Pullstart
Picked up a C-101 this morning!
wallfish
2 hours ago, rjg854 said:
That looks like one choppy ride. Sure hope your fillings are tight.:teasing-neener:
Little bit huh?
Put them back on after the show if you plan to cruise it around. If they stay on I'm going to follow Kevin around and pick up all the loose change falling from his pockets! Maybe some cash too if he goes fast enough. LOL
  • Haha 5
Pullstart
49 minutes ago, wallfish said:
Little bit huh?
There’s springs under the seat.  For the first time in quite a while, I’ll feel like a real farmer bouncing in my cap’m’s chair!
  • Haha 1
Bill D
7 hours ago, Pullstart said:
I did some switcherooing today.  These Deestone 23-8.50-12’s are the first tires I ever bought for a :wh:.  They’re also the first I ever fluid filled.  I don’t know the source of these chains, but they are monsters!  They happened to be the only tires that the chains fit.  Well, it was meant to be.
I pressure washed them, mounted them up (they are super heavy!), then added these fairly wide :wh: plastic/concrete weights.
What a difference in the way it pushes!  There is still no engine.  @wallfish and I plan to remedy that once we get settled in at the big show!
I believe @JoeMhas a nice Onan B48 for sale.  Build something really wild! 😜
  • Haha 1
Pullstart
I’ve got a plan… it’s gonna be great!  Not wild, just great!
  • Haha 1
  • Confused 2
953 nut
1 hour ago, Pullstart said:
I’ve got a plan… i
Be afraid…be very afraid….or not ? – The Party Blog
  • Haha 5
Pullstart
I’ve been looking for this picture.
This was about the time I cannabalized this tractor to make it to the Big Show with Putt Putt.  Next, the engine was needed for a project that became “Frank,” Mrs. P’s 1073 custom.  Then, it was torn down for this, that, and another thing to a pile of parts.
Pullstart
953 nut
Cirrus Fibratus at sunrise, over a C Series :wh:
  • Excellent 3
Pullstart
I kinda got an idea.  It started with “I can fix up this old stack,” but has come to “I can build a new stack!”
  • Like 5
wallfish
Posted (edited)
Make some cool music. Anyone can pepper pot an engine.
Can you Fryderyk Franciszek Chopin  or rap like .50 cent?  LOL :violin:
Edited by wallfish
  • Haha 2
Pullstart
I drilled the spot welds out of some old pulleys and popped them apart.  One is a mule drive pulley, the other a clutch tensioner from a Raider 10.  Doing some math, I decided 14 3/16” holes in each row would be adequate to meet the throughput of this 2” stack, more than enough for a 1” black pipe.  The second chamber baffle allows half the area of the pipe to flow through the outside, and the rest is directed back inside the 2” pipe.  I’m hoping for a mellow tone, not too loud, and not too wimpy.  I’ll machine a block sleeve at the bottom end to well center a 1” x 6” pipe to run the exhaust up towards the welded center baffle and weld it all together before it’s complete and ready for some high temp paint.  I’ll probably weigh the tink slapper down so it is more active than normal.
Pullstart
  • Excellent 2
Pullstart
I won’t hear this make noise, until the Big Show.  That’s when this tractor will get its destined engine.  I need to finish the bottom end of it, to screw into a 1” black elbow.  I have a mock up engine here and will build a stack brace, then will paint it, and pack it away for the show!
Pullstart
Hi temp paint is drying!
rjg854
:popcorn:I'll be waiting to hear what it'll sound like.
953 nut
There is a guy named Donald that would have one thing to say about this picture;       DRILL BABY DRILL.              :ROTF:
  • Haha 4
Pullstart
I used a broken rod engine for a mock up piece and built the rest of the exhaust.  It should work out great!
  • Excellent 3
Pullstart
Me too!   :orcs-cheers:
  • Haha 1
Handy Don
Very impressed with the innovative chain support!
SylvanLakeWH
:text-yeahthat:
:clap:
Pullstart
Have yo ever seen those tensegrity tables?  I had that idea in mind, then it transformed into what you see.  My hope, is that it all works on the planned engine at the show!  Once again, there will be not much room for adjustment once it’s all assembled, and I won’t know if it works until we get there!
Pullstart
One more piece of the puzzle.  I’ve got this #26 carb all dipped, cleaned and tuned up for the show.
Pullstart
A HUGE thank you is in order, to @wallfish for giving me this engine, and for his and @Tractorhead’s help today getting it running!  A @Pullstart Kohler 12 hp engine!  It runs and sounds amazing!
  • Excellent 6
Pullstart
  • Excellent 2
Pullstart
I’ll probably end up sticking a push button in place of the toggle switch, but I have a functioning dash now.  Choke, throttle and kill.  The throttle on the engine shroud was too cool to remove and has a real smooth tight brake on it to keep the throttle set.  I used an old fire suppression cable on the dash and cut it to fit.  It is sleeved using an old Small Block Chevy valve cover tab welded to a piece of 3/8” fuel line.  I also cut the choke cable to fit, so there is no excess slack anywhere on the tractor.  Notice the shift pattern.  Somehow, I ended up with this backerds print.  If you aren’t careful, you might find yourself in the wrong gear but we drive by muscle memory, right?
  • Excellent 2
  • Similar Content
    • SethL1984
      By SethL1984
      312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
      417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
      (1) 42" RD with mule drive. Cuts well!
      (1) 48" SD with mule drive.
      (1) 37" SD.
      (1)  48" snow plow. 5 way blade position I believe.
      Several other parts/WH odds/ends. One tractor does include the weights and chains.
      Parents are moving and, unfortunately, need to thin the herd!
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Ralpho711
      By Ralpho711
      I have a 1976 C-120, 8 speed, that has had a bad rear axle key way for about 35 years.The plastic steel we put in to keep things together finally gave up the ghost last year. I tried some welding but that hasn't held up either. My question is will the rear axles from a C-81 8 speed fit in my transmission? According to the parts lists I found on this site, both trans have 1 1/8" axles and 8 pinion diffs, but the axle part numbers are different.  Any help is greatly appreciated. I'm brand new to the site and think its great!
    • Red144runner
      By Red144runner
      I mow 7 lawns on the side 3 are neighbors. One in is a good size and flat. The only pita is a swingset. I like using the tractor on it for several reasons, it does a beautiful job, it needs to be bagged and with I only need to empty twice, my proline 36” I empty 7-8 and it’s a good excuse to run it for 90 minutes.
