Xearl 132 #1 Posted January 18, 2016 (edited) I am going to motorize the shoot deflector on my snow thrower but I don't know how to wire the switch and route the wires.switch2.htm . I have a 523DXI . Edited January 18, 2016 by Xearl Share this post Link to post Share on other sites
wallfish 20,509 #2 Posted January 18, 2016 (edited) Switch used should be a DPDT 2 center terminals + - to the motor. Doesn't matter which side is which flip flop + - on the out side terminals. Be sure to power it so it turns off with the key and maybe add a 20A fuse in there too. I'm not familiar with your tractor but you can pull the key switch out. Should be an "A" terminal for accessory so you can wire it from there and use any ground point on the steel of the tractor for the - feeding the ouside terminals of the switch So basically the switch is reversing the polarity going to the motor for switching the direction it spins. Test before installing and mount the switch so the chute travels the same direction you are pushing the switch. http://www.instructables.com/id/HOW-TO%3a-Wire-a-DPDT-rocker-switch-for-reversing-po/ Edited January 18, 2016 by wallfish 2 Share this post Link to post Share on other sites
Xearl 132 #3 Posted January 18, 2016 Thanks Wallfish ! That's just what I needed . I knew Red Square would come through . ED ---- Xearl ( Remember Then ) Share this post Link to post Share on other sites
cleat 9,219 #5 Posted January 18, 2016 And do not forget to add a fuse on the red wire going to the battery. Cleat Share this post Link to post Share on other sites
Xearl 132 #6 Posted January 18, 2016 11 hours ago, wallfish said: Thanks for the advice . ED Share this post Link to post Share on other sites
jeff lary 173 #7 Posted January 20, 2016 (edited) I know no one here would believe this but I was honestly just wondering if anyone had ever figured a way to power angle the shoot. Freaking amazing this place is !! I probably am not clever enough to do it but I was just about to post the question ! Jeff Edited January 20, 2016 by jeff lary Share this post Link to post Share on other sites
can whlvr 994 #8 Posted January 20, 2016 yes its been done,i think duke powered his,both ways,up and down,and side to side Share this post Link to post Share on other sites
Xearl 132 #9 Posted January 20, 2016 I have a 10 AMP circuit breaker left over from my boat . I wonder if that would work ? Share this post Link to post Share on other sites
