you know getting the pump out to change it is a "fun" experience.  How bad is it leaking...Oil is relatively cheap...just check with every use.  Most all of my old equipment marks it spot.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
