Terry M
Question for the K90 experts
Terry M
Doing a disassemble on an old Kohler k90 engine today and found that it has a very unusual magneto set-up .  Is this typical magneto set-up of a pull start k-90 engine?
No magnets on the flywheel...instead , theres a "donut" looking magnet around the crank.    And, any idea if a replacement for the coil can be found?   Just curious and not too worried....Its just an old parts engine I'm using for a project:)
Sorry, I'm more of a tecumseh guy and Kohlers are somewhat new to me...
Thanks in advance for any info received .
TerryIMG_2718.JPG.781656ee45f00730beb2f551ebaIMG_2719.JPG.307f5a8dafc754fd2e86deadb13IMG_2720.JPG.6c6e4fedc8141c528ade344794bIMG_2721.JPG.5736840f8231a15a6c293e17b65IMG_2722.thumb.jpg.08f70f7c5857dc38669d7
wallfish
That there is a Bendix coil and about impossible to find a replacement. Even if you can find a NOS coil, it will probably be cracked and useless because of the epoxy they used to build them. One option if you want to keep everything original on that engine is to have it rewound. The other option available is to change the plate, coil and flywheel. I went with option B after searching and searching and searching for a replacement.
Terry M
Could I also ask , is the crankshaft specific to the bendix magneto set-up?,  Or ,will the crankshaft work also on newer style k91 magnetos and engines?
Shynon
Terry had the same thing on by k161 on my 704, found a new coil on :techie-ebay:
wallfish
20 hours ago, buckrancher said:
coil is readily available Bendia Scintilla Magneto Coil OE 399-125 #BE20 on amazon
http://www.wheelhorseforum.com/topic/42741-kohler-k160-230075-coil-replacement/
Brian
WISH I FOUND THAT A FEW YEARS AGO!!!!!!!!!!!!!!!!!!!!!!
I searched around for 6 months before finally giving up and changing all that stuff. Even searched the outboard sites too! BUT, I think I still have all those old parts so maybe I can get that donor engine back together with a new one of those.
Edited by wallfish
buckrancher
may have spoke to soon John the K90 coil may be smaller than the #be20 coil I will have to check it out
Brian
wallfish
Hmmmmm, think I remember finding a larger one. Maybe about 1/2 inch too long.
Don't think I changed the crank so I believe your crank is good
Terry M
Thank you John!:)
This may be something I might try....I know somebody with the know how to do it yourself......it's worth a try :eusa-think:.
jb4249
Terry, That is completely different than my K90 I am trying to make run for an RJ58. I am getting a weak spark from it. I have 2 K91 and was able to put the magneto  stator assembly from one of them in the K90, but then it had no spark. I am trying to find a plug wire for the K90, so now I'll keep looking for that.
Ted
Brian01
Tearing into it I see Terry...good luck...that coil was giving intermediate fire....sometimes it'd fire real good and other times, real weak...I'm assuming because it's cracked and older than dirt. lol
Also, yes I member seeing them on EBay...like $40ish, if I member correctly.
VinsRJ
I personally would swap the parts as John indicated and run a more traditional ignition system... I have used the Taiwan coils off ebay without issue... although you will need to modify it to fit.
Here is my review of the replacement coil:
https://www.youtube.com/watch?v=pylbLgR3Jvs
Terry M
Good info on your video Vin, Thanks:)
  • Similar Content
    • chompinthebit
      By chompinthebit
      Hi all,
      this is a early 1956 rj-35 I picked up and named Ol’ Crusty. I thought I’d share a picture timeline of things I’ve done on it since I’ve gotten it. The reason I say early 1956 is because it has a C channel frame like the 55’s with 55 style hub backing plates and some 1955 features but has a 1956 hood with small kill switch hole.
      the tractor has been cleaned and clear coated. Also wheels were stripped and painted original black.
      i believe this tractor was a local government owned tractor for mowing around a township building or something since it had many payers of the typical yellow paint you see on Govt owned equipment.
      reproduction aluminum steering wheel
      reproduction belt guard
      restored k90
      added electric starter
    • chompinthebit
      By chompinthebit
      I found this K-90 at an auction and it turned out to be a wheel horse spec engine dating to 1956. I attached some pictures of it as I did the paint work. I didn’t start taking pictures until then unfortunately. I then put it in a 1956 rj-35 I have
