rodney10954
snowblower lift pin scrapped off
rodney10954
So I acquired a snow blower for free a few years ago that needed some work and I finally get it fixed up and I knew the lift pin under the blower was questionable but I  figured I could get a season out of it , on the first lift the arm drops. I know there was a thread where someone flipped the pin and put a nut on instead but I cant find the thread. its where the lifting bar connects to the blower. has anyone fixed theirs or modified it in a better way. Right now I have 2 small "C" clams and it seems to be ok but no snow yet so not sure if the clamps will hold if scraped on the driveway. New auger gear pic below.
Ed Kennell
I drilled mine open to 1/4" and  use a flat washer and a 1/4" SST hex bolt and nylock nut.     Never had a problem.
I would think your C clamps will vibrate loose and fall off.   If you are lucky, they won't end up in the blower and launched thru a window.:hide:
rodney10954
did you have to cut the brace off? mine looks like one solid piece of round bar the comes up and is welded to the housing of the blower
looks like this, I was thinking about the bolt thing but was wondering if I would loose some strength if I took off the brace
Edited by rodney10954
Ed Kennell
I don't understand why you think you would have to cut off the brace.  My bolt goes thru the same hole that the hairpin clip was in.   All I did was enlarge that same hole that was about 3/16" to 1/4" and replace the hairpin clip with a bolt and nut.
Which blower do you have , The one shown on the tractor or this one?    The one you have shown above is probably for a vertical engine lawn mower and may have a different lift post than the one on the tractor.
rodney10954
I have the one on the tractor , the one above was just to show how my lift post looks. The post on mine is worn down to where the hair pin goes in. I didn't understand what you had said about drilling out but now I do, was thinking you did something else. You have a good point about the C clamps falling off and going through a window never thought about that lol.
cod
Here's how I fixed mine and it worked great last winter.  If you search for the thread, there's some photos that might help.
Good Luck - Cod
rodney10954
thanks cod , this was the one I was looking for
rodney10954
I didn't get to fix it but I ran it with the C clamps  ekennell  you were right I lost one of the two but im not sure where it went but not though a window so im happy lol
WHX??
Good Idea cod, mine had a real small mangled up hairpin when I got it. On went a stout one that got mangled up 1st snow. Your fix will be on the to do list when she comes off this fall.
  • Similar Content
    • whfan74
      By whfan74
      All original Wheel Horse D-200 with snowblower
      ⭐️⭐️103 original hours⭐️⭐️
      3point, rear PTO, and turning brakes
      Brand new battery
      Runs smooth with no issues.
      Located in Nappanee, IN
      Can deliver to Leseur Show August 22-24 if deposit is paid.
      $3350
    • Jayzauto
      By Jayzauto
      Toro - WheelHorse SnowBlower fits “XT” Models.  Model 79483 Serial 240000164. In great shape, has high chute, wide kit installed and has belt.  Skids show little to no wear, so I’m guessing not used much.  SnowBlower only.  No mule drive or lifting hardware.
      $250/BRO
    • wh315-8
      By wh315-8
      10HP with 42” blade, C-85 w/cab & 42” Snow Blower, 315-8 w/Ark Loader. Ready for some snow ❄️. Last year had up to 14” in Ohio.
      Snow cab windows were fogged up bad and I used MeGuires PlastX, this stuff was easy, apply like wax, rubbing it in and wipe off, amazing how it cleared that plastic window up.
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
    • jebeli
      By jebeli
      Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
      I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
      I could possibly deliver or meet half-way or ship.
      Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
      42in high-shoot snow blower
      42 in rear discharge deck
      Snow blade
      Front mount deck hanger with 42in side discharge deck
      30in lawn seeder
      Brinly single bottom plow with cleavis or sleeve hitch
      50in grader blade
      Extra transmission
      36in rear tiller - leaks a little
      Full set of tire chains for each tractor
      Various body pieces
      7.5 cubic ft pull behind cart - may need tires
      Extra set of rims
      All required belts, pullys, brackets, manuals, too much to list.
