cmorrow
520LXI Dozer blade lift link
cmorrow
Hi all,
Quick question that I am hoping some of the members of this forum could help me with.
I am a fairly new owner of a 520LXI. I purchased it with the dozer blade, part 79355, over the summer. Last night I decided to install the blade since they are calling for a surprising amount of snow in our area this weekend, and I am excited to try it out! However, during the last step of installation I realized that my blade was missing either of the lift links for my tractor. In this case I believe I would have wanted to use the slotted link to avoid down pressure with snow removal.
In the manual, this looks like a pretty simple part to fab up, and it just attaches with 2 3/8x3/4" clevis pins to the attachment lift plate under the tractor. If you have this setup, would you mind giving me some dimensions of the slotted link? Specifically, overall length, location of the end hole and start/stop of the slot?
There seems to be a ton of dimensions for the older tractor/blade links, but I was unsuccessful in searching this forum for details on the newer style.
If I don't have this link, it looks like I could simply loop a small piece of chain over the lifting bar for the mower deck and attach it to the blade as well - does anyone see an issue with that?
Thanks a ton for any help!
shallowwatersailor
Just in time! Another hour and mine would be installed. The PO did some modification with an extra hole and inserting a bolt to shorten the slot.
  • Length: 8-3/8"
  • Width: 1-1/2"
  • Thickness: 5/16"
  • center to hole from edge: 3/4"
  • Slot length: 2-1/4"
  • Hole and slot width: 3/8"
DSCN3300.thumb.JPG.db33f6298527d39a3afd6
cmorrow
THANK YOU SO MUCH!
That is fantastic! So helpful.
I hope your snow removal goes well this weekend!
gwest_ca
  • Length: 8-3/8"
  • Width: 1-1/2"
  • Thickness: 5/16"
Thanks for posting this.
Does this look accurate?
Garry
shallowwatersailor
Yes, Garry, mine has the bolt in it so the slotted-end inset could be different than the other end. The bolt just shortens the travel in the slot.
1 hour ago, cmorrow said:
THANK YOU SO MUCH!
My procrastination, given the history of snowfall in this area (next to none sometimes), has made me scramble now! The forecast is mid 40's for next week. But the city just about shutdown with 7/10's of an inch so we will be snowbound if we get the 28" that they are saying.
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $300 Or Best Offer.
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • Jrodgers04
      By Jrodgers04
      Selling a nice deck for the 5xi line. Starting it at $500 on FB Marketplace, open to offers.
      Model Number: 78395
      Good shape, ready to put to work. Does not include pulley box.
      Recently sold the tractor. Was going to make a coffee table out of it but the wife is not interested.
      Overall good operating condition. Cuts well, spindles, pulleys, rollers, and wheels are in good shape. Deck is solid, no rot. Very heavy duty, weighs over 300lbs. The only piece not functional is the install wheel. This does not affect the operation of the deck, just installation/removal.
      Located in Beverly, MA. Delivery available for right price.
      Video is from a week ago.
      My Movie.mp4
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • Trouty56
      By Trouty56
      Tractor vs. Implement cross reference chart for models from 1955 - 2000
      110 pages 513.43KB
      This chart lists the original attachment model
      The model that replaced the original model
      The model that was available when the list was made
      Often many models between the last two are not listed.
      You must go from year to year and follow the model numbers to see them all.
      For a complete list of models click on the magnifying glass in the Search box. Enter DNA in the Search box and select Files from the drop down menu. Two pages of 33 results will come up in random order. Find the attachment you are looking for and click on it. The DNA for that model of attachment will come up. Look for the model of your attachment in the DNA list. They are organized from earliest to latest.
      OR
      Search the Files using a model number you know will work. Look through the results for DNA in another file name for the same item. That will have the full list of models.
      STD for a model indicates that attachment was standard equipment that came on that model of tractor.
      Mistakes in the online attachment list @ Toro. The Attachment Interchange is correct but confusing and the source of the mistakes.
      1970 *VS           rear discharge mower deck                             5-7362 is correct replaced by 5-0610 both CCW rotation
      1971                  rear discharge mower deck                             5-0600 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 rear discharge mower deck should be model 5-7362 - CCW spindle rotation
      1972 *CG-7 & 8 rear discharge mower deck should be model 5-0610 - CCW spindle rotation
      1973 *VS           rear discharge mower deck should be model 5-0611 - CCW spindle rotation
      1970 *VS          side discharge mower deck                             5-2365 is correct replaced by 5-0700 both CCW rotation
      1971                  side discharge mower deck                            5-0710 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 side discharge mower deck should be model 5-0700 - CCW spindle rotation
      1972 *CG-7 & 8 side discharge mower deck should be model 5-0701 - CCW spindle rotation
      1973 *VS           side discharge mower deck should be model 5-0702 - CCW spindle rotation
      1974 Replacement rear discharge mower deck for the model 5-0622 (side discharge) is wrong - should be 65-36XR01
      *Models using a vertical engine crankshaft
