Similar Content
By CHuls
*Estate Sale*
71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
Not sure what it's all worth together but, make an offer.
By PMeadows
Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
By RJ Hamner
The C-160 just wasn't running right. Started with new points, plug, filters.
I had put an aftermarket carb on it but had found a good Carter N in the correct size so I rebuilt it.
Got it started this afternoon and had it running at about half speed to warm it up so I could make the final adjustment to the carb.
It purred along for about 4 minutes and just quit.
First thought was "out of gas". Looked in the tank and sure enough it was really low so I filled it up.
Tried to start it again .....NOTHING
Went and rechecked everything ....NOPE
Got out the can of starting fluid...NOPE
Pulled the plug and noticed the gap was ZERO. Re-gapped and tried again. Same thing again no gap.
Pulled the head. Looked normal.
When I cycled the engine I noticed that the exhaust valve didn't fully retract.
Was able to remove the exhaust valve with two fingers!!!!!
Guess I am in the market for a new set of keepers and a few gaskets.
The guys at McHenry's Small Engine Love Me
By tractorman99
Hi everyone,
I bought a wheel-horse c-160 a while back, and did some work with it.
One day the rear axle housing broke:
I was thinking about changing the part or soldering the broken pieces.
Does anyone know where to order this part? Or has any idea of the potential cost of a soldering job?
Thank you in advance!
By RJ Hamner
Picked up this C-160 a couple of weeks ago from Joe out in SW PA. It had been on the Classified page for a while so I went out for a look. Got her home and got a new battery, new plug, new plug wire and some fresh gas. She purrs like a BIG kitten! Drove her around the yard a few times and put her on the lift. Got some of the parts I am going to need at the BS and some more from Jay in GA. Wife told me I have to finish the all the trim work in her "home theatre" in the basement so......... I do get a few hours in. After all, "Ya gotta let the finish dry between coats"
