PeteHansen 0 #1 Posted January 2, 2016 Will a Wheel Horse 208-4SD deck fit on a Wheel Horse 312? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,467 #2 Posted January 3, 2016 The 208-4 uses a vertical engine crankshaft so the hardware at least will be different. If you can't sit them side by side for comparison all you can do is compare the parts lists. What is the width of cut and how many spindles? 208-4 36" rear discharge 3-blade model 35-36RL01 208-4 37" side discharge 2-blade model 35-37SL01 Garry Share this post Link to post Share on other sites
PeteHansen 0 #3 Posted January 4, 2016 On 1/2/2016 at 1:35 PM, PeteHansen said: Will a Wheel Horse 208-4SD deck fit on a Wheel Horse 312? OK, thanks for your help. Share this post Link to post Share on other sites
