BEN LORUSSO
homemade 3 pt hittch
BEN LORUSSO
Hi , im new to this forum. I have two wheel horses that im always fooling around with and joined to get more involved. I have a 520-h and a 310-8 my current project is making up a cat 0 three point hittch for the 520 i was wondering if anyone else has attempted to make one. its almost finished I just have to figure out a way to lift it. i made a linkage out of flat stock that goes to the lift cylender for the attachments I just have to make a shaft for the lift arms abd have to figure out lift links aby ideas?
  • Like 6
  • Heart 1
953 nut
:WRS:   Looks like you have a good start toward a 3 point hitch. :handgestures-thumbupright:  I suppose if you were to make up a rocker shaft mounted above the arms and use a cylinder mounted toward the bottom to push up the rocker it can be done. May be best to use a separate pump to provide the hydraulics, others may know more than I do on this and will chime in.
DennisThornton
Man!  Would like to see more closely but from here that is neat!
Have you studied the 3 ph models WH sold?  I've not.  I don't own a WH 3 pt but would like to.  You have so little room to work in hydraulics or electric but it's been done, by WH and others.
Can't help much but I can sure "Follow"!
elcamino/wheelhorse
Can remove the seat and take more photos . The more info you provide the better . :bow-blue::text-welcomeconfetti::wwp:
BEN LORUSSO
i'll get more pics on here soon, but as far as lifting it im trying to utilize the original lift cylender i made a linkage to the back from the first arm the cylender moves on the left side and will make up some kind of shaft that it will actuate. but plan B is going to be a hydraulic pump driven off the pto and mounted in the front            attach-amatic and a small cylender probably mounted right to the lift arms because there's really no practical place to mount it vertically and turn the shaft. And yes i have looked at some of the other WH 3 points, the mounts i made for the lower links i kind of copied from a GT 14 but the real challenge was finding a place for the top link mount without cutting out the fender I really don't want to do that because its a really clean machine
BEN LORUSSO
  • Like 5
SylvanLakeWH
Very cool! And :text-welcomeconfetti:!!!
BEN LORUSSO
sorry about the bad welds im still learning theres two top link mounts one above the fender the main frame is bolted to the carrige bolts that hold the plow mount on shown in the third picture. to hold up the main frame in the middle i used the bottom halves of an old bagger mount i had for the 310. the second to last pic is the brackets for the lower arms and yes i had to add a reciever hitch ;). and the last pic is the lift linkage
elcamino/wheelhorse
Ben , Check out the Forum classifieds I think someone has parts for sale on a 3 pt from a GT 14. I saw picures.
WNYPCRepair
Did you move the gas tank somewhere else, or will it still fit in there somehow?
BEN LORUSSO
well once its done i plan to solder up a steel tank to take up any extra room back there I know i will sacrifice a little less storage
I thought about using the mount for the lower arms off a GT 14, but I wanted a reciever hitch just below the trans
roadapples
Lookin` good so far, and welcome to Red Square..
KC9KAS
@BEN LORUSSO :WRS: Good build project!
BEN LORUSSO
thanks for the welcomings ill get back to the hitch next week I have to throw the plow on there tomorrow we're supposed to get 6 inches this weekend
stevebo
I am here in New Milford. A buddy of mine and I came up with a solid design lifting using the rock shaft and no other lift cylinder needed. I am out of town now so cannot post pics but look up Tombo three point hitches in search.mmight not have info on the new site but on the old. We wanted to sell them but not enough interest.
Here you go
gwest_ca
Think about such a project quite often.
Wonder is one could add a curved mount for the top link to the rock shaft that lifts the lower arms. Have it so the top mount is below the fender pan when down and have it swing around the pan and end up above the pan when up.
Garry
jackhammer
welcome
elcamino/wheelhorse
Here you go
I found info from the Thread but video could not be found . I wonder if you could repost the video when you have time :bow-blue:
BEN LORUSSO
Here you go
pictures would be a big help
:text-thankyoublue:  just got to figure out a rock shaft now . my intentions for the project was to use a cat 0 subsoiler to run sprinklers in my future "mini- orchard" do you think the cylender would be strong enough to provide down force? I know from using the snowplow on my 520 that little cylender is beefy enough to lift the front wheels off the ground.
stevebo
The hydro was strong enough to lift at least 200+ but also depends on the arm length.
Fireman an took the video I do not have it.
KrazeyOlDave
Any updates or videos of this yet?
  • Similar Content
    • Zeek
      By Zeek
      I decided I needed a way to carry some things around when working with the tractor. This is not a "Wheel Horse" attachment, but will work with any Category 1 three point. The idea came from a Kubota guy that did some great videos on how to make it.
      I decided to go with a Rural King "King Kutter" frame for three reasons: 1) it was red and I didn't have to repaint it to match, 2) I liked the RK mounting points better than TSC because they were mounted away from the frame farther and accept quick hitch if you use that, and 3) out of three TSC location around me, NONE had thier County Line carrier in stock. RK had three for the same price of $159.
      I added a hitch receiver to move utility trailers. I beefed it like the video by adding a piece of steel and routing out the underside so it sat flush. For chainsaw carrier I routed out a 2x6 enough to fit the saw bar.
      My rear tires are water filled, but this adds a little more weight as well. I plan to get a big HF (1K) furniture dolly to put under it when not attached because it's too heavy to slide around. I can get that for $12. A handmade one cost more than that in just wheels.
      Here are some pictures of the build if you could use something like this.
    • Rob R
      By Rob R
      Hi fellow Wheelers I just completed the fabrication of a Three Point Hitch for my 70"s GT14. Parts List include:
      1. Used Wheel horse Rear Axle Bracket to which I added two Class One Hitch Pins with a steel bar welded across (bar was from an old shaft from a bad shock absorber)
      2. Lower lift and Center lift bars and center lift arm (purchase from e-bay for $150) Note: One side was adjustable and the other solid, I changed the solid one so that is also adjust so that I could obviously adjust it and also make it fit better by removing a section and welding-in two threaded bolts
      3. A twenty inch Class One tow bar from Tractor Supply for $139
      Think you'll agree it came-out pretty good. Comments or suggestion appreciated
      As a side note might someone know what the rear pulley on the GT14 is for..... I assume perhaps the rototiller... but it looks so flimsy for that?  Thanks
