Snowblower Bearings
By
arminer8, in Implements and Attachments
Similar Content
By Evguy
B100 8 speed and short chute snowblower for sale near Indianapolis Indiana.
good deck and tires, engine runs.
transmission needs axle seals and bearing.
too many projects, not enough room.
By DaveQueener
I have my late father's 1965 Wheelhorse 10hp model 1045 with mower deck and dozer blade that I would like to get to a good home. My Dad was working on getting it running again shortly before he died. It's going to new new rear tires and the transmission seems to be stuck after sitting so long, but it does come with some extra gears for the manual transmission along with an extra housing.
The 1045 did sell today to a friend in Knoxville for $475. He has an auto body shop and loves old equipemt, so I have every confidence it will get restored. My thanks to those of you who inquired. --Dave Q
By Kenneth R Cluley
I have decided to upgrade the wheel bearings on front wheels of Rear engine rider. The original flange "bearings" are Taiwan lets call flow through not sealed . The hub of wheel has a grease zerk and entire hub fills with grease until it flows through bearings and out side. I have purchased a sealed flange bearing and cannot decide if I should pull the shields and just pump it up till it flows through or flush out and pack with Pete approved Lucas high pressure and replace seals and not use zerk anymore. What do you geniuses recommend? I realize I would have to regrease on some maintenance interval either way.
By FarmallFarmer09
I recently purchased my first wheel horse with a number of new attachments, And included in that bundle was a Wheel Horse snow blower. I would love to use it, But as it seems, Its missing a few key components to use it. Its missing the 2 side caster wheels, Along with the lift rod. does anyone know where i could potentially pick up either of these things?
By dave who poos
Hello!
I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
