Chain for Single stage Snow Thrower tall chute
By
RT WH416H, in Implements and Attachments
Similar Content
By HyperPete
JD LX-178 with Kawasaki 2 cyl water cooled engine.
Great shape except for the front hood. Cracks have been patched, and hinges on the hood itself are broken. Hood sits fine, just does not open & close properly
NO DECK!
Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
Well maintained. Snow blower presently not mounted.
By wh315-8
10HP with 42” blade, C-85 w/cab & 42” Snow Blower, 315-8 w/Ark Loader. Ready for some snow ❄️. Last year had up to 14” in Ohio.
Snow cab windows were fogged up bad and I used MeGuires PlastX, this stuff was easy, apply like wax, rubbing it in and wipe off, amazing how it cleared that plastic window up.
By Boyd
wheel horse garden tractor mower, rear discharge mowing deck & snow blower both in good condition and runs well. all the parts for the snow blower are with it.
By Bill D
Picked up this Toro Power Max yesterday. The rake is shot but the gearbox is good and the shaft isn't bent. Why Toro doesn't use shear bolts, I'll never know.
By Macgyver
I got hold of a Wheel Horse snow blower model 6 6212. It has the crank with cable to direct the shoot. Everything is there but the spool the cable is wound around. Can someone tell me the dimensions of that spool. Diameter and length. Thank you.
