Similar Content
By ebinmaine
I know this subject has been covered multiple times over the years. We have a lot of new members and many of us like to refresh ourselves too.
Please feel free to post links to old posts as well.
So what can you share with everyone about plowin' the White stuff??
Common things like what tires and weights.
Why you prefer a certain tractor. (Please Be kind to others as we have different needs and opinions).
What orange/amber lights are required by your local officials while in the road?
How much space do you save for future snow piles?
Is there anything you found that was unplanned for that the rest of us should know?
Whatever you can / care to share.....
By Jack Oldham
Hi All,
I have a question regarding doing an electric mod on my Wheelhorse A800 Ranger. What I wish to do is install some front headlights, rear brake lights, and indicators on all four corners i would also like to install a horn a some point but that can come later. I'm unsure on the best way of wiring this, what gauge wire to use, do I need a fuse if so what ampage and where also what size amp hour battery is best to use if I'm running these additions so i don't drain the battery. I understand more how I'm going to wire the indicators than how I'm going to get the break light to work but really require advice on both.
Thanks for you time in reading this.
Jack Oldham
By Petes Horse
I've been looking for a while. The bolt holes just line up and the wire is a little tight between the fender and light. No drilling though.
They were at Rural King. I think about three bucks each. Optronics MC42RS RED Marker/Clearance.
By edwroy
So my question is: when adding cab lights do you wire directly into the light system of the tractor or do you wire to the battery with a fuse wired in line?
Would be interested how some have wired their lights.
Thank you,
Edwroy
By KC9KAS
The lights on our 875 are what I would call "bug eye" lights.
My wife (on WH Junkies all the time) thinks she has seen these lights with a flatter lens.
Are these lights original Wheel Horse lights?
