ztnoo
Kroil Penetrating Oil?
ztnoo
Have your ever used Kroil penetrating oil, and if so, what was your impression of its performance?
Any comparisons pro, con, or neutral with other penetrating products?
I've noticed it generally doesn't seem to be available locally in a retail setting.
Seems like its really only available online.
It's not cheap either, but if its more effective than other products, it might be worth it.
Opinions? Comments?
Edited by ztnoo
oldredrider
Been using it for years. If it doesn't work,  it's not coming apart!  Originally introduced into the industrial/commercial markets...real torture test environments. In my opinion, there is no other product that compares to it. And yes, the price is worth it.
  • Like 4
doc724
I use Kroil for the really tough jobs (hub removal, steering wheel removal, rear hitch pin removal).  Beats PB Blaster hands down.  It is pricey though and hard to find.  I bought one of the big spray cans like the one shown in your pix and it has lasted three years-but I am selective where I use it.  I have never found it on line, but the good industrial supply houses carry it.  If you call them, I will bet they can tell you who in your area carries it.
ztnoo
DennisThornton
Pricey but perhaps the best.  I've spent a LOT of time reviewing and gathering opinions and I and many others think Kroil is a leader if not the leader.  Some folks have said that Kroil didn't work either but that may not be fair.  Maybe nothing was going to work or maybe Kroil couldn't get through all the other products already tried.  I use it for "mission critical" problems and if I have tried something else I heat it until I've driven off whatever didn't work before I try Kroil so Kroil is not blocked.  Now of course heat and I think heating and cooling helps to, even if not to red heat, so some might say "Well, you heated it!  That's why it worked!"  and they might be right...
cafoose
SALTYWRIGHT
A LOT OF GUN SHOPS CARRY IT.   RUSS
ztnoo
Here's a related discussion I found on this general penetrating oil topic, in case you missed it:
Aldon
In my own experience it's best penetrating oil out there. It really tends to seek or penetrate.
I have always felt I got good value for expenditure.
tech270154
did anyone  ever try home made penetrating oil.
very easy
50%  transmission fluid
50%  acetone
just mix it and apply or pressure it  in a can to use
own experience   very very good and cheap
try it
WHX??
I never heard of it before signing on here and never saw it in a store so I thought you guys were all on crack but I guess not. Always used PB or liquid wrench with mixed results. Would have liked to try it on this really tough 'burban steering  wheel but gave up on possibly of damage so just restored it as is with the bottom end off. As the old saying goes try anything once, twice if I like it so will order a can. Acetone is just finger nail polish remover right?
Aldon
very easy
50%  acetone
try it
I have heard that this is very affective as well although I have never tried it personally.
WHX??
Thanks for the where to buy cafoose
Also thanks to ztnoo for digging that thread out.....
Ok ....gonna go take a pic of my "lube" cabinet to show you guys all crap I have in ther....
Shynon
Just bought another can of it the other day, I use the small oil can version, just a couple drips on the affected area and let it sit. Place I work at has been using it for years in the maintenance shop, that's were I learned about it. It's the only stuff I use. If it won't come of last resort is some heat.
WHX??
Where do you get it from Tom, never saw it at Fleet Farm...
WHX??
Does it keep hoobie's from snapping off? ??:hilarious:
Shynon
Got mine from Amazon
NO only hoobie doobie's :ROTF:
WHX??
Good enough for snapping your doobies...good enough for mine......:blink:
dcrage
very easy
50%  acetone
I for one did try this and it didn't work worth a damn -- For whatever reason they didn't mix -- Ended up with 2 separate phases -- Maybe there are all different kinds of transmission fluid -- It wasn't the acetone, I had pretty pure stuff from work
roadapples
You need to be careful with acetone. It will remove some paint, and take the lettering off of engine decals. Ask me how I know....
tech270154
i did try it and it work pretty good,the acetone make the transmission liquid very fluid .and they stay mix together
cafoose
I just got this from amazon and it works good for Kroil it's well made, leak-proof, conserves the oil, and puts just enough right where you need it with little to no waste:
http://www.amazon.com/Titan-Tools-15200-Precision-Oiler/dp/B002LYQALQ/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1456642903&sr=1-1-catcorr&keywords=titan+precision+oiler
Then I got this they work great together and the oil will last me a very long time.
http://www.amazon.com/Kano-Kroil-Penetrating-liquid-KROIL/dp/B000F09CF4/ref=sr_1_1?ie=UTF8&qid=1456642843&sr=8-1&keywords=kroil
Lane Ranger
You need to be very cautious using Kroil as it can damage your skin and it keep it clear of eyes, cuts.  One collector friend had serious skin damage from being sprayed in the face.    It does work better than PB Blaster.
http://www.brownells.com/gun-cleaning-chemicals/oils-lubricants/lubricant-protectant-oils/kroil-prod7610.aspx
Edited by Lane Ranger
ztnoo
That precision oiler looks like a pretty nifty, handy tool.
Listed  features:
  • For precision oiling in tight and hard to reach places and machines
  • Smooth, push-button actuator allows for greater control and placement of lubricant
  • Machined aluminum body for extended life
  • Protective screw on cover and seal prevents leakage Convenient pen-style pocket clip
  • Convenient pen-style pocket clip
The small semi-transparent bottles with with stainless steel needles look like they might be handy also.
http://www.amazon.com/Applicator-Bottle-Stainless-Steel-Needle/dp/B00BNI6TOE/ref=pd_sim_263_6/183-1927117-6135736?ie=UTF8&dpID=31sHlMcl71L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1ZF1CDMDTH9DBTY8WG9F
cafoose
One nice thing about my precision oiler is that there is no spray and minimal chance of getting it in your eyes and it makes it easier to protect your skin.
  • Similar Content
    • ztnoo
      By ztnoo
      Gentlemen,
      Late last fall I was sweeping my lawn with a pull behind sweeper behind my GT 14. I had been running hard and fast for about a half hour and generally turning sharply to the left while maintaining high speed. Suddenly the rear wheels quit driving. I later found the hydro drive belt had come off the pulley powering the hydro. It has happened before. I'd much rather sacrifice a belt (or ten) if need be, to avoid a Sundstrand Hydrostatic tranny teardown and repair.
      When I looked around a bit more, I discovered my left rear wheel hub had move inward about one inch on the axle. From what I can see it did not come on contact with the axle housing, but there is not much clearance remaining between the hub and the housing.
      It was previously flush with the end of the axle, just like the right side hub still is.
      I believe with my hard left turns while sweeping at full speed for an extended period, the hub and axle was pretty heated up and the force that was being applied was such the hub slid inward toward the axle housing.
      Its not quite touching the housing, but the hub has moved inward about an inch.
      So, I resolved I need to move this hub outward again and secure it in the proper relation to the axle with the two set screws on the inside of the hub before I test the tranny operation. It appears the woodruff keys in both hubs are still secure and in place. I don't believe any shearing of them has occurred. I believe my drive problem was all belt related. (fingers crossed)
      The problems is, how do get the hub moved out???
      This tractor is a 1969 model, and having had the axles replaced in the '80-'81 time frame, I know those hubs haven't been off for 35 years.
      I know these can be really, really hard to remove.......or even moved enough to get it returned to its original orientation.
      I've read some horror stories about getting wheel hubs like these off an axle.
      The hub O.D. is 7". The lug spacing is in a 3.5" x 3.5" square pattern, and the axle diameter is 1 1/8". These are cast hubs and are very substantial and beefy, as I'm sure you other GT 14 owners know.
      I have attempted using a two jaw puller, with PB penetrating oil, alternating with torch heat with absolutely no movement, for a couple of days.
      Its my belief what pressure that puller was able to supply is too far away from the axle centerline for it to be effective. Also, I think just pulling from two points is not enough. I think whatever pressure which is applied to hopefully move the hub, needs to be applied at more points around the hub to get the job done. It seems like increasing the number of pulling points plus moving the location of the pulling points as close to the center of the axle, is the only reasonable solution to be able to move this hub.
      How do I do that......huummm.
      I have been a member of the Yahoo Wheel Horse Garden Tractors forum for quite a while and have inquired over there and received some suggestions. I also looked at this site prior to joining for advice about hub removal.
      It seems like the best and most effective method suggested here is to use another hub just like you are dealing with, and convert it into a puller using the lug holes as the pulling points and the center of the hub with a nut and bolt as the push point.
      Unbelievably and stupidly simplistic.....but apparently very effective and logical. A home brew puller can be fabricated duplicating the lug spacing and pattern, but another hub is the easiest and most straightforward way to go.
      I read it still it requires lots of effort to move, but is generally the best way to get the job done, along with penetrating oil and cautious use of heat.
      It appears to me this will be my best shot at moving this hub.
      Any suggestions or advice about this method.....or any others that comes to mind to achieve what I want and need to do???
      Anyone have a old GT 14 rear wheel hub collecting dust somewhere they would be willing to loan, rent, or sell for a reasonable price for use as a puller???
      If you do, please contact me to discuss possibilities.
      Enclosed are pics below of my hub situation and a suggested solution described and shown here at Red Square.
      Any ideas will be greatly appreciated.
      Thanks for your time and consideration.
      Regards,
      Steve
      _________________
      Flush hub, right rear
      housing to axle spacing, right rear
      inset hub, left rear
      housing to axle spacing, left rear
      left hub and axle, wheel removed
      Example found here @ Red Square suggesting use of another like hub used as a puller
