oldhorse2 3 #1 Posted January 7, 2016 Will a Lift Kit removed from a 1975 WH work on a 1974 C-120 WH? The "Interchangeability Listing" calls for a Mod. 8-4112 Lift Kit for a 1974 WH and a Mod. 8-4113 Lift Kit for a 75-77 WH. While several of the components are the same in each kit, many are different (hoses, valve assembly, springs, etc.). Share this post Link to post Share on other sites
stevasaurus 22,893 #2 Posted January 8, 2016 You might need @gwest to answer this one...if he does not see this...send him a PM. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,108 #3 Posted January 8, 2016 I don't know the answer but it appears the lift cylinder was changed in 1975 so that alone would generate a new part number for the kit. Garry 1 Share this post Link to post Share on other sites
oldhorse2 3 #4 Posted January 8, 2016 Thanks to all who responded to this so far. I have some additional information. The lift was removed from a 1975 C-160 (Mod. 1-0481) with a 90-1140 Sundstrand. The question here is whether it will work on a 1974 C-120 (mod. 1-0490) with a 90-1136 Sundstrand. Share this post Link to post Share on other sites
Callen 64 #5 Posted January 18, 2016 (edited) I would get the transmission from the tractor too, that way you have all the correct parts for the valving to make it work. Edited January 18, 2016 by Callen add to make sence 1 Share this post Link to post Share on other sites
Ed Kennell 38,887 #6 Posted January 18, 2016 I think it may require different hoses and fittings also. I believe the pressure ports are on top of one and on the rear of the other. Can't recall which one is on the rear and has a longer hose. Share this post Link to post Share on other sites
