russellmc301
project rusty
russellmc301
so i figured since i see all kinds of people with projects so since i'm in the process of restoring am a-100 i thought you guys it like to  the progress.
ill get some pictures of it later today to post.
953 nut
:woohoo:        We all love to watch other people work!             :wwp:               :handgestures-thumbupright:
  • Like 6
russellmc301
IMG_0098.thumb.JPG.3c33f6575556412195161IMG_0084.thumb.JPG.2c2194b3f7a8ede416072
the front wheel that i painted
IMG_0097.thumb.JPG.72e61765c9072dee148ce
my homemade shiftier sticker
if wheel horse was a sticker company it would have done well, the stickers are still readable after 40 years
IMG_0092.thumb.JPG.59d6657605d1652acc61a
the hood that im painting
IMG_0096.thumb.JPG.68d5e76d76c1ba93a2469
hope the pictures help kind of blurry and bad but i only had the phone with me when i went out and got pictures
  • Like 5
russellmc301
what is the stuff called that goes around the brim of the seat to hold the seat vinyl to the seat frame?
Where could i find it would be nice too :)
Aldon
Might try edge guard material at a boat or automotive upholstery repair supply online store.
russellmc301
thanks,
 amc said that welt is what is used.
953 nut
It is known as "snap on or drive on windlace", I got some a few weeks ago from an :techie-ebay: seller, it was about $2.00 a foot and they have any color you could ask for.
russellmc301
thanks i am painting her fenders and petals now.
Edited by russellmc301
russellmc301
is it just me or is it when something is painted little imperfections pop out like a sour thumb?
JPWH
It is a fact. Try wetting it before you paint. You get a look before you paint. I have primed and sanded my hood about 6 times and still need to do more work.
russellmc301
what type of primer do you use?
if i do that will all the little imperfections be gone?
callum12
nice to see another A series owner, are you keeping it factory or modding anything?
Callum
JPWH
I use self etching on bare metal and rustoleum sandable. I know I find fewer imperfections each time I prime and sand.
Edited by Hank01
russellmc301
well i'm restoring it and i might add some mods to it but noting extreme... i think :)
any pic of your a-800? did you do any cool things to it?
953 nut
When you are prepping the area for a final color coat be sure to wipe it down with some "Prep solvent" to remove any hand oil and other trash from the surface. this is an important thing to do.
russellmc301
i am almost done with the painting of the hood.
just need to sand the other parts
russellmc301
how do you guys get like the shine of the paint
i have it all painted it just needs shined
Sparky
Pictures??
I have no painting skills so I have no advice on getting a good shine....sorry.
Mike.......
russellmc301
it says my pictures are over 2.1 MB so i can't upload them,
a new question: how do you paint with a brush without brush marks i just think the tight areas would be easier and cleaner to brush it.
Lane Ranger
A very good  quality brush and Flood Penetrol added to oil based paint will smooth out the application of paint on metal.   My  C 121 was painted with a paint brush !  Not me but I have done some   Wheel Horse 1054  parts and hoods this way.
Here is a link to info on Flood Penetrol
http://www.amazon.com/Akzo-Nobel-Coatings-Inc-00415/dp/B0002YWSOU?SubscriptionId=AKIAJO7E5OLQ67NVPFZA&tag=shopperz_origin2-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B0002YWSOU&ascsubtag=046374572-24-1946577139.1456105323
russellmc301
THANKS
The only thing is i need to polish some already painted things:(
953 nut
If you have orange-peal then you will want to wet sand with 600 wet and dry then polish with rubbing compound followed by polishing compound. You are basically using finer and finer abrasives to achieve a smooth surface which will reflect light evenly, the polishing compound will take care of dull flat finishes if that is your only problem. If you have a power buffer be very careful with it, keep it moving and keep the pad damp with compound to prevent burning the paint.
russellmc301
so when i keep getting finer will i have to  keep painting it?
whats orange peal?
i have 400 right now i think, ill have to look though.
thanks for the help
953 nut
You are not really supposed to sand off the paint, just flatten out the high spots.
whats orange peal?
Orange peal is a texture like that of an orange, basically it is like a bunch of drops of paint next to each other, sanding and polishing will flatten them out. Do a search on the internet for "Color Sanding" and you will find videos that may explain it better than I can.
You should not be using anything courser than 600 Wet or Dry and need to wet sand with a liberal amount of water for color sanding and only use it sparingly, most of your work should be wet sanding with 1200 followed by rubbing compound and polishing compound.
russellmc301
ok thanks this is my first time ever painting somthing so i have some little inferfections but i just gave up and i hope it will look good once polished
i started to brush the frame and cast parts today
  • Similar Content
    • Rugerhound
      By Rugerhound
      Greetings!
      I have a non-Wheel Horse tractor (Craftsman 14 HP Briggs OVH) , but the part appears to be common to the Briggs & Stratton Engine rather than a Craftsman part.  (See the photo -  The connector and pins I need are circled in blue)
      I also have a 1977 Wheel Horse A-100 that needs a tail light lens & bulb.  (A complete tail light assy would be fine!)    Anyone got any idea what the Peterson part number is for the tail light for the model I have?
      Thanks!!
      Regards,  Pete
    • Rugerhound
      By Rugerhound
      Greetings everyone!
      I'm a new member to this forum and a new Wheel Horse A-100 owner.  I'd been looking for an inexpensive fixer-upper riding lawnmower to make my yardwork a little easier for an aging fellow like myself.   Snagged this A-100 for $250 that's in really decent shape for the most part.  The mower deck has some problems however, but the actual tractor is in great shape.  Doesn't look as though it was used much, and still has all the original tags on the Briggs  & Stratton stickers on the housings.  Engine sounds fine but the needle isn't shutting the fuel off properly, so it runs rough until it's revved up a bit.   The pedals have scarcely any paint worn from them.   Quite remarkable for a '77!
      So I have one of the blade shafts bound up, another that doesn't feel all that nifty.  I don't know if those bearings are sealed, or whether anyone might be able to clean 'em up and repack them for continued use.  Pulleys are in rough shape but I may be able to salvage them.    Any info on the bearings in the mower deck would be very helpful!   (Including recommended grease type, etc.)
      Also it needs a key... The Ignition switch is an INDAK 103991 which appears to cross to a Toro.   New switches are available, but does anyone know if it's possible to just purchase a replacement key?
      I'm guessing it takes typical non-detergent 30W oil...  It's a '77 model Briggs & Stratton 10 HP.  (Model 251707, code 77040412)  What fluid does the gearbox take?
      Thanks!!
      Regards,  Pete (Aka Rugerhound)
