KyleHorse 8 #1 Posted January 18, 2016 my new to me 416H has no volts or hour meter, i see from schematics that oil pressure unit must come on first before volts or hour meter works. are these prone to sending units going bad or should i be looking elsewhere?? i unhooked all connectors clean and reassembled, everything looked good and corrosion free. the hour meter shows 495 hours and that should be close cause it starts and runs great and previous owner used it sparingly. any info on where to look would be appreciated. also the test lights work but oil pressure light blinks running or not. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,921 #2 Posted January 18, 2016 See if these diagrams help. If you don't have a 1990 or 1991 model post your serial number. I believe all oil lights flash if they are activated. The only one that does Appears a 15 amp fuse powers a pink wire common to all three. Garry. Share this post Link to post Share on other sites
Martin 2,131 #3 Posted January 18, 2016 (edited) check your fuses. more than once I've lost power to the gauges or had erratic behavior from them due to a bad connection at the fuse. Cant remember which one for the gauges, but it would pay to check all three anyway. also check the 9 pin connector at the engine/main harness connection for burnt connectors etc. notorious for problems there as well. there is another 9 pin up higher on the mid 90s models that might need a look too, not sure if all years had them though. Edited January 18, 2016 by Martin Share this post Link to post Share on other sites
rmaynard 15,309 #4 Posted January 18, 2016 Yes, the oil pressure sending units can go bad. 1 Share this post Link to post Share on other sites
