engineguy63 238 #1 Posted February 14, 2016 I will be looking towards getting another horse to fix up soon, and want it to be user friendly for yard work,mowing, snowblowing, plowing, etc. I like the earlier looks.........metal hoods etc...I really HATE plastic. I was kinda thinking a C series would fit the bill best. I understand that the C series was just a bit bigger than the B , and the D was the biggest .thats all easy to follow, but little earlier Charger bronco, raider etc........were some of these earlier versions of the B/C series or just a difrent size category all togather???? Thanks for the clarity 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #2 Posted February 14, 2016 Boy! This is going to be fun and take a bit of time but others will chime in and help. Just a quick comment or two: For the longest time I thought the B series was just a smaller than the C series tractor. Nope! The early Bs, like the B-60 & B-80s were the same frame as the Cs but without some options. Later the Bs went to vertical engines, weaker trannies and were no longer really a garden tractor. Indeed the D's are big boy tractors but also keep a keen eye out for 953s, 1054s, GT-14s, C-195s and the newer 5XIs! The C, 300s, 400s and 500 (not the 5XIs!) are the same frame sizes and have plentiful choices of attachments, unlike the more limited D series and the 5XIs. If I had to limit myself to one WH I would cry, but then I might oddly enough look for one I don't even have! The GT-14s and C-195s have become very appealing to me! Oh my 5XIs are bigger and in several ways better, newer and more advanced but the larger wheels, more common attachments (though some are different!) and 3 pt hitches are really desirable! Realize that a big book would need to be written to fully address your short question! 8 Share this post Link to post Share on other sites
rmaynard 15,426 #3 Posted February 14, 2016 Pretty much what Dennis said is what I was going to say. But if you are looking for something simple to service, powerful enough to cut grass, push snow, and other chores, and is a good looking rig, you can't beat the 1976 or 1977 B-100 or C-120 8-speeds. And it is all metal! 14 Share this post Link to post Share on other sites
stevasaurus 22,705 #4 Posted February 14, 2016 I might as well throw the wrench in this. The guys above are correct...but if you want a really easy starting, better gas efficiency and sharper turning...with all of the above and about a 4" shorter frame...you want a short frame. square hood. 1965, 1966, 1967. My B-100 is sitting out the winter in the garage while my 876 and 857 are doing snow duty this winter. The 8 hsp Kohler has plenty of power to tackle any chore. If there is a down side, they do not have the 8 speed transmission, but the hydro solves that issue. Of course...there is no issue when you have one of each. 16 Share this post Link to post Share on other sites
slammer302 2,155 #5 Posted February 14, 2016 I agree with stevasauras i have had larger horses with plows but find my self using the smaller short frames i've used my commando 8 the for plowing the last couple years 4 Share this post Link to post Share on other sites
Shynon 7,459 #6 Posted February 14, 2016 8 minutes ago, stevasaurus said: Of course...there is no issue when you have one of each. 3 Share this post Link to post Share on other sites
DennisThornton 4,769 #7 Posted February 14, 2016 I haven't used my short frames yet and I only have a deck for my LR so I'm curious, which ones are most desirable and just how hard is it to get attachments? Share this post Link to post Share on other sites
slammer302 2,155 #8 Posted February 14, 2016 I have a snow plow for my LR it does work but their is no down pressure but add a couple pounds of weight and it works just fine 1 Share this post Link to post Share on other sites
tractorhogg 612 #9 Posted February 14, 2016 I have 9 different brand built garden tractors, try and get know all there is to know about that many brands or at least 2-4 models of half a dozen brands, it takes some time. 3 Share this post Link to post Share on other sites
stevasaurus 22,705 #10 Posted February 14, 2016 Dennis, I actually think that attachments for the short frames are more abundant, and more reasonable then the long frame attachments. Don't forget, all the Round Hood, front engine stuff fits the short frames also. As far as desirable...the 1965/1966/1967 horses are all pretty much the same. You can find them with a Tecumseh 6 hsp on some models though. Personally, I would shy away from the Teckys, but they are more rare and therefore more collectible. The 857 is my favorite, and they seem to be plentiful. 5 Share this post Link to post Share on other sites
DennisThornton 4,769 #11 Posted February 14, 2016 45 minutes ago, stevasaurus said: Dennis, I actually think that attachments for the short frames are more abundant, and more reasonable then the long frame attachments. Don't forget, all the Round Hood, front engine stuff fits the short frames also. As far as desirable...the 1965/1966/1967 horses are all pretty much the same. You can find them with a Tecumseh 6 hsp on some models though. Personally, I would shy away from the Teckys, but they are more rare and therefore more collectible. The 857 is my favorite, and they seem to be plentiful. I notice few short frames, Round Hoods, tractors or attachments up this way. Always been a Kohler fan but sometimes you just got to gas up what's in it! Why the 857? 1 Share this post Link to post Share on other sites
stevasaurus 22,705 #12 Posted February 14, 2016 The 857 was my Dad's and I think it was his go to horse. I like that the hood lifts up, unlike the Round Hoods that use the thumb screws. The 8 hsp Kohler will start just by looking at it and will run all day on a tank of gas. Cornering is hard to beat...almost zero turn. This tractor has not been OSHA'd yet...easy wiring and electrical maintenance, and no fuses everywhere. I really like the rear discharge 36" mower decks for these horses...gear driven. And I pick up more chicks riding around the block with this horse, and any of the others that I have...it is a chick magnet. 19 Share this post Link to post Share on other sites
slammer302 2,155 #13 Posted February 14, 2016 3 minutes ago, stevasaurus said: The 857 was my Dad's and I think it was his go to horse. I like that the hood lifts up, unlike the Round Hoods that use the thumb screws. The 8 hsp Kohler will start just by looking at it and will run all day on a tank of gas. Cornering is hard to beat...almost zero turn. This tractor has not been OSHA'd yet...easy wiring and electrical maintenance, and no fuses everywhere. I really like the rear discharge 36" mower decks for these horses...gear driven. And I pick up more chicks riding around the block with this horse, and any of the others that I have...it is a chick magnet. My commando 8 was gave to me by my dad and was my first horse. Sounds like we have the same story stevasaurus 4 Share this post Link to post Share on other sites
Pullstart 62,783 #14 Posted February 15, 2016 (edited) 22 hours ago, rmaynard said: Pretty much what Dennis said is what I was going to say. But if you are looking for something simple to service, powerful enough to cut grass, push snow, and other chores, and is a good looking rig, you can't beat the 1976 or 1977 B-100 or C-120 8-speeds. And it is all metal! So now that you've brought up the B-100 which I know is your favorite WheelHorse, what is the difference between a B-100-8 speed and a C-101-8 speed of the same years? Other than the obvious that yours is immaculate and mine is less than stellar! Edited February 15, 2016 by pullstart added picture 3 Share this post Link to post Share on other sites
Tankman 3,518 #15 Posted February 15, 2016 Love the 12 hp, 14 hp's and the 16 hp Kohlers. All easy to service and rarely need it much. Great garden tractors. 6 Share this post Link to post Share on other sites
shallowwatersailor 3,213 #16 Posted February 15, 2016 My choice would be a Black Hood. What the heck, just go big! 5 Share this post Link to post Share on other sites
857 horse 2,581 #17 Posted February 15, 2016 On 2/14/2016 at 1:10 PM, slammer302 said: My commando 8 was gave to me by my dad and was my first horse. Sounds like we have the same story stevasaurus Well folks you heard it here first,,,,you wanna round the block and bring home the bacon and the babes......Gimme a call,,,,we will work everyone into the schedule... On a serious note.......something I rarley do.... we will have a spring 857 line-up,,,, all running... snap a few shots of the happy almost 1/2 dozen 857's..... with the Titantic Suburban In the meantime, we pushed 1/2 a foot today,,,,,,,,,,,,,, 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,489 #18 Posted February 16, 2016 Shallowwater's right when he says " My choice would be a Black Hood. What the heck, just go big! " Unlike most of these guys, I have one horse that does it all...She's not only cute, but she multi-tasks as well...Sorta like a perfect wife (which btw I am also blessed with!). It's a C-105 black hood with a 10hp kohler. Handed over to me from my brother and still going strong... 5 Share this post Link to post Share on other sites
Retired Sparky 526 #19 Posted February 16, 2016 You guys blow me away at your knowledge about these . Just curious, is 86' 310 long or short frame? I've owned my for 30yrs. and didn't know there are some many models. 1 Share this post Link to post Share on other sites
953 nut 55,051 #20 Posted February 16, 2016 Just about every '67 and later is a long frame. Share this post Link to post Share on other sites
Retired Sparky 526 #21 Posted February 16, 2016 (edited) OK then, I like what I got. Edited February 17, 2016 by Retired Sparky 1 Share this post Link to post Share on other sites
Retired Wrencher 5,441 #22 Posted February 16, 2016 On 2/14/2016 at 11:33 AM, stevasaurus said: Dennis, I actually think that attachments for the short frames are more abundant, and more reasonable then the long frame attachments. Don't forget, all the Round Hood, front engine stuff fits the short frames also. As far as desirable...the 1965/1966/1967 horses are all pretty much the same. You can find them with a Tecumseh 6 hsp on some models though. Personally, I would shy away from the Teckys, but they are more rare and therefore more collectible. The 857 is my favorite, and they seem to be plentiful. Steve what's up with the Tecky hater? I love those pain in the A>> Teckeys. Gary B.... 2 Share this post Link to post Share on other sites
rjg854 11,349 #23 Posted February 16, 2016 Well my Commando 8 didn't do too bad this morning with this soaking wet snow we have, altho I see a strong need for chains! I filled the tires with RV antifreeze, and I only weigh in at about 160 lbs. She just wouldn't push long distances with all that weight in front of the plow, but as long as I could take small bites it pushed fine. With just the turfs, it would lose traction. Chains I'm sure would have given me more bite. This is my first year having a for snow duty, so it's also a learning process for me. I'm really impressed though on just how well it does it's job. The other day when it was 20 below it started as tho it was 70 degrees. This morning we have steady rain and about 4" of snow but it is nothing but slush. Do I understand this is a short frame tractor? It's really maneuverable I got everything plowed out around the barn and the shed, and the house, which is basically a big circle. The 1/4 mile drive I drove down with the truck to open that up, I try the after I dry out to clean it up some more. Maybe by then it will melt out and make plowing easier. I could leave it but when it freezes again later, it will really be tough to plow. There was no way the blower on the other Commando was gonna deal with that slush. I did get to use it last night when I got home to clear a big drift and it worked great. I wish I had gotten into Wheel Horse years ago. 2 Share this post Link to post Share on other sites
stevasaurus 22,705 #24 Posted February 16, 2016 Gary, I actually like Tecumsehs. The 3.5 hsp on my Ariens walk behind snow blower is fantastic. The 2 502's I had were great also. I did have to mess with the carbs more then the Kohlers, but when they ran nice...they ran nice. If there is one thing I do not like...the Chinese bought them. Prices for parts are ought of sight now. That is the real reason I look to shy away. 1 Share this post Link to post Share on other sites
TDF5G 2,069 #25 Posted February 17, 2016 Here is the Master Model List. You can see that not all models were all produced in the same years. http://www.mywheelhorse.com/graphics/file/wheel_horse_products_master_model_list.pdf Share this post Link to post Share on other sites
