arminer8
Mower Deck PTO and snowblower attachment
arminer8
I need a PTO for operating the underbelly mower deck of a 1966 Wheel Horse 856. Anybody got a part number or ideas? Also, anybody got any idea how you could take the welded on sprocket on the end of the auger off and replace it? mine is worn out and don't turn the auger anymore.
Thanks in advance,
Alex
Edited by arminer8
Different diagnoses
gwest_ca
Welcome to the forum.
Some general info
Original dozer blade
Snowthrower but your's may be different
One of the mower decks
Garry
  • Similar Content
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      Wheelhorse Snow blower Fits c100's 500's etc. with a front mule setup. Works. Comes with lift Flag & Lift spring relief. Also have a set of rear tire chains for additional - $50
      Have a set of custom exctra heavy rear wheel weights if interested as well. $75
      Snow Blower Only, Tractor Not For Sale.
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
