zekepiks 8 #1 Posted December 8, 2015 I have a older 32 inch blower that I have always mounted on my 76 C 160 , I just bought a 94 314-8 and after I mounted the blower to the front of the tractor I went to install the lift tube and it was about 8 or 9 in to long. ( I didn't measure it ) The arm that comes down to lift the implements has only one hole in it and that one is the one the flag misses, I thought about drilling a new hole but I'm sure that would make it much harder to lift. I know I could probably make a new tube to fit but I didn't realize they made different wheel bases, what's the deal Share this post Link to post Share on other sites
ericj 1,578 #2 Posted December 8, 2015 recheck to make sure you are trying to get the right hole. the frame should be the same on a C160 and the 314-8. they are basically the same just different sheet metal. good luck. eric j Share this post Link to post Share on other sites
WH nut 553 #3 Posted December 8, 2015 Should go into the top hole of the bellcrank. Been there done that. Share this post Link to post Share on other sites
